| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,101 | 85.22% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.78% |
| Voters: 3639. You may not vote on this poll | |||
#2577 |
Drives: 2013 Rocketbunny GT86
I had my pump replaced yesterday. There is a Tech bulletin out on it. The crickets are gone now. same tank of gas and all.
#2578 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
A lot of people report no crickets for a few hundred miles on the new pump and then they return. You should let us know again within the next 500 miles if they stay away.
#2579 |
Drives: 2013 FR-S Standard Blue
The sound does come from the fuel pump. All you have to go is go back to the dealer and they will replace the pump and some seals which is covered under warranty.
#2580 |
Drives: '11 Subaru STI
I work for Toyota and have access to the tech bulletins so I have been keeping my eye out for updates on this one. They just released an updated one a few weeks ago that found the root cause of the chirping. It has to do with bad seal alignment on the inside of the DI pump that causes the noise. To fix it you have to have the dealer replace the pump but it has to be after a certain manufacture date. I think the date was 4/2013 but I will have to check when I'm at work.
| The Following 5 Users Say Thank You to MST Engineer For This Useful Post: | Blackbeltmma (08-16-2013), FRS1010 (08-15-2013), JDM FRS (08-15-2013), scary alien (08-15-2013), shiro (08-16-2013) |
#2581 | |
Drives: 2013 FRS
#2582 | |
Drives: Scion FRS(Whiteout)
#2583 |
Drives: 2013 FRS, 2010 Evo X GSR
Started to happen after my first oil change 2 days ago. Used oem filter and motul 0w20 ecolite oil @7000 km
#2584 |
Drives: White 2013 BRZ Limited 6MT
At 7500 miles, I had the fuel pump swapped out under warranty, and the crickets went away. Within the first 500 miles on the new one, the sound was back. I'm hoping they come up with a solution soon
#2585 | |
Hail Magnet
#2586 |
Lost in Kansas
Definitely. And it has been shown to pretty much a 100% success rate that getting your HPFP replaced will make the crickets go away... at least for 100 miles or so...
#2587 | |
Drives: 2013 FR-S, IS-300, 2004 VW R3
| The Following User Says Thank You to Demotic For This Useful Post: | strat61caster (08-16-2013) |
#2588 |
Drives: SWP Subaru BRZ
I had the crickets after filling up with 91 octane 10% ethanol in Iowa on my way back home to Omaha. Noticed the crickets when I stopped to use the bathroom and get some water. Ran the tank until it was close to E, no low gas light. Filled up with my usual 91 non Ethanol gas, crickets gone. Now I have not driven 4+ hours at 80-85MPH continuously since then so granted my crickets could not appear until I do that again, but I am sticking by this ethanol in gas issue until I see otherwise personally. I am no mechanic, no engineer, but it worked. Did not have them before I left on my road trip, did not have them when I got to my Dad's in Michigan on 91 non Ethanol gas, and only the last leg when I HAD to fill up with 10% it showed up.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below. Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty. |
#2589 |
8SiX
Drives: FRS 10series
I did half a tank of 92, no-ethanol gas and then the other half 92 10% ethanol. I got crickets.
I'm going to try and run her empty, and then try non-ethanol fuel. |
#2590 |
Drives: 2013 Scion FR-S, 2014 Lexus IS350
I haven't had a chance to read through 100+ pages of form but this is just what I heard from Toyota: The chirping is normal and part of the noise the boxer engine gives off.
I would assess it is because of the design and high compression, if the said comment was true. It's a little annoying but that's what a loud stereo is for :P |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 09:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 01:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 10:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 03:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
