View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 08-26-2013, 05:41 PM   #309
suaveflooder
Originally Posted by frs10 View Post
do you have the VIN range handy?
I thought I did, but it's questionable, so I'd rather not give you wrong information. I'm not sure if the dealer understood my question sadly
suaveflooder is offline   Reply With Quote
Old 08-28-2013, 12:43 AM   #310
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
It is confirmed that my car has the "ZA1JA01C" update. The build date is 12/21/12.
Muaddib is offline   Reply With Quote
Old 08-28-2013, 01:06 AM   #311
suaveflooder
How did you confirm?
Old 08-28-2013, 01:21 AM   #312
Muaddib
Mentat
Muaddib's Avatar
I brought the car to the dealership and that is the answer that they gave me.
Old 08-28-2013, 01:24 AM   #313
suaveflooder
Interesting. I was told they couldn't tell. Might have to try another dealer. You already had it or did they update you? Thanks for responding.
Old 08-28-2013, 01:28 AM   #314
Muaddib
Mentat
Muaddib's Avatar
According to the guy i was talking to. The ecu was updated prior to delivery.
The Following User Says Thank You to Muaddib For This Useful Post:
suaveflooder (08-28-2013)
Old 08-28-2013, 01:52 AM   #315
ft_sjo
Drives: GT86
IIRC TechStream tells you what the cal is.
The Following 2 Users Say Thank You to ft_sjo For This Useful Post:
Sportsguy83 (08-28-2013), suaveflooder (08-28-2013)
Old 08-28-2013, 01:55 AM   #316
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
It does.
Sent from my iPhone using Tapatalk - now Free
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 08-28-2013, 06:44 AM   #317
regal
Drives: Scion FR-S/Toyota Yaris
Does anyone have access to Toyota parts directory to see if any part numbers on the engine changed around this date ?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 08-28-2013, 06:50 AM   #318
ft_sjo
Drives: GT86
Part numbers and engineering codes are usually separate. The former would typically stay the same, whatever the cal.
Old 08-28-2013, 06:56 AM   #319
regal
I don't know how OEM's do things in England but any change to a part requires a part number change at a well run Lean OEM like Toyota. If there has been a part number change it may provide a clue why Toyota isn't offering this calib. to early adopters.
A place like Lotus yea I can see them still using engineering codes but we all know where they are headed.
Mods:
Old 08-28-2013, 07:24 AM   #320
ft_sjo
Drives: GT86
You are a silly sausage, don't let your hate of everything outside of the United States affect your judgement. Parts have BOTH part numbers and engineering codes. The latter is usually stamped on the part somewhere, and typically includes the year of design.
The Following User Says Thank You to ft_sjo For This Useful Post:
strat61caster (08-28-2013)
Old 08-28-2013, 07:37 AM   #321
regal
I haven't bought a big three car in 25 years. In 2013 a part can't change design without a part number change, stampings can change with suppliers. Are you suggesting Toyota may have had a problem with one of their castings suppliers?
Mods:
Old 08-28-2013, 08:19 AM   #322
ft_sjo
Drives: GT86
You're wrong, and your last sentence is just nonsense. I give up! You're a lost cause!
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
