go_a_way1
Old 08-18-2013, 10:39 PM   #1373
Grantmac
Drives: 2001 NB MX-5
An eductor (which that is) creates vacuum through flow. But it requires the exhaust side to have similar or less pressure than the suction line. I've built eductors to introduce methoxide in a biodiesel reactor. They are very simple devices but getting it right took work, any backpressure and there was no suction.
In a boosted application it's nothing but a boost leak.
However if you were to use it as a means of pump-less water injection then that would be awesome. The water tank would need to be under pressure as well though. I've actually got something drawn-up using a side-draft carb with the throttle plate removed.
-Grant
Grantmac is offline   Reply With Quote
Old 08-19-2013, 01:55 AM   #1374
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
-Grant
In the lab, that's how we powered the vacuum lines for filtering and drying various extracts. Water running out of a tap, through a little thingy, and the water flow created a vacuum But yeah, put a restirction on the outlet, and water came squirting out where vacuum was supposed to be lol.
Toma is offline   Reply With Quote
Old 08-19-2013, 02:05 AM   #1375
fenton
Rob and I are very interested in adding water meth injection to the current system if possible.... if anyone has good suggestions on a system let us know
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
TIE Pilot (08-19-2013)
Old 08-19-2013, 02:14 AM   #1376
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
This is a very interesting set up.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline   Reply With Quote
Old 08-19-2013, 08:24 AM   #1377
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
does anyone know when this kit will be for sale? and a price? i hope its close to the other prices they have posted for the chevy and vw
http://www.phantomsuperchargers.com/...ubaru-brz.html
NYCsubaruBRZ is offline   Reply With Quote
Old 08-19-2013, 09:07 AM   #1378
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
Originally Posted by fenton View Post
Thanks Toma. Not sure if you have had to much time to look at the logs I have sent you but it looks like the long term fuel trim is richining us up a bit.
Sent from my HTC One using Tapatalk 4
The long term fuel trim is richening our car from 8% to 12% after 2-3 weeks reflashed.
That's why your tuning have to compensate for that.
Usually after my FA20CLUB reflash I was right on the spot where we wanted 12.8 -13 but after 2 weeks I wasnt there anymore.
So what Tony did, he sent me a flash where a was leaner at first 14 -14.3.
It goes like that for 2-3 days and then gradually after 2-3 week at WOT I'm now at 12.5-13 all the way to redline.
From what I understand, by doing this we cheat the long fuel trim effect.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 08-19-2013, 10:07 AM   #1379
mid_life_crisis
Drives: FR-S 10 #103 AT
I really don't like the fact that the tuners have to play games like that. It explains a lot about the blown seals out there. There must be a way to edit the target table to get the correct results from the start. It isn't like they're using a primitive version of an add-on processor to cheat the system: they're directly editing the processor. It shouldn't be necessary to "cheat" the system.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-19-2013, 11:40 AM   #1380
Calum
That Guy
Drives: 2013 asphalt FRS MT
Check out Ptuning's stuff. I have no first hand experience with it, but what they've posted leads me to believe it's worth investigating.
Old 08-19-2013, 11:42 AM   #1381
Calum
That Guy
-Grant
Grant, that is brilliant! Do you have any plans to take it beyond the design phase? I'd love to see that come to market.
The Following User Says Thank You to Calum For This Useful Post:
DAEMANO (08-19-2013)
Old 08-19-2013, 12:10 PM   #1382
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
This is from ALCOHOL INJECTION SYSTEM
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 08-19-2013, 03:13 PM   #1383
nonicname
Drives: it has 4 wheels and a motor
mmmm I like this system as simple as it is.
if it's not broken don't fix it.
nonicname is offline   Reply With Quote
Old 08-19-2013, 04:29 PM   #1384
Toma
Pump from mopac...aem. nozzle from mopac... snow performance about 150 to 200cc.... I would flow test it to make sure it flows about 175cc or about 20 percent of fuel flow by mass. Pressure switch or wot window switch. And assorted air line fittings and hose from princess auto.... just y the supply line from your washer tank and run windhsield washer fluid.
Then re tune to give the factory knock sensors more authority to add additional timing.
Old 08-19-2013, 04:40 PM   #1385
Toma
And then once a season nozzle cleaning and flow test.
Old 08-19-2013, 05:01 PM   #1386
Robftss
Drives: VW
Originally Posted by FT_Monk View Post
Was the current draw actually measured or based on the ESC advertised rating?
0:59 (VW, current measured)
[ame="http://www.youtube.com/watch?v=VnWkfa98rGE"]http://www.youtube.com/watch?v=VnWkfa98rGE[/ame]
Robftss is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
