Old 08-12-2013, 09:28 PM   #15
ft86me
ft86me's Avatar
Drives: 2013 FRS
currently running a koyo radiator with a perrin oil coiler. fit perfectly fine with my vortech kit
ft86me is offline   Reply With Quote
The Following User Says Thank You to ft86me For This Useful Post:
jack43 (08-13-2013)
Old 08-13-2013, 12:02 AM   #16
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
Same here.. this combo works great
jack43 is offline   Reply With Quote
The Following User Says Thank You to jack43 For This Useful Post:
ft86me (08-13-2013)
Old 08-13-2013, 12:01 PM   #17
robispec
Drives: Black frs project
if you have tight fitment issues and
whatever oil cooler you want you may like our take off plate.
drilled for sensors too
no thermostatic option available.
robispec is offline   Reply With Quote
Old 08-13-2013, 12:04 PM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Damn Robi....
I can't wait to get it, install it and run it!!
That shit looks SICK!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
robispec (08-13-2013)
Old 08-13-2013, 12:34 PM   #19
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Do you think a thermostat is necessary ?
Old 08-13-2013, 01:06 PM   #20
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Well.... there might be a slight modification needed to the Condenser brackets depending on what IC you have, but nothing major and yes it should fit.
@robispec can chime in. He has already done a few for some Boosted and IC cars.
David, let me know how the install goes, very interested. Thanks in advance.
Ny Brz is offline   Reply With Quote
The Following User Says Thank You to Ny Brz For This Useful Post:
Sportsguy83 (08-13-2013)
Old 08-13-2013, 01:30 PM   #21
Dezoris
Dezoris's Avatar
Yes if you car is a street car you need to have a thermostat. Or your oil temps will never reach a normal level.
Old 08-13-2013, 04:12 PM   #22
jamesm
nothing at all.. boosting on all stock cooling. i live in florida lol. it's actually worked quite well just driving on the street, temps havent changed a bit since before the turbo. oil is still too hot, but then it already was before (230ish).
Old 08-13-2013, 08:27 PM   #23
SkullWorks
Drives: SSM LT MT BRZ
tsk tsk...
if you are using a liquid to air oil cooler you need a thermostat...if you are going liquid to liquid...ala robi spec solution none is needed, water temp will bring oil up to temp faster.
You can always install an inline thermostat if needed, the units that are scaled down to fit in small applications are...well less than ideal in operation for my money.
The Following 2 Users Say Thank You to SkullWorks For This Useful Post:
Ny Brz (08-13-2013), Sportsguy83 (08-13-2013)
Old 08-13-2013, 09:12 PM   #24
Dezoris
Dezoris's Avatar
Originally Posted by SkullWorks View Post
tsk tsk...
My comment pertained to liquid to air coolers since thats the most common type of cooler. Thanks for expanding.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 08-13-2013, 10:04 PM   #25
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Robispec waiting to go in...
Robispec Radiator/Oil Cooler combo sw20kosh Engine, Exhaust, Transmission 86 06-16-2015 07:56 PM
Mishimoto Oil Cooler - Anyone running one? swift996 Engine, Exhaust, Transmission 34 05-28-2014 10:07 AM
1.1 vs 1.3 Radiator Cap JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 01-21-2014 01:21 AM
Koyo Radiator vs Oil Cooler Captain Snooze Engine, Exhaust, Transmission 54 06-21-2013 11:18 PM
Hot side of radiator? wootwoot Engine, Exhaust, Transmission 4 05-30-2013 06:50 AM
