#71 |
Grip>Slip
#72 |
Drives: 2018 BMW M2
04/13 build date and I just noticed the drivers side is not lined up.
#73 |
Unemployed DIY Ninja
Drives: 2013 SWP BRZ, 1983 MB SD300
You never took off your bumper? It came that way?
2013 SWP Subaru BRZ - Panda'd
FS: BNIB WORK 11R 17x9 +38 [Custom] 5x100 PCD [Custom] 56.1 Bore |
#74 |
Ugh my low pitch hella horn went out... I have to remove the fucking bumper again. I hope I can line it up right
#75 |
Drives: 2018 BMW M2
#76 |
print out the tsb* and go throw a shit at the dealership
FS: BNIB WORK 11R 17x9 +38 [Custom] 5x100 PCD [Custom] 56.1 Bore Last edited by Perihelion; 06-25-2013 at 03:45 PM. |
| The Following User Says Thank You to Perihelion For This Useful Post: | ML (06-25-2013) |
#77 |
Grip>Slip
#78 |
Well I may or may not have done something stupid. I bought the new revised bumper brackets from Subaru today. But I own a frs. Is that the wrong parts for my car
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#79 |
Drives: 2013 FR-S Matte Orange
The brackets are likely the same. I hope this fix actually works.
#80 |
note the new tsb brackets didn't do shit. because the tabs on the bumper the closest one to the headlight is all wore out. I had to cut off tabs of bumper bracket and make my own.
#81 |
Grip>Slip
#82 |
yes I cut off the factory tabs and use some tabs from shelf hanging stock. the driver side worked perfectly but the passenger side new tab ripped the tab on the bumper so now it will never fit. so I don't see this as a viable solution. I also copied the bumper tabs on paper for a template to cut out of sheet aluminum and glued that to the underside of the tabs on the bumper but the added aluminum wouldn't allow the bumper to push in. honestly the design from the factory is pure lazy shit. I have been installing and uninstalling factory bumpers at body shops for years. This is one of the worst. I mean wth the car is a year old and bumpers don't line up. ![]() so at this point I don't know what to do. People look at my engine bay and are amazed. And the next sentence out of their mouth is "what happened to your bumper"
#83 | |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
really? tried it and it worked for you? if so I have to order me some |
#84 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | 448hpsti (08-27-2013) |
| Bumper and fender damage - Hit and Run | 01s0uljah | Cosmetic Modification (Interior/Exterior/Lighting) | 40 | 12-24-2016 01:44 PM |
| Worn floor mats - Covered under bumper to bumper warranty? | Philly758 | Issues | Warranty | Recalls / TSB | 45 | 08-19-2013 01:32 PM |
| Where to Buy Fender badges and bumper V light?? | taimysho0 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 05-17-2013 04:31 AM |
| WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement | mariolefty1 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 05-06-2013 04:52 PM |
| Need scratches/scuff marks buffed out of bumper or cheap bumper for sale | [Cyanide] | NY / NJ / CT / PA | 12 | 12-28-2012 07:34 PM |
