Old 08-27-2013, 06:35 PM   #15
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
I have a mostly light downhill drive from SLC to my place about once a month -- 45 mins all freeway. Got the trip display to show over 40mpg when reset after getting on the freeway. 6AT here. It was awesome.
Also just took her from SLC -> Vegas, San Luis Obispo, Carmel, Monterey, Tahoe, back to SLC and averaged 33.5 according to trip - that's including some spirited driving on the PCH. Awesome stuff!
Proof: http://imgur.com/881bmC6
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 08-27-2013, 06:36 PM   #16
ntr0py
ntr0py's Avatar
Drives: '13 FR-S Asphalt M/T
Originally Posted by Veloist View Post
How flat are the places you guys drive?!?
I have 21.5mpg mixed on my FR-S and it's kept below 3k RPM since it has 430 miles.
I get 42mpg mixed on my 2012 Prius.
I had a Scion xD that got 19mpg mixed
My 06 Corolla gets 24mpg mixed.
I do live in a hilly place with 8-12% grades for over a mile.
The freeway is pretty flat but my home is about 2 miles off the freeway and it's all up hill and down hill from there. My average for the life of my car (about 4500 miles) is just over 29 mpg. I keep track of it using the Gas Cubby iOS app (didn't know about Fuelly). The 39 mpg I got above was all pretty much flat.
ntr0py is offline   Reply With Quote
Old 08-27-2013, 06:39 PM   #17
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I've gotten 42 on a 10 mile trip before. However, I have a hard time maintaining above 29 on the computer. Once you get on the gas that average plummets
Old 08-27-2013, 06:44 PM   #18
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
You guys drive like grandmas.
Old 08-27-2013, 08:31 PM   #19
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
If I want to drive like a Jackass, I take my other car. The BRZ does just fine on fuel and with so little relative power stomping on the go pedal every so often only hurts a little.
ntron1 is offline   Reply With Quote
Old 08-27-2013, 10:46 PM   #20
frsvr4
Drives: '13 FRS
I like to keep the revs relatively high while not necessarily driving like a jackass so I don't always have to downshift to accelerate. It makes me laugh to find out that the meter actually reads high. I cleared mine today at about 1200 miles, with a 24.x mpg average. In the short trip thereafter, I didn't come remotely close to 20 mpg
-Jackass
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 08-28-2013, 09:24 AM   #21
fistpoint
Drives: Supercharged Golf Cart
Mine gets 127 mpg
fistpoint is offline   Reply With Quote
Old 08-28-2013, 09:33 AM   #22
Boostedpro
I wish I could see those kind of numbers. Mine gets about 20-21 mixed driving.
Boostedpro is offline   Reply With Quote
Old 08-28-2013, 12:56 PM   #23
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by WHITE View Post
Its really impressive how well this car does on gas when your not driving like an a-hole. My current best was during a return trip from Williamsburg VA to wilkes-barre PA. i did the entire 334 miles trip on less then a tank of gas getting my highest avg. of 44mpg, this was even with 2 hours of stop and go traffic, going 65-75 mph when possible, and having 265/40 18's on the back and 255/40 18's up front on 18x9.5 rpf1's. 6spd manual trans also.
I was speechless.
Edit:
i lied, just found the picture i took of my avg. during the trip,
So how did you get the odometer/computer to compensate for the larger diameter rear tire?
smbrm is offline   Reply With Quote
Old 08-28-2013, 02:08 PM   #24
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
I didnt, i assumed it would screw up the computers read out but the speedo has been dead nuts with every gps/speed sign/iphone app/other car woth me. Soooooo unless theyre all wrong then my computer compensated for the change in size? Idk.
WHITE is offline   Reply With Quote
Old 08-28-2013, 02:20 PM   #25
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Did you verify the speedo with the oem wheels before the swap?
Most speedometers read 2%-5% faster than what you're actually going (my truck is 8%) which would also explain the optimistic mpg readings, with a larger tire spinning at the same rpm as the old small tire the overall vehicle velocity will be faster with the larger diameter tire, basically covering the built in compensation with the speedo.
The computer has no fucking idea what diameter your wheels are, it's just looking at the final drive speed is coming out of the transmission. Most wheel swaps aren't big enough to matter especially given most areas plus or minus 5 mph isn't a big deal.
Also larger diameter wheels are basically adding gearing which lowers rpm and improves fuel economy. Not accounting for the weight gain.
ineedyourdiddly
Old 08-28-2013, 04:33 PM   #26
WHITE
Thats pretty neat
WHITE's Avatar
The 46.5mpg was just a one time thing with my 265's and i have not come close to getting that again, i tried hard to get the highest mpg i could on that trip. On my normal commute to and from work all highway i get 27mpg +/- 0.5 with my 265's. with my stock wheels and tires i was averaging 31mpg on the same commute.
I have no clue about the whole speedo crap, i didnt even know the speed sensor was in the diff(never cared to looked for it to be honest) all i know is yime and time again ive checked my speedo versus other speed read outs and so far the most its been off was a "your speed is" sign saying i was 1mph slower then my speedo. idk im not going to try and figure it out, im just gonna continue to drive, i dont care about mpg at all i fill up when i need to fill up and thats it.
Old 08-28-2013, 05:13 PM   #27
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by fistpoint View Post
Mine gets 127 mpg
...downhill
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 08-28-2013, 05:26 PM   #28
meadowz06
THE CORVETTE KING!
meadowz06's Avatar
Drives: 2013 FR-S, and 2016 FR-S!
I don't. I get 26 mpg in my 560hp supercharged Corvette on the freeway!
meadowz06 is offline   Reply With Quote
Hybrid power Perihelion Other Vehicles & General Automotive Discussions 6 06-28-2013 08:28 AM
My new plug-in hybrid fr-s t88supra Scion FR-S / Toyota 86 GT86 General Forum 7 06-16-2013 03:46 PM
GT 86 Hybrid. Would you? russv Scion FR-S / Toyota 86 GT86 General Forum 74 03-13-2013 03:31 PM
FT-86=Hybrid?!? Please say it ain't so... BoostJunkie Scion FR-S / Toyota 86 GT86 General Forum 60 08-31-2010 09:38 PM
Is it the LFA HYBRID?? Dark Other Vehicles & General Automotive Discussions 6 04-27-2010 09:37 PM
