#15 |
Drives: UK GT86
MFactory popped over to our UK site. For those interested, they said they would make the Cusco ratio if enough people were interested. So 4.56 for the same or possibly cheaper as their other FDs
.: Stealth 86 :.
#16 |
Drives: 2013 FR-S, 2016 Miata Club
Yeah, I was over there reading your site, I think. MFactory mentioned that the 4.44 ratio was a custom ratio for a customer in Japan. Could you ask them about a shim kit for their gears? That would be much appreciated. Thanks.
#17 |
Drives: UK GT86
That's right, the 4.44 was originally a custom ratio. Just drop them a mail about the shims although my guess would be that they would recommend an OEM kit.
.: Stealth 86 :.
#18 |
Lexus is300 with a manual tranny is usually a 3.73 gear set. That's the one I'm on the hunt for.
#19 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I've been wanting a 4.67 ever since I knew it was available, but I don't know anything about installing a final drive. What is all this shim nonsense?
Are ya'll saying that if you were to only buy a final drive you wouldn't be able to install it? I figured it would come with everything needed. Is it because they're older FDs that weren't necessarily designed for our cars? Maybe even universal ones?
| The Following 2 Users Say Thank You to Anthony For This Useful Post: | liquidsky44 (08-31-2013), mike_ekim1024 (09-11-2013) |
#20 |
The shims are needed to get the correct backlash in the gears. If you don't it could be too tight are too loose and result in heavily worn out gears or eating the teeth right off.
#21 |
Weight Nazi
A quick search seems like they'd cost about $10-20. Does that sound right?
https://www.google.com/#fp=3869f80cf...shims&tbm=shop
#22 | |
http://www.nissanpartszone.com/parts...129-61001.html |
| The Following User Says Thank You to JimmyMac For This Useful Post: | Anthony (08-25-2013) |
#23 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
http://www.villagescionparts.com/sho...rchString=shim
Part - 41201D Tried my best to read the numbers on this blurry pic. Quote:
Numbers - 90201 35497 - 1.70 90201 35498 - 1.73 90201 35499 - 1.76 90201 35500 - 1.79 90201 35501 - 1.82 90201 35502 - 1.85 90201 35503 - 1.88 90201 35504 - 1.91 90201 35505 - 1.94 90201 35506 - 1.97 90201 35507 - 2.00 90201 35508 - 2.03 90201 35509 - 2.06 90201 35510 - 2.09 90201 35511 - 2.12 90201 35512 - 2.15 90201 35513 - 2.18 90201 35514 - 2.21 90201 35515 - 2.24 90201 35516 - 2.27 90201 35517 - 2.30 90201 35518 - 2.33
#24 |
Drives: 2013 Raven FRS MT
Looking for a 373 gear myself before I go FI. If anyone does a group buy once a 373 is found. You can count me in. I will be on the hunt for some 373s.
#25 |
Drives: 86
I got this from our local Toyota dealer for 450 $.
http://www.ft86club.com/forums/showp...1&postcount=34 Will be in my car by Thursday.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
| The Following 2 Users Say Thank You to 8686 For This Useful Post: | jcw99 (03-06-2016), RehabJeff86 (12-05-2013) |
#26 | |
Twin Screw You
Nice!! The OEM 4.56. Let us know how you like it!! Here is a list of OEM part numbers for those that want different options I found in another thread. Not 100% sure is these work in our cars. Just info I found on the interwebz. 41201-80125 : 3.58 41201-80050 : 3.73 41201-80052 : 3.91 41201-19605 : 4.10 41201-29606 : 4.30 41201-19557 : 4.56
| The Following User Says Thank You to Dustin For This Useful Post: | RehabJeff86 (12-05-2013) |
#27 | |
Drives: Firestorm 86
#28 |
Drives: Scion FR-S A/T, Whiteout
So I'm taking this a step further and I got a whole new carrier out of an IS300, which I am then going to install my final gear into.
The reason I bring it up is that Spence over at Weir Performance (http://weirperformance.com/) sells gear kits for the mark 3 Supra, which he knows to be compatible with the IS300 carrier (he's sold them to a bunch of IS owners looking to do final gear swaps). Seeing as the IS300 carrier is a direct swap into our cars, I would think these final gear kits would be swappable into our carriers as well. It's like that one mathematical property... if A = B and B = C, then A = C. ![]() Take this with a grain of salt though. I've not tried taking one of these final gear kits for a Supra and installing it in our carrier; my plan is to install it into an IS300 carrier, which is known to work. Maybe @Jeff Lange could shed some more light on this issue? |
| CUSCO 4.55 FINAL DRIVE installed. | Racecomp Engineering | Engine, Exhaust, Transmission | 488 | 06-17-2018 12:14 AM |
| Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 02:21 AM |
| Final Drive Calculations | wootwoot | Engine, Exhaust, Transmission | 34 | 12-19-2014 04:06 AM |
| Anyone w/ 3.727/3.909 Final Drive Post Boost? | Staf00 | Engine, Exhaust, Transmission | 12 | 05-02-2013 08:38 PM |
