Old 08-19-2013, 11:22 PM   #1
Pavel
Drives: Raven 2013 Scion FR-S
Question: Does anyone know what you need to do in order to have the front turn signals stay off when not in use? So the lights go on only when turn signals are used. I want to disable parking lights because I am planning on installing a LED strip and having stock parking lights and LEDs would be just too much for my taste.
Best Answer: There are three ways to do it:
1. Buy bulb 7440 that eliminates parking lights. Available in orange and chrome finish.
2. Cut connection clip on the existing light bulb. Cut the clip that connects to the green wire.
3. Cut the green wire connecting the light bulb (not recommended)
Thanks everybody for help!
Pavel is offline   Reply With Quote
Old 08-19-2013, 11:27 PM   #2
beaver_scott
beaver_scott's Avatar
Drives: 2013 FRS hot lava
Clip the parking light wire?
beaver_scott is offline   Reply With Quote
Old 08-19-2013, 11:39 PM   #3
Xanzent
Xanzent's Avatar
Drives: 2013 Scion FR-S Asphalt
Thanks in advance for help!
Sorry if this was already discussed, I spent a good amount of time searching for this without any results.
I went with switchback lights like these. I know it's not exactly what you asked for, but you get a cool white LED (6000k) instead of amber for parking lights, and then the normal (and legal) amber when used as turn signals.
Xanzent is offline   Reply With Quote
The Following User Says Thank You to Xanzent For This Useful Post:
Pavel (08-21-2013)
Old 08-19-2013, 11:52 PM   #4
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
This is possible just use the bulb the blinks not stays on. I cant remember 7440 maybe
FR-Shadow is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-Shadow For This Useful Post:
Pavel (08-21-2013), SkAsphalt (08-22-2013)
Old 08-20-2013, 12:25 AM   #5
retrosmiths
Drives: Scion FR-S Whiteout
Cut the green wires.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
The Following User Says Thank You to retrosmiths For This Useful Post:
Pavel (08-21-2013)
Old 08-21-2013, 10:43 AM   #6
Pavel
Cool, I'll try to either find that light bulb that doesn't stay on or I'll just cut the green wire. Thanks a lot!
Old 08-21-2013, 10:48 AM   #7
nalc
Drives: 13 BRZ Limited 6MT GBS
So you're just trying to eliminate the parking lights? Why?
nalc is offline   Reply With Quote
Old 08-21-2013, 11:32 AM   #8
retrosmiths
It's one bulb with three wires. Just cut the green one.
2013 Scion FR-S
Pavel (08-21-2013)
Old 08-21-2013, 03:46 PM   #9
Pavel
I'm going to install LED strip (the one sold by Zeta and several other suppliers). My plan is to use tinting foil to black out the turn signal and have LED only strip lights on, but have the original turn signal operational. IMO having LED strip and parking lights on at the same time will be just too much, so I want to disable them.
Sent from my Transformer TF101 using Tapatalk 4
Old 08-21-2013, 06:36 PM   #10
Hardrock4445
Hardrock4445's Avatar
LEAVE FACTORY WIRING ALONE!!!, just clip the metal tabs on the bulbs to the always on side. No damage to factory wiring and no buying bulbs! PM me with questions/help if you need it.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
The Following 2 Users Say Thank You to Hardrock4445 For This Useful Post:
mezdup (08-22-2013), SkAsphalt (08-22-2013)
Old 08-22-2013, 04:18 AM   #11
psk
Drives: scion fr-s
i wanted to change my turn signal bulbs to yellow, so i purchased single filament bulbs vs the dual filament factory bulbs. that way they only turn on when activating the turn signals.
psk is offline   Reply With Quote
Old 08-22-2013, 08:19 AM   #12
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
@Pavel
this or buy a pair of 7440 bulbs. avoid cutting factory wiring if you can. yes, it can be repaired, but why would you wanna deal with that?
also if you go the bulb-buying route, i recommend chrome ones as they look nicer: http://www.hidlightsusa.com/shopping...s&sc=7440/7443
mezdup is offline   Reply With Quote
The Following 2 Users Say Thank You to mezdup For This Useful Post:
Hardrock4445 (08-22-2013), Pavel (08-22-2013)
Old 08-22-2013, 10:42 AM   #13
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
+1 for getting 7440 bulbs. i never would want to cut factory wires. i replaced both sets of turn signals with led and the bulbs are the same size but the front ones have extra contacts on them that works for the parking light.
mrlewistan is offline   Reply With Quote
The Following User Says Thank You to mrlewistan For This Useful Post:
Pavel (08-22-2013)
Old 08-22-2013, 02:34 PM   #14
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
A couple smart people have responded here. Thank god
The Following User Says Thank You to SkAsphalt For This Useful Post:
wparsons (10-08-2013)
FS: White LED front turn signals Panda Grahams Exterior Parts (Aero, Lighting, Etc.) 6 05-28-2013 11:58 AM
smoked front turn signals dawnst3ar Cosmetic Modification (Interior/Exterior/Lighting) 20 05-21-2013 09:17 PM
DIY JWMotoring LED turn signals sirhc DIY (Do-It-Yourself) Guides 54 03-16-2013 04:22 PM
Eyebrow Turn Signals PhastekSport Cosmetic Modification (Interior/Exterior/Lighting) 11 01-28-2013 02:52 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-12-2012 12:23 AM
