Old 08-12-2013, 01:16 PM   #547
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by dabocx View Post
Its the subtle way of kicking you out of the thread....its prob because your not going to tx2k
At this point, he will probably never make it either.
I did just yesterday read about FL2K13 in Bradenton later this year. There are only two things in Texas, and neither are fast cars. At least I hit the drag strip on Saturday.
King Tut is offline
Old 08-12-2013, 04:02 PM   #548
JerryMichaels7
Drives: Whiteout FRS
time slip or it didn't happen ^
JerryMichaels7 is offline
Old 08-12-2013, 07:45 PM   #549
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by mid_life_crisis View Post
This seems counter-intuitive. Can you please explain?
Think about the shape of a connecting rod, during compression of the rod all of the force is distributed along the rod half of the big end bearing. When the rod is in tension all of the force is distributed along the cap half of the big end bearing. If the bolts are parallel to that force, they take all of it. By rotating the break line for the cap, the bolts no long take all of that force in tension which can make the overall assembly stronger. This wont really help the engine make more power at the present rpm limit, but it will make the rods able to withstand higher rpm as they'll be less likely to separate while trying to slow the piston as it approaches top dead center.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
Sportsguy83 (08-12-2013)
Old 08-12-2013, 07:52 PM   #550
Calum
That Guy
From a basic mechanical perspective, in a standard arrangement, the stress on the rod bolts is primarily stretch (lengthwise) from the part of the cycle when the crankshaft is pulling the rod/piston down in the cylinder. The rest of the time the force is squarely against the base of the connecting rod, either from the crankshaft pushing up or the piston pushing down. Under those conditions, all the bolts are doing is holding the rod end in position so the bearings don't move.
Tilting the rod end adds shearing stress (across the bolt), so yes, it would seem that this layout is harder on the bolts. Depending on the angle, it could also put shearing stress on the bolts whether the force is from the crank pulling or the piston pushing.
I see what you're saying here. What you need to add to that though, is that the forces aren't directly added together and the sheer stress is less then if the cap was perpendicular to the forces. Also the bolts should be able to handle that sheer better then the tension.
If you add in the cracked caps that are common on powdered rods, there is actually very little (comparative) sheer stress making it to the bolts.
Calum is offline
Old 08-12-2013, 09:05 PM   #551
Frs300
Frs300's Avatar
Drives: Pile of junk
Originally Posted by Andy@FA20Club View Post
you got access to the pics of my car that toni has? its killing me i want to see the car already. Im about to drive down just to look at it
Frs300 is offline
Old 08-12-2013, 09:14 PM   #552
Andy@FA20Club
Drives: FA20Club.com
I'm in the office this week to get these Flex Fuel Kits out.
Andy@FA20Club is offline
Old 08-12-2013, 09:24 PM   #553
Frs300
Frs300's Avatar
damn no love at all lol
Frs300 is offline
The Following User Says Thank You to Frs300 For This Useful Post:
lbroskee (08-12-2013)
Old 08-12-2013, 09:40 PM   #554
Andy@FA20Club
j/k we got you.
Old 08-12-2013, 09:46 PM   #555
Frs300
Frs300's Avatar
j/k we got you.
snap snap got few 100 ppl waiting. im kidding...must be sending out a lot of flex fuel kits if your at the office this late.
Frs300 is offline
Old 08-12-2013, 10:09 PM   #556
lexusb3
Drives: FRS
I'm on the list for one lol flex fuel kit
lexusb3 is offline
Old 08-12-2013, 10:25 PM   #557
dabocx
dabocx's Avatar
Drives: Scion FRS
Derailing this thread.......Dates for Tx2k are up
dabocx is offline
Old 08-12-2013, 10:28 PM   #558
Frs300
Frs300's Avatar
they will run out before you get one
Frs300 is offline
Old 08-13-2013, 06:05 PM   #559
King Tut
NASA SpecE30 Racer
King Tut's Avatar
King Tut is offline
swift996 (08-13-2013)
Old 08-13-2013, 06:34 PM   #560
Frs300
Frs300's Avatar
not bad
Frs300 is offline
#car in litigation?, #ferris bueller ferrari?, 12 year build, 5 month engine build, are we there yet?, edging, fantasy, innovate thread pt.2, its happening!!!!, keep calm and carry on, maybe tomorrow?, not today, not viscontiqued ftw, the neverending build, unicorn!, vaporware
Full Blown Stage 1 Short Block FullBlown Forced Induction 116 03-22-2019 07:29 PM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 12:54 PM
2013 FR-S / BRZ (The R&D has Begun) Cotnoir CANADA 10 06-26-2012 03:08 PM
PM Spammers, it's begun! Beast Off-Topic Lounge [WARNING: NO POLITICS] 11 01-30-2010 01:13 PM
