Old 08-25-2013, 03:25 PM   #29
John.Hong
John.Hong's Avatar
Drives: 2013 Ultramarine Frs
Originally Posted by denkigrve View Post
If you lower you'll get some negative for free anyway. Depending on the drop it shouldn't be too super pokalicious.
Only the rears gets natural camber. The fronts won't.
John.Hong is offline   Reply With Quote
Old 08-26-2013, 02:56 PM   #30
lp87
Drives: 2013 swp brz
Originally Posted by lp87 View Post
anybody?
noobody??
lp87 is offline   Reply With Quote
Old 08-26-2013, 04:11 PM   #31
Chase Bays
Chase Bays's Avatar
Drives: FR-S | 335i | S13
I run 18x9.5 +30 all around on our FR-S and love it. I just tracked our car at Barber Motorsports Park too and it was amazing. No understeer and no excessive oversteer.
Chase Bays is offline   Reply With Quote
The Following User Says Thank You to Chase Bays For This Useful Post:
John.Hong (08-26-2013)
Old 08-26-2013, 04:32 PM   #32
camelflage
Drives: pinto power
9.5 square on rpf1s as well, 225/40 federals and it feels great.. plenty of room.
camelflage is offline   Reply With Quote
Old 08-26-2013, 04:42 PM   #33
John.Hong
John.Hong's Avatar
anybody?
You should be fine. You will need camber plates up front and possibly LCA for the rear. Depending on if you're trying to go low or not you wont need fender mods much if at all, and your fender lining might get slightly rubbed but not much at all.
Old 08-26-2013, 06:34 PM   #34
lp87
Already have whiteline top hats so front camber should be fine. Only really worried about inner clearance that's why i'm hesitant to go above 42 offset, especially with a 255/35
Old 08-26-2013, 08:07 PM   #35
John.Hong
John.Hong's Avatar
Yeah i didn't want to go above 40 so i went with 35 all around lol. I think i only rubbed fender liner when i had installed 255/40 tires on. I quickly changed to 35 profile tires and i was fine. No rubbing.
Old 08-26-2013, 08:27 PM   #36
lp87
Yea gotcha. Get some more pics mang! And a ground to subframe measurement. Looks great
Old 08-26-2013, 08:34 PM   #37
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
All great info this really helps for my choices on wheels to order to.
Something I didn't ask and should have is WHAT camber you guys running ft & back with 9.5 and approx how much lower then stock all way around?
Old 08-26-2013, 08:35 PM   #38
OICU812
Just a dude
OICU812's Avatar
That looks damn good what could you on?
Old 08-26-2013, 08:36 PM   #39
John.Hong
John.Hong's Avatar
Thanks! I'll try. Ground clearance is definitely not an issue. I kept it as functional as i could whilst looking good
Old 08-26-2013, 08:49 PM   #40
John.Hong
John.Hong's Avatar
Something I didn't ask and should have is WHAT cber you guys running ft & back with 9.5 all way around?
with 9.5 and 255 tires i had to max out my camber plates at -3 up front. The rears just have natural camber because double wishbone which set at -2.5. I could probably back out the camber plates to be at -2.5 in the front to look a little more aesthetically pleasing but I MIGHT have rubbing issues.
Old 08-26-2013, 08:53 PM   #41
OICU812
Just a dude
OICU812's Avatar
Holy shit -3 wow ok.... I'm assuming you're really low? I was only thinking of 1-1.25" lower then stock.
Old 08-26-2013, 09:01 PM   #42
John.Hong
John.Hong's Avatar
No im not low at all. Im porbably like 1.5 lower than stock. Mind you I am on 18s as well. and 9.5 +35 offset pokes alot upfront lol
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 01:15 PM
Wheel + Suspension Question 18x9 +40 225/40/18 Front 235/40/18 Rear Asphalt~86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-10-2013 07:34 PM
anyone running 18x9 front and 18x10 rear? YDNA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 05-06-2013 12:55 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
For those running 18x9.5 all around empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 11-17-2012 11:10 AM
