#15 | |
I really don't understand why people upgrade their wheels and tires and don't put as much rubber on the ground as possible. Turning faster is more fun. But to each their own. I'm certainly not going to tell someone their car isn't fulfilling it's "purpose." [ame="http://www.youtube.com/watch?v=yJJA6WRpvlg"]The Jerk (8/10) Movie CLIP - Navin's Special Purpose (1979) HD - YouTube[/ame]
| The Following User Says Thank You to qoncept For This Useful Post: | BlaineWasHere (08-15-2013) |
#16 | |
i'm sorry, what?
Drives: Canada
street tires, limited by wheel diameter, do not benefit from going wider. A6s on the other hand...
#17 |
Grip>Drift
Drives: FRS
I'm not running rims. I do however have 17x9s with ZIIs mounted currently.
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | Jaylyons1 (03-16-2014) |
#18 |
Drives: 2013 Hot Lava FR-S 6 MT
Having been to only one AutoX on my new setup of 18x9 +45 TE37SLs with 255/35 Direzza ZIIs, I can say the confidence in high speed cornering was huge to me ...
That said - I couldn't offer what is fastest. I'm sure the guys going for gold each lap have better information, and they seem to run 17x9 tires from what I have read ... My wheels have almost identical weight compared to stock, however the rotational mass distance I haven't calculated. I will say this, my circumference is almost dead on to stock as my aspect ratio on my tire 255/35 matches up with the stock tires. The variance on rotational mass distance seems like it would be a very, very small percentage.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
#19 |
i'm sorry, what?
Drives: Canada
so you're in STX?
#20 |
Grip>Drift
Drives: FRS
#21 | |
Drives: Some rust bucket
http://www.cicenet.net/showthread.php?t=11708 Look at the optimal wheel size section. I'm sure @CSG Mike has tested 245/255 tires. They just found out that 225 yielded the fastest lap time. It doesn't necessarily produce the most grip, but it produced the fastest lap time, and that's all that matters. Off the top of my head, I recall Mike saying that a benefit of the wider tires was the ability to run more laps without the tires overheating. The 225 tire was more of a one lap wonder type of tire. Obviously track and autox cars will have a different setup. You just have to find what's best for you. |
| The Following User Says Thank You to ayau For This Useful Post: | John.Hong (08-15-2013) |
#22 | |
Drives: Scion FR-S
It's pretty easy to see why wider isn't necessarily better on a light car on a track with any decent straights. More weight and rolling resistance could slow you down more in the straights than it helps you in the corners. Sent from my SCH-I535 using Tapatalk 4 |
#23 |
Grip>Drift
Drives: FRS
If be interested to see what Mike has tested on the track!
I think once you're at the full bolt on level (210WHP over stock 175) would help you be faster on wider tires with more resistance. But this is something that's not really been scientifically tested I'd bet. Obviously once you're at FI power levels wider is always better with power to spare.
#24 | |
Drives: 2013 Ultramarine Frs
![]() Wider width will create grip whilst compromising weight slightly if at all. Sure straight aways matter but I believe the corner is where you make up for the time. For me with 255/35 on 18x9.5, I didn't lose much responsiveness if at all. If anything I gain a lot more controlability through corners and helluva lot more grip. If i have no grip, i could care less how much resposniveness i still have. |
| The Following User Says Thank You to John.Hong For This Useful Post: | ftc~brz (08-15-2013) |
#25 | |
i'm sorry, what?
Drives: Canada
with a wide tire and a car that rolls, you'll end up using only a portion of your tire during the time for which you got the wide tire in the first place it's all a system the higher up the ladder you go the more specific your tuning has got to be.
#26 | |
#27 | |
i'm sorry, what?
Drives: Canada
STR and STX will allow you to use a wheel up to 9" and a tire up to 255 (or maybe even 265... i might be thinking of STU) furthermore, if you're currently running in C-Stock, you should be running on A6s, and when it comes to the black crack it has been proven that wider is better, 255 A6 on a 7" ain't no problam. See, this is the problem with auto-cross discussions. People are too focused on their own class to handle a general discussion on tire choice. OPEN YOUR MIND PEOPLEZ
#28 |
I've tested 235/245/255 tires as well at this point. Generally 225 is the fastest. However, on courses that have few or very short straights, wider tires are faster. E.g. SoWS is faster on a 255.
I wouldn't be surprised if 255 is generally fastest on an AutoX course. *edit* While CSG has not purchased wider tires for me to try, I've used my own 255's on the BRZ before, and I've driven countless other FRS/BRZ with varying setups, and keep notes on the setups and results. I would never consider anything less than 255 on my s2k (and yes, I almost "pinch" them on my 8.5" rims). Last edited by CSG Mike; 08-15-2013 at 01:08 PM. |
| Staggered or Square? | tdoggy57 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 09-26-2014 07:55 AM |
| Square vs staggered setup | slowbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 05-11-2013 10:18 PM |
| Wheel Directory: WedsSport TC105N 17x8.0 +42 / 17x9.0 +35 | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 56 | 03-08-2013 12:10 PM |
| Staggered vs. Square | WWEVOX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 01-12-2013 03:57 PM |
| Square or Staggered? | dabocx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 44 | 02-02-2012 09:40 PM |
