#1373 |
Drives: 2001 NB MX-5
An eductor (which that is) creates vacuum through flow. But it requires the exhaust side to have similar or less pressure than the suction line. I've built eductors to introduce methoxide in a biodiesel reactor. They are very simple devices but getting it right took work, any backpressure and there was no suction.
In a boosted application it's nothing but a boost leak. However if you were to use it as a means of pump-less water injection then that would be awesome. The water tank would need to be under pressure as well though. I've actually got something drawn-up using a side-draft carb with the throttle plate removed. -Grant |
#1374 | |
Drives: Viper, Mustang, FD RX7, FFR GTM
#1375 | |
| The Following User Says Thank You to fenton For This Useful Post: | TIE Pilot (08-19-2013) |
#1376 |
The Based God
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
This is a very interesting set up.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
#1377 |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
does anyone know when this kit will be for sale? and a price? i hope its close to the other prices they have posted for the chevy and vw
http://www.phantomsuperchargers.com/...ubaru-brz.html |
#1378 | |
Drives: FR-S Firestorm
That's why your tuning have to compensate for that. Usually after my FA20CLUB reflash I was right on the spot where we wanted 12.8 -13 but after 2 weeks I wasnt there anymore. So what Tony did, he sent me a flash where a was leaner at first 14 -14.3. It goes like that for 2-3 days and then gradually after 2-3 week at WOT I'm now at 12.5-13 all the way to redline. From what I understand, by doing this we cheat the long fuel trim effect.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow - 2007 Honda CBR 600RR - 2002 Bombardier Legend 800SE Website : http://nofear99.monchar.com |
#1379 |
Drives: FR-S 10 #103 AT
I really don't like the fact that the tuners have to play games like that. It explains a lot about the blown seals out there. There must be a way to edit the target table to get the correct results from the start. It isn't like they're using a primitive version of an add-on processor to cheat the system: they're directly editing the processor. It shouldn't be necessary to "cheat" the system.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#1380 |
That Guy
Drives: 2013 asphalt FRS MT
Check out Ptuning's stuff. I have no first hand experience with it, but what they've posted leads me to believe it's worth investigating.
#1381 | |
That Guy
| The Following User Says Thank You to Calum For This Useful Post: | DAEMANO (08-19-2013) |
#1382 | |
Drives: TIE interceptor; BRZ13
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
#1383 |
Drives: it has 4 wheels and a motor
mmmm I like this system as simple as it is.
if it's not broken don't fix it. |
#1384 | |
Then re tune to give the factory knock sensors more authority to add additional timing. |
#1385 |
And then once a season nozzle cleaning and flow test.
#1386 |
Drives: VW
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
