Old 08-20-2013, 06:47 AM   #43
arghx7
Drives: car
Holy crap, two pages in this thread and nobody has mentioned...
What are your intake air, oil, and coolant temperatures? Do you see signs of the coolant boiling?
intercooler sprayer isn't a bad thing but the intercooler has minimal heat transfer in the system relative to the oil, coolant, and exhaust. Try heatsoaking an STi or Evo with factory intercooler sprayer, hitting the button, and see how much your coolant temperatures go down.
Old 08-20-2013, 07:02 PM   #44
Dipstik-sportech
Dipstik-sportech's Avatar
http://m.summitracing.com/parts/spu-ix-30102029
These look promising
Old 08-20-2013, 07:54 PM   #45
jamesm
driving around on average my intake air temp is around 5-10 deg above ambient (so usually 105-110f), oil is around 220-230f, and coolant is 195-200f.
Old 08-20-2013, 08:58 PM   #46
arghx7
Drives: car
Yup, that's an expected range. In this case OP is reporting significant coolant loss. The main causes, besides headgasket issues, are going to be a leak or boiling. The way you diagnose a leak is with a pressure test. The way you address boiling is to either 1) raise the cooling system pressure or 2) improve the cooling capacity, especially of the engine coolant circuit, to keep the temperatures down.
Another thing that would be interesting to see are signs of engine failsafe modes kicking in due to high temperatures. You could see changes in AFR and timing at least. If we could see a log of a cold start, warm up, and basically normal around-town drive cycle for like 30 minutes it would give a good idea of what's going on with the engine.
Old 08-20-2013, 09:14 PM   #47
Dipstik-sportech
FBM Turbo Thirsty
Before I did the rad and oil cooler you noticed a significant drop in performance when the coolant temps rose to almost 3/4 on the gauge (sorry i don't have a way to tell the exact temp yet). It felt like the ecu was pulling timing to try and cool the engine.
Old 08-20-2013, 09:51 PM   #48
CTB727
Drives: 2013 Subaru BRZ
Originally Posted by SmsAlSuwaidi View Post
Our middle eastern climate sucks ass in summer you guys in the rest of the world can't imagine how bad it is !
Attachment 48396
This was yesterday , about 115f (46c) a normal summer day
I don't mind suffering in a Ferrari
CTB727 is offline   Reply With Quote
Old 08-21-2013, 12:50 AM   #49
nix
nix's Avatar
Drives: AVO BRZ
@Djen What oil & coolant temps are you seeing? And what do all your temps get to during stops/heat soak, including IAT?
Water-oil is a great plan to avoid the heat soak from air-oil lines/core. 1 quart per drive is so much, that thing must be cooking. With the stock fans on a Koyo radiator and AVO turbo kit I made it through the Aussie summer including a couple track days. Temp range 35-47c.
51c / 70 % humidity is another level of heat though!!
nix is offline   Reply With Quote
Old 08-21-2013, 01:41 AM   #50
Djen
Drives: GT86
atm im trying to figure out the AC issues I cant enter go stop traffics on this hot without AC you know.. swating etc im using cusco water to oil cooler. temp guage looks fine after done burp the rad. once we fix the sluggish idle. changing fans rad need a bit tune. if I switch AC on idle drop at times once the fans start pulling. RPM drop till it feel wanna stall the car. without AC switchd on idle stay on it position.. shit happen.
Djen is offline   Reply With Quote
Old 08-21-2013, 01:43 AM   #51
Djen
Drives: GT86
yeah its end of season here in Kuwait suns rises its heat... damn even my dialy drive car had some heat issues sounds common and turbocharged cars will have more heat
Old 08-21-2013, 01:55 AM   #52
Djen
Drives: GT86
yup your correct I can tell that after 1-2hour of driven in hot like this. I can feel slightly drop in performance but in highr RPM the car responde.
Old 08-21-2013, 04:46 AM   #53
Djen
Drives: GT86
Originally Posted by Alhammadi View Post
@Djen
Today I tried my car for the first time with FBM rad, oil cooler and slim fans. as well as the turbo blanket. That set up worked much better than the factory rad with the slim fans. I can tell you its about 30% more effective. still am facing some heat according to the gauge but AC working fine. now the heat goes down very quickly unlike before.
sounds good ali, main faces trouble on stops ac cant keep up because of idle droping once AC compressor pulley start spinning it make. dropping to stalling point. me and LJ@Fullblown we goin fix it sooner
Old 08-21-2013, 08:29 AM   #54
Djen
Drives: GT86
three bottle of coolant additive should help little bit
The Following User Says Thank You to Djen For This Useful Post:
Alhammadi (08-21-2013)
Old 08-21-2013, 01:18 PM   #55
Alhammadi
Drives: 2013 Toyota FT86
hope so =)
btw, I told you that I will send you the link for the carbon fibre hood:
http://www.brz-parts.com/hd1213scnfrs-fa.html
I am gonna get one of these within two coming months.
Alhammadi is offline   Reply With Quote
Old 08-21-2013, 01:26 PM   #56
Alhammadi
when you have the latest map your car will idle correctly. however, the pulley will work fine. but mine idles normally but when the heat was going up, 3/4 approx straight away the AC doesnt work. same as my other car I use to have the same issue with heat and it effects the AC. I am just telling you what I faced on this car and previous I might be wrong.
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
