Old 08-13-2013, 10:18 PM   #127
Ndgreely
Ndgreely's Avatar
Drives: 2013 FR-S 2003 SRT-4 1964 Impala SS
Roughly how much lower did it make the car? I ended up going with the tein s-tech springs which I think is about the same a your sportlines and wheel and tire combo is pretty close too .. 18x8.5 +44 and 18x9.5 +44 with 225/40 and 255/35 . Also car came from dealer with the mudguards which I didn't care for at first but now that I have black wheels I was gonna shoot for a white and black color scheme .. To have the lip kit they would need to go .. But with the wheels I feel like they are saving me from rock chips .. Thoughts ?? And did you have to have any work done to them before paint ?
Ndgreely is offline   Reply With Quote
Old 08-13-2013, 10:35 PM   #128
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Originally Posted by chadstyle View Post
What additional mods did you added for the 93 octane run? Was it just the Borla UEL with a tune?
LeeMaster is offline   Reply With Quote
Old 08-13-2013, 11:01 PM   #129
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
It probably makes the bottom of the car about 1-1.5" closer to the ground. I haven't had any rock chips at all on my car but I don't drive on gravel roads either. I personally don't like the look of mudguards on these cars but that's just me. Lastly, I didn't paint the lip kit..installed as is.
chadstyle is offline   Reply With Quote
Old 08-13-2013, 11:30 PM   #130
Ndgreely
Ndgreely's Avatar
Yea I agree didn't really care for the mudflaps they just kinda grew on me .. But for the price of that kit , and not having to paint it ! That's a huge plus !! So I can deal with losing them .. Thanks again !! Awesome progress on your ride btw .. I've been keeping up with it ..
The Following User Says Thank You to Ndgreely For This Useful Post:
chadstyle (08-14-2013)
Old 08-14-2013, 07:46 AM   #131
chadstyle
chadstyle's Avatar
Mods are the same for E85/93 octane.
Borla UEL
Perrin Overpipe
Perrin Front pipe with high flow cat
Perrin resonated 2.5" catback
Perrin CAI with Silicone intake tube
Perrin crank pulley (doubt it made a difference in power)
FA20Club.com 93/E85 tunes
Old 08-14-2013, 07:56 AM   #132
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Some pics from a photoshoot this morning...enjoy!
Every time..... really every damn time I see your car I regret it once more that toyota does not offer this color on the GT86 ;-)
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Old 08-14-2013, 08:11 AM   #133
chadstyle
chadstyle's Avatar
Thanks bro! I have the same envy for your car
The Following User Says Thank You to chadstyle For This Useful Post:
Killerbee (08-14-2013)
Old 08-14-2013, 08:20 AM   #134
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
Chad your style is killer like my own... looking at your car makes me want a BRZ even more!
Sbeezy is offline   Reply With Quote
The Following User Says Thank You to Sbeezy For This Useful Post:
Old 08-14-2013, 08:13 PM   #135
chadstyle
chadstyle's Avatar
Thanks I appreciate it!!
Sbeezy (08-15-2013)
Old 08-15-2013, 10:36 AM   #136
loogs
Drives: on cruise control
Attachment 33116
And here's a pic of my hot mechanic's assistant helping out on the install...
Man, I'm lucky...
OMG, you need to show us the better angle
loogs is offline   Reply With Quote
Old 08-18-2013, 04:56 AM   #137
Alfalasy
2013 BRZ
Alfalasy's Avatar
I was strongly considering a supercharger but I'm having second thoughts similar to your reasons to decide on turbo, also we have here hot and humid weather I'll be very interested to know how it goes from your side. Thanks for the updates and I hope it will work out as you wanted.
Alfalasy is offline   Reply With Quote
The Following User Says Thank You to Alfalasy For This Useful Post:
chadstyle (08-18-2013)
Old 08-18-2013, 11:50 AM   #138
chadstyle
chadstyle's Avatar
Ok, so I did a really simple mod yesterday that I have wanted to do for a while and never got around to it. Last week I saw that a vender has 4th brake light kits for sale on the forums. The prices were high but he said to PM him for actual pricing shipped. I asked out of curiosity and he replied "$126 shipped"...THAT'S ROBBERY!! I almost fell over. I'm all for making a buck but that is just wrong. I did the same exact mod and I'd be willing to bet that mine looks even more OEM than the kit he sells and the entire project cost less than $20 and took less than 2 hours time to complete. All parts can be found at Pep Boys. This isn't intended to be the full DIY but I wanted to share the parts I used so hopefully others can save some $$ too.
First, I bought two Honda 194 sockets from Pep Boys as they're readily available and properly sized for the project. You CAN use a dual filament setup instead of using two smaller bulbs like I did but you may have to order a socket/bulb as my local Pep Boys didn't have them in stock. I then soldered and heat shrunk the wires and made a 6 foot harness to run up to the drivers side brake light. Here is a picture of the harness before tape.
As you can see, I used two bulb sockets so I have tail/running lights as well as brake lights. I then taped up the harness so it looks nice and clean and is easy to insert into some split loom once installed on the car. Here is a pic of it all taped up.
Next, using a UniBit (stepped drill bit), I drilled two holes large enough for the center part of the sockets to fit in. I then used a file to make the four notches on each hole for the socket to turn and lock in place. Take your time..it took me about 20-30 minutes to do all 8 notches but the sockets lock in place nice and snug just like an OEM connection. You don't want any moisture or water droplets getting in the housing. My housing is smoked so it wouldn't be as noticeable but the clear housing will show all the moisture. I used an air compressor to blow out all the plastic shavings that fell inside the housing while drilling and filing. Here is a pic of both of the holes and the locations I drilled them.
Lastly, here is a picture of the bulbs mounted in the housing for final fitment before installing in the car.
After mounting in the car I ran the wires along the factory reverse light harness towards the drivers side tail light. I removed the drivers side tail light and reached down behind the carpet panel to feel for the grommet where the wires enter the car. I removed the grommet and sliced it just enough for the 3 wire harness I made to come in through it snugly. After running the wires through the grommet I pushed it back in place. I then connected all three wires near the brake light plug. I used the Red and Green wires for tail light and brake light signals and the black wire as ground. I then put everything back together making sure to plug in the brake light harness and not to over torque the bolts that hold the brake light in place. I tested it out and it works perfect. I will most likely order some LED bulbs to replace the standard bulbs but only for the longevity of them. I saved over $105 by doing it myself. The kit would still have you drill the holes for the sockets and run all the wires so I imagine the install time would be almost exactly the same.
Hopefully this helps a few of you save some $$ and enjoy a fun and easy project on your 86.
The Following 5 Users Say Thank You to chadstyle For This Useful Post:
ftc~brz (08-22-2013), Hyper4mance2k (02-21-2018), RidetheTran (08-22-2013), stock (04-10-2014), zAnSh1n (05-03-2014)
Old 08-18-2013, 12:16 PM   #139
FR-S FI
FR-S FI's Avatar
Drives: 2013 MT FS FR-S / 07 GT500
Mad near OEM notching skillz there Chad, Bravo!!! now that you've set the bar I'll have to follow suit. Thanks for this one, I've been wanting to do this, just needed the right catalyst...
Stage 1 V2 .57trim Turbo Kit, ACT HD6P Clutch w/Streetlite Flywheel, Greddy EVO3
391whp/295tq 13psi 96 pump
335wh
p/260tq 10psi 93 pump
FR-S FI is offline   Reply With Quote
The Following User Says Thank You to FR-S FI For This Useful Post:
Old 08-18-2013, 12:17 PM   #140
Vten
Drives: Too heavy
just happened to check on your built page Chad ...awesome !! nice car , nice lift and nice wifey too :P
I wished I live close by FA20Club too , I would've sent my car straight from the dealership ..lol
Vten is offline   Reply With Quote
The Following 2 Users Say Thank You to Vten For This Useful Post:
chadstyle (08-18-2013), MadFRS (08-18-2013)
