Old 08-26-2013, 07:57 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Who makes the best value performane guages?
Looking for an accurate oil pressure gauge that isn't $200. The cheap mechanical one I have isn't working well.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 08-26-2013, 08:29 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
AEM has some good ones. MSRP is 210. You can probably find them cheaper.
http://www.aemelectronics.com/gauges...l-pressure-46/
Old 08-26-2013, 09:24 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, yes indeed you can get it cheaper and ready to tap into the block!
@brillo
FS: Oil Pressure gauge
Old 08-26-2013, 09:29 AM   #4
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
really digging the MTX line from Innovate, when you look at the 2 gauges in 1 thing the cost is justified
448hpsti is offline   Reply With Quote
The Following User Says Thank You to 448hpsti For This Useful Post:
xjohnx (08-26-2013)
Old 08-26-2013, 09:50 AM   #5
brillo
I'm using a scangauge for oil temp, water temp, IAT and ignition so really I just need a reliable electronic oil pressure gauge.
Sportsguy83, thank you for your help this weekend with my questions, your AEM gague is a litte out of my price range ~$100 and I already ordered the galley plug but I appreciate the offer.
The Following User Says Thank You to brillo For This Useful Post:
Sportsguy83 (08-26-2013)
Old 08-26-2013, 10:55 AM   #6
Sportsguy83
Drives: Limited BRZ
PM'd
Old 08-26-2013, 03:22 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This is your classic pick 2:
1. Accurate
2. Cheap
3. Reliable
themadscientist (03-04-2015)
Old 08-26-2013, 03:24 PM   #8
brillo
1. Accurate
2. Cheap
3. Reliable
I guess I find it hard to believe you can't find all three in one gauge for less than $100.
Old 08-26-2013, 03:27 PM   #9
qoncept
qoncept's Avatar
1. Accurate
2. Cheap
3. Reliable
It's also a great setup to only end up with 1 or 0.
A "cheap" gauge (say, under $50-150) should be just as accurate and reliable as "expensive." It's not until you get to "dirt cheap" that they're truly junk.
Autometer has been used forever and is as accurate and reliable as you're going to need. But they're ugly.
qoncept is offline   Reply With Quote
Old 08-26-2013, 03:34 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You can get a half sweep electrical Autometer for around $70, but that only satisfies Cheap and Reliable. I have no issues with Autometer gauges. I just find they look more at home in American muscle.
Old 08-26-2013, 03:35 PM   #11
topazsparrow
Drives: slow
Why hasn't anyone mentioned using Torque Pro?
If you've got a tablet or android phone, it's 5 bucks for the app... It's going to be as accurate as the sending unit that comes with the car.
topazsparrow is offline   Reply With Quote
Old 08-26-2013, 03:38 PM   #12
Sportsguy83
Drives: Limited BRZ
Because the OEM oil pressure sensor is not truly a range sensor, only sends one signal low pressure and when that low signal is sent, its already too late to save the engine. He wants a sensor with certain range (say 0-100 psi).
The Following User Says Thank You to Sportsguy83 For This Useful Post:
topazsparrow (08-26-2013)
Old 08-26-2013, 03:39 PM   #13
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
are p3cars gauges worth the money?
86_ZN6 is offline   Reply With Quote
Old 08-27-2013, 09:38 AM   #14
brillo
what are the specs of the idiot light anyways? how low does pressure have to fall for it to go off?
Can you tell me who makes this wing? bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 11 02-02-2014 09:02 PM
Who makes 2.75 front pipes? Hawk77FT Engine, Exhaust, Transmission 10 07-02-2013 07:37 PM
Right gas makes big difference Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 33 06-22-2013 06:03 PM
Anyone know who makes this wing? deadsailor86 Cosmetic Modification (Interior/Exterior/Lighting) 13 01-11-2013 08:38 PM
Who makes this front lip? green_comet Cosmetic Modification (Interior/Exterior/Lighting) 6 10-25-2012 09:01 PM
