Old 08-20-2013, 10:27 PM   #29
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by defylogik View Post
The tow hooks are "standard" Subaru. You can get used ones on ebay for under $10.
I've verified this by using my extra hooks from the STi.
Not all. The Tow loops for my GD Imprezas (02-07) do NOT fit my BRZ. Maybe newer Subarus will match (08+) but I'm not sure.
Old 08-20-2013, 11:17 PM   #30
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Noz View Post
Something like this? haha
Or this...
holy moly
where can i get one? lol
Old 08-21-2013, 07:47 AM   #31
troek
troek's Avatar
Drives: 2012 Toyota 86
my car came with 3 of those factory tow hooks. i painted 2 of them red and throw them on for track days, works great.
troek is offline   Reply With Quote
Old 07-15-2014, 01:40 AM   #32
wallace03
wallace03's Avatar
Drives: WRB BRZ
Any suggestions on reliable cheap tow hooks/strap? best one i found is the takata one. I also like the way these look a lot. Just not sure if they fit even though it says universal http://www.andysautosport.com/subaru...c00008515.html
wallace03 is offline   Reply With Quote
Old 07-15-2014, 11:31 AM   #33
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
By the way, driving around with your tow hooks in is a pretty good way to get the airbags to not deploy correctly in a crash.
@wallace03 Those "universal" tow hooks sandwich the factory tow hooks underneath the car, the little teeth on frame that you use to secure the car to a flatbed. They're usually flimsy and shitty enough that any side load will fold them over.
For those of you that want to mess around with tow hooks... this isn't the place to DIY. Welding a bigger ring onto the stock hook might look cool, but if that weld fails while someone is trying to pull your car out of a ditch, it might ruin someone's day when a chain or strap under considerable tension suddenly goes flying. The stock rings are perfectly adequate, if you need a larger strap the best thing to do would be get the spencer fabrication bumper beam which comes with a correctly installed tow strap.
I just wish they made these for the FRS / WRX
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 07-15-2014, 12:03 PM   #34
qoncept
qoncept's Avatar
How's that?
Got a drill?
qoncept is offline   Reply With Quote
Old 07-15-2014, 12:15 PM   #35
SomeoneWhoIsntMe
@qoncept at least on my WRX, it was in the owners manual that it may interfere with how the sensors work. it makes sense, hitting something with the hook in will put much more force straight into the frame rail as opposed to spreading it across the bumper beam
going back further, '95 imprezas were recalled because Subaru decided that the factory fixed tow hook under the bumper cover, which hung lower than the rest of the solid stuff on the front of that car, would set off the airbags if you struck a big enough object on the ground forcefully enough.
obviously, airbag technology has advanced since my '02 or that '95, but it's still worth noting.
Old 07-15-2014, 12:26 PM   #36
sklimo
Godspeed project sells them as well. $80 on website, but they run group buys on FB sometimes.
Old 07-15-2014, 09:16 PM   #37
wallace03
wallace03's Avatar
Drives: WRB BRZ
hmm i really can't afford an entire new bumper beam right now. Don't the straps just wrap around the frame of the car anyways? i guess if anything ill just use the stock tow hook for my track day.
Old 07-16-2014, 11:15 AM   #38
Rosticles
Drives: 1966 Mustang, 2013 FR-S
Originally Posted by DriftEightSix View Post
Need a bolt that is the same size as the tow hook bolt.
I don't trust those strap tabs inducing a torque on the bolt and tabs when a load is applied. Have you ever seen them used for purpose and not cause deformation or fail?
Rosticles is offline   Reply With Quote
Old 07-16-2014, 11:28 AM   #39
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
@ModBargains.com sells a Raceseng tow hook, comes in different colors and optional gopro mount...best of all, made here in the USA!
http://www.modbargains.com/raceseng-...on-frs-brz.htm
Old 05-17-2015, 05:49 PM   #40
abeds1
Drives: Subaru BRZ Limited
Any links to the OEM tow hook? my searches have failed me...
abeds1 is offline   Reply With Quote
Old 09-17-2019, 08:40 PM   #41
qqzj
Drives: MDX, Camry
Attachment 85112
I searched on eBay RaceEng hooks are about $175, Cusco's are cheaper at $115. However, the GodSpeed ones have very different prices. From $25 to $80. What is going on here? Also if I buy a RaceEng one, is it at high risk of being stolen? I can imagine it will be very easy for a interested thief.
qqzj is offline   Reply With Quote
Rust on tow hook ayau BRZ First-Gen (2012+) — General Topics 30 04-08-2014 02:54 PM
Tow hook specs? mufasis BRZ First-Gen (2012+) — General Topics 15 10-21-2012 10:41 PM
Tow Hook Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 7 09-11-2012 11:39 AM
Delete driver01 Scion FR-S / Toyota 86 GT86 General Forum 17 03-28-2012 12:32 PM
