Drives: 2013 FR-S & 2011 TC
Recommended HID Coversion kit?
I wanted to see which conversion kit people would recommend I go with for my FR-S. I'm looking for tangible recommendations and prefer quality over lower cost. Thanks in advance.
#2 |
Drives: 2013 Scion FR-S Raven
The Retrofit Source 404-220-7940
http://www.theretrofitsource.com/pro...roducts_id=254 Call them and mention FT86club forum, they "might" have a better price for you.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
| The Following User Says Thank You to tonystewart For This Useful Post: | RRnold (08-20-2013) |
#3 |
Drives: 13 FR-S
Are there retro fit kits that don't produce glare and actually work properly with the optics? I'm skeptical because I have seen so many annoying conversions.
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
#4 |
#5 | |
#RememberTheBuster
Drives: Firestorm FRS MT
A lot of people usually put HIDs in Halogen projectors which causes the glare due to the beam pattern. It's better to retrofit the projectors so it works well and has the correct light output. You can also buy HIDs from them as well, but once you retrofit with the mini h1 projectors, you can ultimately use any HID system. |
| Recommended Car Ramps for the BRZ/FRS? | mechaghost | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 49 | 09-01-2017 12:41 AM |
| Recommended PAINT SHOP GTA? | project d | CANADA | 5 | 02-05-2013 01:29 AM |
| Recommended Maintenance | blunova | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 51 | 01-04-2013 08:47 PM |
| Recommended first jobs? | 6-Shift | Off-Topic Lounge [WARNING: NO POLITICS] | 80 | 12-21-2012 12:19 PM |
| E-85 NOT Recommended | White64Goat | Engine, Exhaust, Transmission | 36 | 09-05-2012 01:53 PM |
