Old 08-24-2013, 08:08 PM   #15
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Back to 11.2
Thanks @Sportsguy83
Sent while popping Mollys
The Following User Says Thank You to whitefrs For This Useful Post:
Sportsguy83 (08-25-2013)
Old 08-24-2013, 08:11 PM   #16
Dipstik-sportech
Dipstik-sportech's Avatar
What was the fix? I think my car is doing the exact same thing
Old 08-24-2013, 08:22 PM   #17
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
my pump wasnt sitting right
i got white collar and 2 orings and the canister closed good
Old 08-25-2013, 12:17 PM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Did some pulls yesterday and my afr was perfect at WOT
Now again they went up 2 points, its 13.2
What could the problem be?
Old 08-25-2013, 12:28 PM   #19
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The fuel pump is moving around inside the canister after using the car a bit.
Maybe O rings are bad? There's not much more that could be.
When you close the canister, do you have to push down really REALLY hard?
Also, if its the loose pump, you should see even higher AFRs on higher gears.
Old 08-25-2013, 12:31 PM   #20
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
nop it just snapped in place, no force at all
Old 08-25-2013, 12:34 PM   #21
Sportsguy83
Drives: Limited BRZ
When I finally solved my issues I had to push down HARD. As a last resort, you can drill small holes by the pins area and tie wrap it all tight, that way it has nowhere to move.
I find it so ODD that you have white spacer, 2 O rings, it snaps into place but still FP moves around. Look at the O ring condition. Maybe they've gone bad.
Old 08-25-2013, 12:35 PM   #22
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
o rings were perfect
I might removed the white collar and do 4 orings
Old 08-25-2013, 12:40 PM   #23
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I also don't have a FP filter as Visconti threw it out saying that I don't need it
Old 08-25-2013, 12:59 PM   #24
mad_sb
Drives: 2013 Asphalt FR-S
Maybee that is why your first pump failed, and this one is already acting up.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
Sportsguy83 (08-25-2013), xjohnx (08-25-2013)
Old 08-25-2013, 01:01 PM   #25
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
well
it works when I take it out and put It back on place, it maybe moved again.
where can I get this filters
Old 08-25-2013, 01:02 PM   #26
mad_sb
Could also be long term trims. I have verrified that the ecu WILL apply negative long term trims under wot. Would be worth it too take a quick log.
Also, as i mentioned, without the soc filter you may be sucking up some debris. Could be it is shifting around as mentioned, or maybee the R&R is clearing the inlet temporarily... i guess i would lean towards the pump shifting but still try and get a new soc... whomever makes the pump should be able to get you one.
The Following User Says Thank You to mad_sb For This Useful Post:
Old 08-25-2013, 01:06 PM   #27
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
will do
thx bud
Old 08-25-2013, 02:57 PM   #28
FA20Club.com
Drives: 2013 White Out FR-S
without the damn filter on the bottom the pump doesnt that added pressure pushing it up into the housing thats why your losing pressure and your assembly closed so easily wtf would run the pump without the inlet filter not to mention not measure the installed height of the pump assembly.
FA20Club.com is offline   Reply With Quote
The Following User Says Thank You to FA20Club.com For This Useful Post:
whitefrs (08-25-2013)
cowboys, fire_is_coming
Why does the fuel pump not do well with ethanol? boredom.is.me Engine, Exhaust, Transmission 42 02-28-2019 06:21 PM
FS: Visconti Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 0 03-31-2013 04:45 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
