Old 08-24-2013, 09:19 PM   #15
DJCarbine
Thupercharged
DJCarbine's Avatar
My ark testpipe stays at 2.5 inch and uses a different donut gasket than stock FWIW
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 08-24-2013, 10:10 PM   #16
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
I've noticed that on mine too. But it's getting switched out with the P&L catted front pipe which is 2.5 all the way thru and uses a gasket instead of a donut. I'm switching because I'm going catless on the header.
JimmyMac is offline   Reply With Quote
Old 08-25-2013, 10:23 AM   #17
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by RiskyTrousers View Post
Does anyone not mind all the vendors advertising a 2.5" frontpipe, yet they fail to mention the 2.2" bottleneck?
I was pretty disappointed when I got my over/frontpipe to see this horrible and abrupt step down to 2.2", not to mention the craptacular fitment.
Anyway, doesnt seem like any shop is making a proper full 2.5" system, they're just letting people assume thats what they're getting. All about the $$$ I guess.
I'm pretty sure the are a few vendors that don't use a 2.2" insert at the midpipe/overpipe.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 08-25-2013, 10:26 AM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
i wonder who?
Old 08-25-2013, 10:34 AM   #19
Apoc
Apoc's Avatar
Originally Posted by whitefrs View Post
i wonder who?
Perrin?
“The World is Flat”
[||•]=(86)=[•||]
Old 09-17-2013, 10:43 AM   #20
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by sw20kosh View Post
Sadly i just pulled off my stock catback to find my nameless frontpipe looks Exactly like that pic. I measured the ID at 2.25" (with calipers). It looks like there is enough room to cut off the pinch section just inside the flange face with a dremel from inside the pipe. The weld on the flange is on the forward side of the pipe.... bummer... will see how my speedfactory midpipe looks when it get here latter today then decide to cut or not
Old 09-17-2013, 11:11 AM   #21
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Hmm I have the Perrin Catback and a fa20 front pipe on the way. The perrin system does not use the gasket. Not sure if the fa20 pipe needs the donut gasket or not.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-17-2013, 12:59 PM   #22
sw20kosh
Drives: 2013 Black FR-S
Yep we dremeled and ripped that sucker out of there. You can still use the donut gasget without that piece.
Old 09-19-2013, 07:40 PM   #23
mad_sb
I had the neck down seciton removed from my nameless today. Also had them replace the bellmouth on the ft86speedfactory midpipe with a regular 2 bolt flange..... I didn't realize they weren't going to butt-weld the new pipe section on the midpipe till they had already slipped the new pipe over and welded it on... So, i had the guy run a bead on the inside of the flange and grind down the lip to make a smooth transition.....
Not sure why they did it that way after i explained exactly what i wanted and why, i even make a drawing for them to explain it all..
anyway... it's good enough i suppose.
Old 09-19-2013, 07:55 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Nice effing drawing!!
Old 09-19-2013, 08:36 PM   #25
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Good work
448hpsti is offline   Reply With Quote
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Agency Power over-pipe/front pipe combo question... seven Engine, Exhaust, Transmission 11 01-13-2013 12:14 PM
