Old 08-15-2013, 12:23 PM   #407
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
Originally Posted by Frs300 View Post
pipe cutter in the FIX KIT just makes me laugh. is he trying to tell us his kit is a hack job?
next kit will come with one of these so you can make your own custom hoses!
JDM FRS is offline
The Following 7 Users Say Thank You to JDM FRS For This Useful Post:
@Art_Mighty (08-15-2013), cuddefred (08-15-2013), HotLeopardMama (08-15-2013), InvalidJohnny5 (08-15-2013), PStaff716 (08-15-2013), Rayme (08-15-2013), Sportsguy83 (08-15-2013)
Old 08-15-2013, 12:23 PM   #408
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Squishy View Post
There is this awesome feature I have forgotten to use more often on this forum. It's called "add to ignore user list."
I think I will have a capped list soon.
I've never used it in my life. I am about to though....
Sportsguy83 is offline
The Following User Says Thank You to Sportsguy83 For This Useful Post:
JDM FRS (08-15-2013)
Old 08-15-2013, 12:25 PM   #409
Frs300
Frs300's Avatar
Drives: Pile of junk
where is this ignore feature
Frs300 is offline
Old 08-15-2013, 12:26 PM   #410
Sportsguy83
Drives: Limited BRZ
Go to member profile and below their name it says User lists..
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Frs300 (08-15-2013), Red FRS (08-15-2013)
Old 08-15-2013, 12:26 PM   #411
Frs300
Frs300's Avatar
Go to member profile and below their name it says add to list..
found it
Frs300 is offline
The Following 2 Users Say Thank You to Frs300 For This Useful Post:
JDM FRS (08-15-2013), Sportsguy83 (08-15-2013)
Old 08-15-2013, 12:34 PM   #412
Opposed
Drives: 2013 Asphalt FR-S
Will cost $40 on top of existing kit price...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
The Following 2 Users Say Thank You to Opposed For This Useful Post:
HotLeopardMama (08-15-2013), JDM FRS (08-15-2013)
Old 08-15-2013, 12:39 PM   #413
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
That's only for the groupbuy. If you don't jump now, it'll be $65.
Nightbringer is offline
The Following 3 Users Say Thank You to Nightbringer For This Useful Post:
HotLeopardMama (08-15-2013), JDM FRS (08-15-2013), Squishy86 (08-15-2013)
Old 08-15-2013, 12:41 PM   #414
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
If everyone would calm their tits for just a second, how do we know the flex fuel kit wasn't installed without the hose clamp, like in the updated kit?
If that was the case the fuel line would have 0 chance of a leak. And if it did leak that would be on Accelerated Performance, not John. I'm just stating observations, not siding with anyone.
post_break is offline
The Following User Says Thank You to post_break For This Useful Post:
Allch Chcar (08-15-2013)
Old 08-15-2013, 12:42 PM   #415
Frs300
Frs300's Avatar
nice always wanted some visconti-doh
Frs300 is offline
Old 08-15-2013, 12:44 PM   #416
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Sorry for your loss, this is horrible news
SLICVIC is offline
Old 08-15-2013, 12:44 PM   #417
Sportsguy83
Drives: Limited BRZ
It would be on both. The kit itself was flawed, before the upgrade. This happened before any talk of upgrade was made. Both Don and John worked together in tuning/selling/modifying this car.
At the end of the day, ALL of this is speculation since the exact cause of fire is still unknown. It might very well be what you say is true. Who even knows if this car was testing the upgraded fuel kit?? Only Don'/John know. Hopefully the investigation founds a clear cause.
Time will tell.
Old 08-15-2013, 12:45 PM   #418
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Originally Posted by Toma View Post
If you don't know what you are talking about, don't add fuel to the fire.
The hose is fine, not degraded, and there is no printing on the outside braid. All normal.
There are several style of hose ends for this hose,
This is approximately what it looks like with one type of end installed
It's that weave that makes the end look frayed, then. That's what I was referring to. nm.
Subzero is offline
Old 08-15-2013, 12:46 PM   #419
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Like I said earlier in this thread, car video was posted July 17th, user stated the car was a total loss on July 23rd, John didn't have the "fix" ready until July 29th. Kits were originally released to us (you, CB, me, the rest of the group buy) around June 26th. If the hose fix was in operation, John sat on it from everyone else.
As to the ultimate fate of the OP's car, that's still up in the air - however based on what facts are present, it's likely the outcome was from the issues/failures that have been noted with the first round of the kit failing.
Let me be clear, this isn't anything against you @post_break - your diy was spot on for the hardware provided - the kit lasted 3 weeks on my car in the state it was delivered in before failing. The fact remains however that is does fail, at least a certain percentage of the time so it was not a well engineered design. John would have been better off partnering with someone that focused on the hardware, while he focused on the tune.
mikalem is offline
The Following 4 Users Say Thank You to mikalem For This Useful Post:
Calum (08-15-2013), Frs300 (08-15-2013), Sensisnow (08-15-2013), Sportsguy83 (08-15-2013)
Old 08-15-2013, 12:50 PM   #420
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
A few goals in my posts.
•Don't jump to conclusions without all evidence. ie, cause of fire.
•Don't bite off more than you can chew, modding a car is not a joke or to be taken lightly. Especially OIL or FUEL or ELECTRICAL systems.
•Aftermarket parts and kits are just that, and do not go through all the rigorous OEM type design, modeling and testing, nor do most of them employ hundreds of engineers like the OEM's do, and spend hundreds of thousands of man hours on their stuff.
•Ultimately, you, the owner, is responsible for your car.
Just simple, "well known" facts.
Another goal of your posts (all of them) seems to be to convince the FT86 community that a vendor/tuner/shop/professional mechanic cannot be held responsible for incompetence. You are wrong. That is a simple LEGAL (and CIVIL) fact.
IF this fire is proven to be caused by design flaws or improper installation of professionally installed aftermarket parts then the OP has every right to be made whole for his loss in total. It is my understanding that the insurance company may/will cover the loss of the value of the car but not the total investment in the car. Therefore, the OP and the insurance company may still pursue a legal resolution to the case with one or more of the above mentioned parties.
You are also a "tuner", correct?
So many modders have more cents than sense!
Rampage is offline
The Following 4 Users Say Thank You to Rampage For This Useful Post:
86_Insider (08-15-2013), cuddefred (08-15-2013), Sportsguy83 (08-15-2013), wrb (08-16-2013)
accelerated, because visconti, boo-urns, brz, burn my ride(no pimp), burning man 2013, car-b-que, don, e85, fire, firefighter, flex fuel kit, he'sonfire!, here lies johns career, hlppreventfrsfires, if it doesn't fit, if the hose fits, john, marshmallow tuned, nobody got time fo dat, not tight enouf, oh lord jesus its a fire, roasted brznuts, tag orgy, that's hot, toasty!, toma <3 visconti 4 eva, toma is an asshole driver, tuning, user install error, v-tune kicked in yo, viscan't tuning, visconti, visconti roast, visconti-hunt, viscontifried, viscontinguished!, vtuning evisceration, you must acquit!, your fired!
Whiteout FRS on FIRE! 636 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 29 07-12-2019 10:41 PM
Fire Extinguisher sw20kosh Tracking / Autocross / HPDE / Drifting 5 08-08-2013 04:28 PM
Brakes on Fire! clickfiveZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 07:57 PM
Toyota 86 catches fire calis5nest FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 05-06-2013 11:36 PM
Fire Safety zaptorque Off-Topic Lounge [WARNING: NO POLITICS] 11 04-05-2013 03:55 PM
