Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 04-15-2013, 11:40 AM   #155
Kagetsu
Drives: 86 GTS
Thought I'd chime in, as I've also done an install (or rather, had one done, because I'm a dunce when it comes to some of these things) on my 86 by the boys at PAC here in Melbourne.
They haven't got all the pictures up, but this weekend, I'll take a few photo's and upload them so people can see the work (top notch).
For those interested:
http://www.facebook.com/media/set/?s...4570380&type=1
Installed are Polk Momo MM6's 6.75" 2 ways in the front (MM6's) powered by a focal FP2.150, and the sub is a Phoenix Gold Sl12 powered by an Phoenixgold SD300.1 installed into the wheel well (as my car didn't come with a wheel). Head unit is currently stock, though that may change in the coming weeks. For sound quality up to about half way, it's excellent, and slightly let down by the head unit when pushing it to ear bleeding levels.
With the exception of the focal amp for the splits, and the speaker grill on the sub, there is no practical loss of room and usability of the car.
I will say one thing, and this is coming from a Liberty as my previous car, the sound system in the standard toyota is pretty sub par. The Liberty is no slouch, but there was zero impact on the audio in the 86, to the point where I'd rather drive with headphones in.
Highly recommend the PhattAudio guys here too.
Kagetsu is offline   Reply With Quote
The Following User Says Thank You to Kagetsu For This Useful Post:
fuddbutter (05-27-2013)
Old 04-28-2013, 07:30 PM   #156
ckcrown84
Not seeing a lot of posts about how to fix the rear brake light rattling without removing it... any suggestions? Please PM me if I have missed some threads please provide me with link
ckcrown84 is offline   Reply With Quote
Old 05-26-2013, 10:58 PM   #157
Ben Stef
Ben Stef's Avatar
Drives: Toyota 86 GT
Originally Posted by Alfalasy View Post
Looks great!
Are you using the built-in USB/Aux plugs/connectors with the DDX630WBT to connect to iPhone. Because it requires AV input cable and USB. Did you modify it to work. Update: I've checked the manual and there are two cables AV in and USB, I think they fit in the same slots
I think this unit is still not compatible with iPhone 5 but will try to use the converter
No its not compatible w/ iphone 5 but i just use my 160GB ipod anyway. works perfectly with my iphone 5 over bluetooth, cannot tell the difference in quality at all.
2012 Toyota 86 GT Thunder Silver
Ben Stef is offline   Reply With Quote
Old 05-27-2013, 02:04 AM   #158
2SeeKU
Drives: Raven GT86 & Subaru WRX CS6
Originally Posted by Ben Stef View Post
Did a full focal rebuild of my sound system.
Head unit: Kenwood ddx630wbt with Garmin sat nav module
Front: 6.5" Focal KRX2 components
Rears: didn't bother replacing
Sub: Focal 27KX in custom fiberglassed box
All powered by a focal amp
Sounds so clean and crisp
Attachment 16553
Hey mate,
I've got the same headunit, what Sat nav unit are you using?
Thanks!
2SeeKU is offline   Reply With Quote
Old 05-27-2013, 02:09 AM   #159
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
Works perfectly with my Girlfriends through the USB port, so I don't know what's wrong with yours.
Gir is offline   Reply With Quote
Old 05-28-2013, 11:49 PM   #160
Paragon
Guest
Posts: n/a
so just to check with those who have installed an amp and aftermarket HU, the blue wire from the loom which is the remote power line needs to be hooked up to both the amp (remote power in) and the power antenna?
Old 06-03-2013, 02:39 AM   #161
Ben Stef
Ben Stef's Avatar
The ipod cord is a 30 pin not lightning is what i meant
Old 06-03-2013, 09:37 PM   #162
Gir
Gir's Avatar
You don't need the Kenwood iPhone cord at all. Just plug the standard iPhone USB cable (30 pin, or lightning, doesn't matter) into the headunit USB port, and it will work perfectly, and automatically go into iPod mode.
Old 06-04-2013, 08:18 AM   #163
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
has anyone put subs where the rear seats go? id like to do this soon.
NYCsubaruBRZ is offline   Reply With Quote
Old 08-24-2013, 04:52 AM   #164
Yich
I'd like to hijack this thread to give another thumbs up to Rodney, Melou and Alex's Team at Lifestyle store, very happy with my new setup.
Absolutely no regrets heading there after seeing this thread at these forums.
The system includes the following:
Eclipse AVN827GA head unit (This was factory fitted and had a camera installed with it as I never thought I'd be modifying the car until missing sections of the music annoyed me)
The modified system as listed on the receipt follows:
Audison Bit ONE DSP $1049
Audison AV5.1K Voce 5 Channel Amp $1599
Audison AV bit IN Voce Amp Digital Input $179
Hertz HSK163 3-way split system $799
Hertz Dcx100 4" 2-way coaxial speakers $49
Hertz HX250D 10" Subwoofer $340
Focal Ek35 2 Gauge Wiring Kit Elite $399
Focal Bam XXXL Soundproofing sheet/foam $329
Installation 4 Channel Amp $140
Installation Carpet Amp Rack $140
Installation 3-way Component speakers $300
Installation Rear Speakers $90
Installation Sound Deadening $200
Installation Custom Fibreglass Subwoofer Enclosure $990
Installation DSP tuning $300
After discounts this came to $6700 and was finished in a week.
This is a complete stealth installation that does not reveal anything at first glance with all speakers in factory location.
The bit ONE is under the driver's seat with USB cable hidden there as well for easy access to programming.
The spare alloy wheel that comes with the Australian BRZ was flipped upside down with the subwoofer mounted in the space underneath the flipped wheel and after the factory wheel cover is thrown over it, the wheel acts as a very good grill with enough space under it for the subwoofer to throw and surprisingly enough allowed for a perfectly sized enclosure as prescribed by the Hertz tech sheet. This meant that neither sound nor available boot space was compromised.
The Amplifier was mounted on a carpeted board installed on the rear of the back seats and still allows the seats to be opened level with the boot.
The DRC for the bit one was mounted nicely next to the stock USB plug on the center console and is level with the push start button which ended up looking very sleek and lets me turn off the subwoofer at will.
Custom mounts were manufactured for the front mid range and tweeters with custom mounts for the rear speakers as well.
Sound quality at the volumes I listen to is excellent with crystal clear highs and mids with none of the harshness or muddiness of the stock speakers.
Furthermore I was surprised at how detailed the previously missing mid bass section ended up being with the subwoofer also playing so low that the subwoofer could be felt even though I play my music far below speaking level and apparently since these are brand new speakers and haven't been run in yet they'll sound even better in 30 hours of play time when I'm due for my follow up DSP tune.
So if anyone wants a very high quality install in Sydney's Western suburbs I recommend the Lifestyle store, pictures of the install will be uploaded as soon as Rodney sends me the photos from his phone.
Yich is offline   Reply With Quote
The Following User Says Thank You to Yich For This Useful Post:
Skorov (09-01-2013)
Old 08-25-2013, 10:03 AM   #165
ZZT86
ZZT86's Avatar
Drives: BR86
I'm sure it's nice yich but that's a lot of coin :/
ZZT86 is offline   Reply With Quote
Old 08-26-2013, 05:39 AM   #166
Yich
Worth every bit of it as I still have quite a bit left over to mod this BRZ to have at least the comfort of a 370z, since I had the money and targeted that originally. I don't need the power. Next things to go in will be an STI flexible tower brace and flexible draw stiffener then I need to research on what other suspension parts i'll need to improve the ride further.
Old 08-26-2013, 06:22 AM   #167
ZZT86
ZZT86's Avatar
Drives: BR86
Interesting Do you know what you can get the BitOne on its own for ?
Old 08-26-2013, 07:49 AM   #168
Yich
Around $800 used according to Amazon and it's official Australian RRP is $1149, but since I needed someone local to install it, Life Style are really the only people in my area plus they offer lifetime warranty on their installs so if anything were to go wrong with it as early internet threads about the bit one were any indication, they'll fix it.
purchasing area 86 stuff pkptd447 Scion FR-S / Toyota 86 GT86 General Forum 7 08-15-2014 03:09 PM
Help Me Get This Stuff OFF!!! wootwoot Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 09-07-2012 11:38 AM
Any more cool stuff? Davyator Scion FR-S / Toyota 86 GT86 General Forum 21 05-24-2012 04:28 PM
More HKS stuff! uspspro Engine, Exhaust, Transmission 0 04-25-2012 01:27 PM
Dimman's technical stuff. Dimman Other Vehicles & General Automotive Discussions 74 10-17-2011 02:15 PM
