Drives: Rocket Bunny v1 FRS
Issue with BC BR extreme low coilovers
ok so I installed my BC extreme low coilovers this past weekend and so far im having an issue that that is almost unbareable... I had them built w/ 10k springs front and rear. my issue is my car bounces like crazy in the rear. this isnt my first eperience with coilovers so i know there is an issue. Its like there is no dampening going on in the rear. Ive adjusted dampening several times and nothing has helped... Its like i purchased a set of $200 ebay coilovers. If anyone has any insight i would greatly appreciate it. I installed them myself and it was a pretty straight forward install. Idk if there is something i could check or adjust to help this issue...
#2 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
I have no experience with suspension but I know that the stock spring rates are far less than 10k. 2.3k front 3.8k rear is the stock setup. Is the fact that your spring rate is so much higher the reason that your car is jumping? Why did you increase your spring rate over 300%? Your new setup seems awful stiff.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#3 |
Loading...████████] 99%
Drives: #0517
not familiar w/ bc products aside from seeing the name everywhere, but do they revalve their shocks to match w/ the higher spring rates? i would be doubtful but again, i'm not familiar with the brand
#4 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Have someone watch the car from the outside. You need to determine if the bouncing is from the suspension traveling up and down, or if it's the car bouncing on the tires.
Personally I think 10K rates is crazy high for street use. |
#5 |
Boosted
Drives: Not a supra....yet
| The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | 636 (08-16-2013) |
#6 |
I spoke w/ @636 and he said his is bouncy as well. but i would like to hear what SLIVIC has to say...
| The Following User Says Thank You to 86TruenoFRS For This Useful Post: | 636 (08-16-2013) |
#7 |
I ran 10k springs on my previous car (s2000) and the ride quality seemed so much better. I was running Megan Racing Street series on the s2k so it wasnt like I was running high end coilovers
#8 | |
Sounds like you need far, far more damping in the rear. Keep adjusting the damping up and hope that it works. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#9 |
Drives: Too heavy
I have bc br with swift 8/8k springs Upgrade, there's a time that I wish I opted for a softer spring rate. So I can imagine 10k would be super stiff....
#10 |
Drives: 2006 STi
uh.. i guess mine is bouncy. It really depends on personal opinion? i have 10k all around , dampening on full stiff all around. Kinda too soft for my fitment thinking about doing 15K maybe idk
| The Following User Says Thank You to SLICVIC For This Useful Post: | 636 (08-16-2013) |
#11 |
Señor Member
OP, have you checked whether the car is sitting on some sort of bumpstop in the rear?
1974 TA22 Celica
2013 86 GT |
#12 | |
Drives: '23 CWP BRZ
And, I just don't know if you're used to having such a light car with such stiff springs, It's normal. Rode like this on my civic with 24k. |
| The Following User Says Thank You to 636 For This Useful Post: | 86TruenoFRS (08-16-2013) |
#13 |
Drives: FRS
its normal. I had buddyclub rsd 10k/15k on my civic and its stiff... still is. Riding in my FRS is like rolling around in a cloud compared to the vic.
| The Following 2 Users Say Thank You to qijian For This Useful Post: | 86TruenoFRS (08-16-2013), SLICVIC (08-16-2013) |
#14 |
Drives: 1992 BMW E36 325i, 2013 Scion Frs
Same I have the same extreme drop with 10k my dampening is set to 25 all around and yap my car is bouncy too, thinking its from the stiff springs is all.
| The Following User Says Thank You to Jarumie42172 For This Useful Post: | 86TruenoFRS (08-16-2013) |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 12:09 PM |
| RS*R SUPER DOWN SPRINGS AND COILOVER AND MORE! | ExtremeAutowerks | Brakes, Suspension, Chassis | 32 | 12-23-2013 02:39 PM |
| BC Racing Extreme Drop Coilovers | 636 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 10-16-2013 11:42 AM |
| BC BR Extreme Low Coilovers install pics | 86TruenoFRS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 08-22-2013 01:44 PM |
| Stance coilovers lowering issue | Dispect | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 08-06-2013 11:05 PM |
