#43 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Just ordered my 4.56 final drive from Weir Performance. Should be here by the end of the week!!!
#44 |
degrees
Drives: 6MT BRZ
Here's the list I compiled with help from @Jeff Lange describing what all I'd need. Part numbers are on me so if anyone finds an error, please let me know so I can correct the list.
90179-20018 ... Pinion nut 90311-38070 ... Pinion seal 41231-24010 ... Pinion spacer 90366-35133 ... Pinion bearing* 90311-43009 ... Side seals (x 2) 41222-22010 ... Ring gear lock tabs (x 5) 12157-10010 ... Drain bolt gasket SU003-00122 ... Fill bolt gasket (listed above) ... Pinion bearing shims (listed below) ... Diff washers** *Note 1: Pinion bearing can potentially be reused if you or your shop has the removal tool and your bearing is still in serviceable condition. Replacement is recommended but not mandatory depending on these conditions. **Note 2: Side washers might be needed depending on the new ring/pinion tolerances. If anyone has any input on this, please add to the discussion. Diff washers in order of thickness: 90201-52001 ... T=2.58, MARK 01 90564-46014 ... T=2.60, MARK 32 90564-46015 ... T=2.62, MARK 33 90201-52003 ... T=2.64, MARK 03 90564-46016 ... T=2.66, MARK 34 90564-46017 ... T=2.68, MARK 35 90201-52005 ... T=2.70, MARK 05 90564-46018 ... T=2.72, MARK 36 90564-46019 ... T=2.74, MARK 37 90201-52007 ... T=2.76, MARK 07 90564-46020 ... T=2.78, MARK 38 90564-46021 ... T=2.80, MARK 39 90201-52009 ... T=2.82, MARK 09 90564-46022 ... T=2.84, MARK 40 90564-46023 ... T=2.86, MARK 41 90201-52011 ... T=2.88, MARK 11 90564-46024 ... T=2.90, MARK 42 90564-46025 ... T=2.92, MARK 43 90201-52013 ... T=2.94, MARK 13 90564-46026 ... T=2.96, MARK 44 90564-46027 ... T=2.98, MARK 45 90201-52015 ... T=3.00, MARK 15 90564-46028 ... T=3.02, MARK 46 90564-46029 ... T=3.04, MARK 47 90201-52017 ... T=3.06, MARK 17 90564-46030 ... T=3.08, MARK 48 90564-46031 ... T=3.10, MARK 49 90201-52019 ... T=3.12, MARK 19 90564-46032 ... T=3.14, MARK 50 90564-46033 ... T=3.16, MARK 51 90201-52021 ... T=3.18, MARK 21 90564-46034 ... T=3.20, MARK 52 90564-46035 ... T=3.22, MARK 53 90201-52023 ... T=3.24, MARK 23 90564-46036 ... T=3.26, MARK 54 90564-46037 ... T=3.28, MARK 55 90201-52025 ... T=3.30, MARK 25 90564-46038 ... T=3.32, MARK 56 90564-46039 ... T=3.34, MARK 57 90201-52027 ... T=3.36, MARK 27 90564-46040 ... T=3.38, MARK 58 90564-46041 ... T=3.40, MARK 59 90201-52029 ... T=3.42, MARK 29 90564-46042 ... T=3.44, MARK 60 90564-46043 ... T=3.46, MARK 61 90201-52031 ... T=3.48, MARK 31 Last edited by 37; 08-26-2013 at 03:52 PM. |
| The Following 10 Users Say Thank You to 37 For This Useful Post: | Anthony (08-26-2013), enjoyminutemaid (06-02-2014), Fly Guy (04-22-2014), GT86_PRAGUE (01-06-2015), jcw99 (03-06-2016), misooscar (08-25-2015), Mr. (10-12-2013), mtsui (08-27-2013), RehabJeff86 (12-05-2013), Toyota86.ir (10-10-2015) |
#45 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Very nice!
I wish I was awesome enough to quote people from the future.
| The Following User Says Thank You to Anthony For This Useful Post: | Dustin (08-26-2013) |
#46 |
Twin Screw You
It's a gift. Lol, yeah I just copied and pasted from where he posted in another thread. Sorry bout that. Thanks for the great info @37!!
| The Following User Says Thank You to Dustin For This Useful Post: | Anthony (08-27-2013) |
#47 | |
Drives: 86
I didn't count how many seals it came with. It was in a small clear bag that I was afraid to open. The install is done but I am on business trip and will not be able to get the car until Thursday when I am back home.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#48 |
Drives: 86
I don't believe this mod will add anything in term of HP. It will just help the car accelerate faster.
#49 | |
Drives: 86
![]() By the way my car is AT
#50 |
Drives: 86
Just drove my car around the block. Difinitly accelerate better. Mostly in 1-3 the gears are shorter than before. My guess, is gears became like MT from 1-3. Need to drive it on the high way to test 4-6 gears. I am very satisfied with this change.
Sent from my iPhone using Tapatalk - now Free
#51 |
Twin Screw You
Just got my Weir Performance 4.56 final drive and solid pinion spacer. He supplied shims for both. I'm going to buy a few more things before installing it but we've purchased from Weir before and his products are top notch!! We have his axles, final drive, and solid pinion spacer in my brother's AE86. Anyone wanting to do this mod should definitely get in touch with him. Everything for well under $400 shipped and I received it in 2 days!!!
| The Following 12 Users Say Thank You to Dustin For This Useful Post: | 8686 (08-31-2013), Anthony (08-31-2013), Carlitoz3 (02-07-2016), DAN_BRZ (12-05-2013), GT86_PRAGUE (01-06-2015), jcw99 (03-06-2016), JiB (08-31-2013), JimmyMac (08-31-2013), leon78 (09-01-2013), number1Tango (10-11-2014), RehabJeff86 (12-05-2013), Toyota86.ir (10-10-2015) |
#52 |
Weight Nazi
Very nice.
| The Following User Says Thank You to Anthony For This Useful Post: | Dustin (08-31-2013) |
#53 |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
Damn. Nice.
| The Following User Says Thank You to 448hpsti For This Useful Post: | Dustin (08-31-2013) |
#55 |
Twin Screw You
That's one of those things I still have to buy. I'm gonna get the pinion bearing, pinion seal, and a few other things.
| The Following 2 Users Say Thank You to Dustin For This Useful Post: | 37 (08-31-2013), RehabJeff86 (12-05-2013) |
#56 |
In Test:Oil Fed SC
if youre careful and low miles shouldnt be an issue if youre delicate with the press!
| CUSCO 4.55 FINAL DRIVE installed. | Racecomp Engineering | Engine, Exhaust, Transmission | 489 | 06-17-2018 12:14 AM |
| Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 02:21 AM |
| Final Drive Calculations | wootwoot | Engine, Exhaust, Transmission | 34 | 12-19-2014 04:06 AM |
| Anyone w/ 3.727/3.909 Final Drive Post Boost? | Staf00 | Engine, Exhaust, Transmission | 12 | 05-02-2013 08:38 PM |
