Old 08-24-2013, 10:08 AM   #1149
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by jet86 View Post
I kinda have the kit.
this shud b interesting
and wheres ur battery??
lbroskee is offline   Reply With Quote
Old 08-24-2013, 01:43 PM   #1150
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by wrxgoose View Post
update for @DarrenDriven
edit: YES. I KNOW THE RPM ARE OFF BY 1K. IGNORE THAT. lol
I would love to but your torque and HP numbers are still crossing at 5225 which means whatever is wrong with your rpm could also be effecting other things, to put it bluntly theres no proof this isn't fabricated or "fixed" how ever you want to take that... Get another dyno.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 08-24-2013, 01:47 PM   #1151
wrxgoose
WUB WUB
Drives: 2013 Firestorm
i could go back to the dyno that showed me having 174 whp stock. I've been using this dyno since i started modding, and I'm sticking with it. I'll see if they can fix it, but i'm standing by my numbers until they tell me otherwise
wrxgoose is offline   Reply With Quote
Old 08-24-2013, 02:31 PM   #1152
Adeets
OEDC
Adeets's Avatar
K, no reason to change if you've been doing the same place the entire time, last couple Q's:
Who's your tuner
I'm taking it that that is e85?
Which pully/psi are you running?
Do you plan on going intercooler when it ships?
My BRZ FI Build
Old 08-24-2013, 02:49 PM   #1153
wrxgoose
WUB WUB
Who's your tuner
I'm using JR. (the guy who tuned the 12.4 second P&L car) @JuniorAWD
93 octane.
stock pulley (8.5 psi iirc)
and i do plan on getting the I/C when they release it, BUT! my friend has been in touch with some people, which means I could be getting an I/C sooner. More on that later, when I find out more
edit: and looking at the dyno sheet, that does kinda bother me about the RPM. Gotta see if they can fix that, or what's wrong with the dyno
The Following User Says Thank You to wrxgoose For This Useful Post:
lbroskee (08-24-2013)
Old 08-24-2013, 04:01 PM   #1154
Adeets
OEDC
Adeets's Avatar
93 octane.
So I read your build, and thruout your entire build on 93 your motor has been pumping some really high numbers, like with catback and intake you were pulling 200hp on 93, where most other users have to go e85 to get those numbers, very healthy motor, but your stock pulls were in line with expected. Your numbers are right along vortech pulls, I thought the stock innovate was ~7psi, not 8.5.
To sum this up, 92 has gotten me to 274 with my vortech, maybe I should stop being lazy and get tuned for 93. Also if your running 8.5psi unintercooled, I think I should try the 12.5 pully with 93.
My BRZ FI Build
Old 08-24-2013, 04:03 PM   #1155
Adeets
OEDC
Adeets's Avatar
With your new tune, how are you feeling safety wise, wouldn't happen to have IATs/oil temps would you?
My BRZ FI Build
Old 08-24-2013, 04:51 PM   #1156
wrxgoose
WUB WUB
unfortunately no.....actually, I may be able to go back to look at the log in a bit. bout to go have dinner with the girl. remind me later, and i'll see what i can find.
Old 08-24-2013, 04:54 PM   #1157
phloozy
phloozy's Avatar
Drives: Scion FR-S
I didn't want to say anything but I wouldnt compare dyno numbers. Every dyno is different and I have a feeling his reads very high, nothing wrong with that just dont use it to compare to your numbers. From what I am seeing even people with smaller pullies are barely reaching these numbers.
His build is nice though and I'm sure it feels amazing
phloozy is offline   Reply With Quote
Old 08-24-2013, 09:15 PM   #1158
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by xjohnx View Post
I seem to recall one tuner saying that it can read higher, however needs the MAP tables scaled higher. Maybe FA20Club.com moto-mike or DeliciousTuning can comment.
Even if we scale the stock values to read a little higher, it not only won't be accurate, but it will still not reach the full boost on the stock pulley. So no real benefit there.
The 3 bar MAP allows you to see real boost, we can then adjust timing for actual boost, and you won't need to re-flash for the smaller pulleys. For $108 it is not a hard choice...
In regards to the IC...I think it will be a necessity for folks in hot areas, but it won't be an easy fix for some.
1. It will be h20 to air, so it will heat soak for track days anyway
2. It may be a restriction. The laminova core is nice, but closer to blower redline I think we might see a drop-off. On E85 you're intercooling at the injector. The twin screw design will net temps about 20c lower than a PD blower anyway, so with DI especially, the IC may be redundant and extra complexity/restriction...at least for folks running e85.
Xero-Limit is offline   Reply With Quote
Old 08-24-2013, 10:35 PM   #1159
wrxgoose
WUB WUB
Thats why i think i may have a freak block, or could be becUse the tune. I dont know, i juat know what it shows. /Shrug
Old 08-24-2013, 11:16 PM   #1160
phloozy
phloozy's Avatar
Drives: Scion FR-S
pretty sweet
Old 08-24-2013, 11:19 PM   #1161
DriftEm
DriftEm's Avatar
what does a stock FR-S puts down on this dyno?
DriftEm is offline   Reply With Quote
Old 08-24-2013, 11:44 PM   #1162
wrxgoose
WUB WUB
i put 151
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
