Old 08-16-2013, 06:58 PM   #1009
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by evo4g63 View Post
If anyone can post or send me pics of the opening of the valve. I want to see if the arm going in is sitting straight or slightly angled.
The arm is slightly angled in the actual actuator. This is normal. I actually had an issue similar to yours when I first installed my personal system. I just moved the TB hoses a little bit and the lever can not touch the hose. That is how it was supposed to be, it was my mistake for not making sure it is tucked well when I first did the install.
mines13 is offline   Reply With Quote
Old 08-16-2013, 07:18 PM   #1010
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by swift996 View Post
Please add some pics when you figure it all out. It would be helpful to the community.
What about the three screws that hold it on? Do they sit flush or slightly not so flush? I still have the noise but only when I am at 6k and blip. It's 95% gone though. I can wot shift and no noise
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-16-2013, 08:52 PM   #1011
evo4g63
evo4g63's Avatar
So drove my car again and the noise is super minimal not every time like before. Not much access to adjust anything due to how the blower sits. I can't really see what I would be adjusting without it off of the car. I notice the slight angle the rod has almost touching the roof of the valve itself going in. I wonder if it is damaged due to binding for some time
-2016 Subaru WRX
Old 08-16-2013, 08:54 PM   #1012
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
@evo4g63 is the noise similar to around the ~1:01 second mark in this video?
[ame]http://youtu.be/IxC2iNj1j9g[/ame]
Xero-Limit is offline   Reply With Quote
Old 08-16-2013, 09:27 PM   #1013
evo4g63
evo4g63's Avatar
Yeah, sounds a little like it. My video is posted a page back
-2016 Subaru WRX
Old 08-16-2013, 09:51 PM   #1014
Xero-Limit
Xero-Limit's Avatar
that sounds exactly like it (don't know how I missed that video)
Tip in knock.
Old 08-16-2013, 10:02 PM   #1015
evo4g63
evo4g63's Avatar
Tip in knock.
-2016 Subaru WRX
Old 08-16-2013, 10:04 PM   #1016
xjohnx
Grip>Slip
xjohnx's Avatar
shouldn't be too big of a deal for your tuner to clean up.
Old 08-16-2013, 10:07 PM   #1017
evo4g63
evo4g63's Avatar
Well we shall see. And now I am worried about damage that may have been caused due to this.
-2016 Subaru WRX
Old 08-17-2013, 12:12 AM   #1018
Xero-Limit
Xero-Limit's Avatar
spent about 12 hours and nearly 30 revisions to have it go away on pump. Still can see some on the datalogs, but no more audible noise on the last beta tune. The audible portion is what counts.
No easy task IMO....the blower pushes that air in there awfully quick if you stomp on it.
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
xjohnx (08-17-2013), xxscaxx (08-18-2013)
Old 08-17-2013, 01:02 AM   #1019
sw20kosh
Drives: 2013 Black FR-S
I see tip in knock on all my tunes. If you take a ecutek log you will see it as Knock Correction right when you go to WOT. It isn't audible on mine (from inside the cabin at least)
Old 08-17-2013, 01:11 AM   #1020
evo4g63
evo4g63's Avatar
I see that as well on mine. The audible part scares me a lot though.
-2016 Subaru WRX
Old 08-17-2013, 02:58 AM   #1021
ft_sjo
Drives: GT86
Looks as if I found my noise finally. It is coming from the bypass valve on the back of the unit. I am wondering if and when the unit opens and closes of the rod is bent. This would cause it to bind and such. Reason I saw this is due to the two heater hoses that run to the throttle body. Seems as it was minorly touching the valve. I moved that line and went wot. Noise is gone wot but is slightly apparent if I blip at 6k. I guess I may need a new bypass valve.....
I'm not convinced. My guess is its transient det/knock. If it only does it when the vehicle is rolling (in neutral on that video, I assume?) then the ECU is doing something different as it thinks the car is moving. The bypass valve on the supercharger doesn't know the car is moving, but the ECU does, and may be applying a different strategy.
Check your knock count with an OBD scanner or monitor it realtime with ecutek if you can to see if you get simultaneous knock events with the noise.
Old 08-17-2013, 04:00 AM   #1022
evo4g63
evo4g63's Avatar
In the video my foot was holding the clutch in. The car won't do it if its just in neutral or at a complete stop. Even with the launch control setp on, the vehicle will not make the noise. The clutch has to be in at low speed with throttle blip, WOT shifting gears or at speed in the mid to high rpm range when blip of the the throttle. I have tried many times to get it to do it at idle or rolling in neutral. No signs than at all.
-2016 Subaru WRX
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
