Old 08-14-2013, 09:59 AM   #1
bakerr6
Drives: 2013 raven black fr-s
Racer X LCAs
Well these bad boys just came in yesterday, so I figured I would throw up a few pics for those that are interested. Now I just need to find time to make it over to @TiC to pick up the front camber plates. Here you go:
bakerr6 is offline   Reply With Quote
Old 08-14-2013, 01:12 PM   #2
Boil
Drives: CX500 Cafe Bobber
Did you choose to not have the arms powdercoated?
Boil is offline   Reply With Quote
Old 08-14-2013, 04:15 PM   #3
bakerr6
I originally wanted them to be powdercoated, but ended up having them zinc plated. In the future, I may end up having them powdercoated if they start to pit from rust. Once this car is no longer taking on DD duties, I'll be switching to spherical bearings instead of the poly bushings
Old 08-16-2013, 11:40 AM   #4
2Brnt2BRZ
Drives: 2013 WRB BRZ premium
What's the weight compared to the OEM?
2Brnt2BRZ is offline   Reply With Quote
Old 08-16-2013, 12:03 PM   #5
Dephective
Drives: '13 Whiteout FRS
idk what the weight is, but they are chromoly steel, which allows you to use half the material as stamped steel (oem). I would say they are maybe a 1lb lighter, but they are considerably stronger than stamped steel.
I just received my invoice, I'll post pics when I receive them.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 08-17-2013, 10:44 PM   #6
bakerr6
He's probably accurate. I can try to wigh them both before I install them tomorrow morning. I'm installing these, konis, machv springs and hvt camber plates
Old 08-17-2013, 11:35 PM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I have RacerX rear lca with spherical bearings. I can't pick any additional nvh over the original arms.
Old 08-18-2013, 01:07 AM   #8
bakerr6
I'm more worried about mantinence at this point. If I wasdoing more track days, I think having the spherical bushings would be better. I think these will lat me a little longer than the spherical bearings would (we salt our roads a lot)
Old 08-18-2013, 03:30 AM   #9
Boil
But for climates/locations that do not have the need for salting the roads, would you consider the spherical bushings (with the optional dust boots) to be acceptable for a daily driver/track day vehicle…?!?
I am thinking my 'dream suspension' would be the complete Racer X lineup & Ohlins coil overs…
Old 08-18-2013, 03:40 AM   #10
Captain Snooze
Drives: Red Herring
I view spherical bearings as a consumable. In my previous car I changed them every couple of years. I have no idea if this was required it was just something I did. I will be carrying out the same schedule with my current car.
As been mentioned a couple of times in these threads (see my post above) there is no noticeable increase in nvh with spherical bearings.
Old 08-18-2013, 04:46 AM   #11
bakerr6
I think is you are not dealing with salt that they will last you much longer. 2 years would be a little excessive for normal drivng standards though. If you are tracking the car, you may need to change them more frequently
Any issues running Stance LCAs and GTSPEC toe rods/trailing arms? FTEIGHTSIX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 04-01-2014 01:15 PM
KW V3, Stance LCAs, Project MU Club Racer Pads HighbreadEH3 Brakes, Suspension, Chassis 18 09-05-2013 11:12 AM
First mod every serious racer should do Heero CANADA 10 07-12-2012 05:44 PM
Hyper Pro Racer go kart Axel Other Vehicles & General Automotive Discussions 1 02-22-2010 11:36 PM
