| DIY (Do-It-Yourself) Guides For all DIYs. |
#43 |
Drives: BRZ(sold), STI
^Not the best of pics. This seems to be a pass-side plug. So, per wiring diagram, one should route the power to the terminal #2, white wire. Which is one the back row of the pic, second from the bottom. Red wire with a brown insulator right on the 'knob' of the plug is terminal #5, #1 is right behind it, and #2 is one up. On the other side the wire colors are different and you'd have to splice into a red wire, still on terminal #2 though.
Personally, I'd just route a wire from some ignition switched source directly (or rather via a relay just to be safe) to the halos and not mess with soldering. Just disconnect the OEM wire off the headlight harness and plug your ignition-sourced one. |
#44 |
Drives: Subaru BRZ Limited
Go to Nav Settings, change dimmer to Time and then set it as your sunrise and sunset.
Turn the knob up to the parking lights mode and there you go, your Boomerangs are on during the day and your Nav is still bright. Isn't that basically what you're trying to achieve? |
#45 |
#46 |
You know that sunrise/sunset time changes over the year, right? You'd be adjusting it constantly. And you'd have to turn your headlights on manually when it's dark during the day due to weather.
#47 | |
Constantly!? I've had the car 2 months and the sunset has changed by 30 minutes. Takes less than 1 minute to adjust it. I'd rather spend 6 minutes a year adjusting the sunrise/sunset than take apart my car and rewire everything. You'll spend more time trying this DIY than it would take to just manually adjust it. And, I'd rather have full control over what my headlights and DRLs are doing rather than have no control over them at all and have them be on constantly. Plus, what's the point in having the boomerangs on during the day when you can't even tell that they're turned on until is late afternoon anyways. This DIY is a step in the wrong direction. You're basically using a ton of your time so that you can lose full control of your lights. |
| The Following User Says Thank You to ericmpena For This Useful Post: | sftateofmind (05-05-2015) |
#49 |
#50 |
Doctor
Drives: Fast
Maybe the Nav going into night mode doesn't bother me much cus my car has tinted windows and it's always night time
![]() Sun never sets on a bad ass. |
#51 | |
Not trying to be a ****
Drives: BRZ - 6MT - GBS
Its just personal preference man, I think I learned that people are going to do what they want regardless of what I say a while ago.
-EvilBeaverFace - My 2013 Subaru BRZ - 6MT - Galaxy Blue Silica
Inland NW 86 Owners Club on Facebook (Spokane, WA/CDA, ID area) FRS/BRZ/GT86 Enthusiasts Facebook Group |
#52 | |
You're right, people are going to do what they want. This thread isn't about wether you should or shouldn't do the mod, it's just about how to do it if you wanted to. I shouldn't have posted my opinion as I know now that this isn't an opinion discussion, it's a How To/DIY. |
#53 | |
@Respect BRZ and @dsgerbc did you guys ever figure anything out? I saw this thread a long time ago before it was even 1 page long and nothing was in here but since I checked again today it seems like you two have come a bit farther.
I really would like to be able to do this on my car. Quote:
I know I'm asking a lot here so thanks guys if you can help. The only training I've had as far as electronics is the Air Force Electronics Principles course and that was 6 years ago so if I sound ignorant on the subject I apologize.
#54 | |
What he did is in post #42. Now that I looked at it, I think I'll redo mine more like his. If one needs an underhood fuse to tap - IG2 7.5A fuse (just off the pic above on the left) seems like an okay source. I'm gonna try to pull a pin #2 of a headlight harness and see how easy it's gonna be to source a replacement. Shouldn't be too hard. |
#55 | |
#56 |
Okay, I did it the way @Respect BRZ has it.
I'm not entirely happy, so I might be re-doing it. That's when I'd do a write-up. A few notes: 1) Currently, I did grab ignition-switched power from a IG2 fuse under the hood (see pic). I'm not entirely happy with that (lots of useful stuff on that fuse), I'm probably gonna re-do it with a relay, still using ig2 source to close the relay, but take power off some empty fuse slot. 2) I have a thing for preserving factory wiring. So I've spent most of my time trying to take pin #2 off factory harness and sourcing a replacement pin that would work in its place. I went to my local autoparts store and grabbed the only thing that looked remotely similar. It ended up being okay. The pin in that replacement harness is a bit narrower than OEM one and the rubber seal is too small, so I had to make sure to wrap something around that pin before plugging it into the OEM harness. 3) Now, taking the #2 pin (red circle) of OEM harness is basically my only useful contribution. The white part of the plug just pops off with a bit of effort. Then one needs to pop up the latch on the pin (blue circle) and push the pin out of the plug. The mechanism is the same as in the parts-store plug, so take the pin off that plug first to practice. |
| Halo ODST Commercial (Epic)!! | MR2fan | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 09-14-2015 01:29 PM |
| FRS Ignition Key | ft86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 120 | 07-22-2014 09:23 PM |
| Halo Light Logic Modification? | feedbag | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 01-28-2013 11:33 PM |
| New test from Ignition. | zoomzoomers | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 04-30-2012 11:31 PM |
| *** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** | zAnSh1n | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 04-04-2012 04:41 PM |
