Old 08-12-2013, 05:27 PM   #29
MethBear
Drives: Scion FRS
So I used a fuel treatment, STX if I remember right, after filling up with AAFES 93oct. after about an hour or so the chirping has all but gone away. you can still hear them but it is truly negligible and i didn't even hear them today and i put the treatment in last week sometime. just thought I'd share...
MethBear is offline   Reply With Quote
Old 08-12-2013, 11:56 PM   #30
07jazzrs5gt86
Drives: Firestorm 86
Finally have my 1st trace of crickets this after noon for 1 min at a stop light but was gone and totally disappear for the rest of the day.
Have Toyota and subaru figure out what is actually causing it yet?
What kind of damage might it cause if not fixed? besides annoy the heck out of you
07jazzrs5gt86 is offline   Reply With Quote
Old 08-13-2013, 12:08 AM   #31
kodyo
Drives: Scion FR-S
Most of us are just living with it. It hasn't caused any problems for me as of yet, nor have I really heard of any issues from others. Basically just a sound issue currently
kodyo is offline   Reply With Quote
Old 08-13-2013, 01:52 AM   #32
07jazzrs5gt86
Thanks
Good to know it hasn't cause any other issues yet.
I just got my unichip and flux2 today so when I heard the crickets I was hesitant to install it.
I might do it any ways tmr
Old 08-14-2013, 01:19 AM   #33
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
I took mine in the other day to Toyota and was told there is a tech bulletin about to be released on the issue. I know my dealership extremely well as they sponsor me for a track car I own so I believe them that there is a fix coming. They said any day now. They are ordering the "parts that will be needed but the car is safe to drive according to corporate" soon to fix my crickets. I am trying to avoid driving the car however as I can only assume that part of the sound we here is the engine running lean and the injector cannot get the fuel it needs. Therefore I would like to avoid driving it. But hey, Toyota might be correct. I just don't want the long term damage that might result.
Maverick22 is offline   Reply With Quote
Old 08-14-2013, 01:51 AM   #34
mike the snake
My old BMW 135i had HPFP problems and recalls. No noise, but they did go bad and BMW has increased the warranty on them to 100K miles.
In reading up about that issue, I read that someone recommended adding a cap full of synthetic 2 stroke oil to every tank full. This was supposed to help the HPFP.
I wonder if adding a cap full of synthetic 2-sroke oil per tankof gas would help with the chirping crickets on our cars?
It certainly won't hurt anything.
Old 08-14-2013, 07:55 AM   #35
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Please read. http://www.ft86club.com/forums/showthread.php?t=41776
Don't be afraid, your car won't blow up.
Old 08-14-2013, 09:24 AM   #36
choi0706
Drives: t
+1
choi0706 is offline   Reply With Quote
Old 08-14-2013, 09:31 AM   #37
FR-S Matt
Man, and I thought I was paranoid about door dings and keeping my car clean. This takes the prize. The pump is fine. Read the thousand posts in the other thread. It is just an annoyance.
Old 08-15-2013, 06:38 PM   #38
86_Insider
86_Insider's Avatar
Originally Posted by reesmicm View Post
Toyota is odd at times with issues - did they ever find the issue with the ghost acceleration problems with several models, if I recall, they thought it was floor matts, so they modified the mat clip on my 4Runner - go figure.
The only problem was people who should not have been behind the wheel. I have had a floor mat go loose and get stuck. I pushed the clutch in, reached down and pulled it out from behind the pedal.
http://www.nhtsa.gov/PR/DOT-16-11
86_Insider is offline   Reply With Quote
The Following User Says Thank You to 86_Insider For This Useful Post:
Tim_Asphalt_FRS (08-16-2013)
Old 08-15-2013, 07:39 PM   #39
TurboBrett
Drives: 13 BRZ
It would hurt your octane rating, wouldn't it? Wouldn't cause any issues I don't think, but will slow you down if so.
TurboBrett is offline   Reply With Quote
Old 08-15-2013, 08:06 PM   #40
37
degrees
37's Avatar
Drives: 6MT BRZ
+1. Mine chirps like crazy but it's no worse than any aftermarket HPFP I've had in other cars. If a true fix hits the system then I'll consider scheduling it, otherwise it's about the last thing on my mind.
37 is offline   Reply With Quote
Old 08-16-2013, 11:56 AM   #41
Stu baru
Official Cobb beer knurd
Stu baru's Avatar
Drives: 2013 BRZ-L MT SWP
My BRZ is at the dealer as we speak to have a few things taken care of, one of which is the return of the DI chirp. Apparently the first iteration of the redesigned fuel pump wasn't sufficient (as my car can attest...was fixed for a while but not forever), and there is now 2nd iteration of the fuel pump. Supposedly they are on national back order, but my dealer pushed/begged/pleaded and is supposed to be getting on Monday. Fingers crossed that this fixed it for good.
Don't text while driving, everyone around you will appreciate you not endangering their lives.
Stu baru is offline   Reply With Quote
Old 08-16-2013, 12:55 PM   #42
stefmiesterb
stefmiesterb's Avatar
Drives: B8 A5
Sounds like something the dealer would just say to shut a customer up. But as with everyone, I hope its true.
stefmiesterb is offline   Reply With Quote
(TSB) No More Crickets Under My Hood!! xpicer Issues | Warranty | Recalls / TSB 1140 12-04-2015 08:53 AM
Crickets? Jertronic Scion FR-S / Toyota 86 GT86 General Forum 15 05-24-2013 08:38 PM
Different kind of crickets... KSC Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 03-19-2013 05:51 AM
Crickets Gone Or Returned After Pump Replacement? FR-S Matt Issues | Warranty | Recalls / TSB 38 02-25-2013 03:16 PM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-05-2013 11:29 PM
