go_a_way1
Old 08-12-2013, 11:44 AM   #1667
tinma
Drives: '13 BRZ
Hi everyone,
I have a question about a staggered setup that I am interested in.
Rims:
Enkei Tuning Raijin
18x8 +45mm / 235/35-18(Front) (also have the option of going 18x8.5)
18x9.5 +45mm / 255/35-18(rear)
I will be staying with stock suspension so I will be at stock ride height.
How will this setup look on my car?
will I experience any rubbing from the tires and the suspension?
will the tires have a lot of poke from the fenders? im trying to keep it looking flush.
Will this setup negativily effect my cars performance?
Sorry for all the questions. First time buying new tires and im trying to make sure im staying safe.
Thanks in advance for all the help!
tinma is offline   Reply With Quote
Old 08-12-2013, 12:04 PM   #1668
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by tinma View Post
Hi everyone,
Rims:
Enkei Tuning Raijin
Figment is good. No rub at stock height or lowered.
Wheel and tire combo is (most likely) heavier than OEM setup.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-12-2013, 12:25 PM   #1669
tinma
Drives: '13 BRZ
for 18x8 the weight is 20.6lb (18x8.5 -20.8lb)
18x9.5 is 20.5lb (not sure how the rears r lighter...lol)
If i went with 18x8.5 fronts, am i still free from rubbing? also if i switch the rubbers to 225 for the fronts?
im not too sure what the specs r on the OEM setup, ill do a search right now tho
Old 08-12-2013, 02:14 PM   #1670
Erik-Frs
Drives: 2013 FRS asphalt
just ordered my FRS to pick up tomorrow and trying to preorder 19"s.
Stock offset is 48mm?
The 19"s i want to order are 19x8 with a 35mm offset.
anyone know if this will be a problem? The car is NOT lowered.
pleaseee help!
Erik-Frs is offline   Reply With Quote
Old 08-12-2013, 02:50 PM   #1671
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
You can fit a 245 on the front, 255 without issue on the rear, even 265.
We discussed this exact setup on the previous page. See itdansharpe's sig.
Slick is offline   Reply With Quote
Old 08-12-2013, 02:52 PM   #1672
Slick
Slick's Avatar
pleaseee help!
Should be fine depending on the width of tire you choose.
Old 08-12-2013, 03:17 PM   #1673
djdnz
1337
Drives: 2013 BRZ WRB S/C
pleaseee help!
Should be fine. Pick 235/30/19 or 225/35/19 or 225/30/19.
They should be pretty close to flush in the front at stock height.
djdnz is offline   Reply With Quote
Old 08-13-2013, 04:29 PM   #1674
svodka
Drives: 2013 BRZ 6MT
Hey guys I'm looking into the following setup:
17x9 +45 enkei kojins on stock suspension
245/40/17 tires
I've done a lot of reading and it sounds like I may need a spacer to make this work on stock suspension in the front. I was looking into adding a 10mm hubcentric H&r spacer to the front wheels to add clearance from the strut. I am not concerned with flushness or poke, as long as it has enough clearance to fully lock the wheel with no rubbing.
I will eventually drop it ~1" or so but not right now. Likely just springs, not coilovers. I'll worry about correcting the camber later. Any input would be great. Thanks!
svodka is offline   Reply With Quote
Old 08-13-2013, 04:37 PM   #1675
itdansharpe
itdansharpe's Avatar
Sounds like you've done your research. I don't think the 9" +45 will fit up front on stock suspension.
245/40/17 tires
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 08-13-2013, 05:21 PM   #1676
svodka
Yeah, I've seen some success with +35 in the same size which is why I thought maybe a spacer would work, but I'd rather be safe than sorry.
Old 08-13-2013, 05:57 PM   #1677
itdansharpe
My only concern with adding a 10mm spacer would be that you lose 10mm of thread on your lugs. Should be fine, but I'm not the one to ask regarding this.
Old 08-13-2013, 06:08 PM   #1678
Slick
Slick's Avatar
^^ This...
Also, would suggest if you run spacers to run them in the rear also.
The rears are already more tucked in than the front, so it may look odd if your fronts are flush (with spacers) but the rears are tucked in.
Old 08-13-2013, 06:31 PM   #1679
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
From all I've read (and will soon find out) is that with stock struts and a 9" wide rim, you need 42mm offset for "safe" clearance. If you go with anything more than a 3mm spacer, you'll need longer studs too.
boarder1995 is offline   Reply With Quote
Old 08-13-2013, 11:01 PM   #1680
Iddoit2er
Drives: S
Just got a set of 18x8.5 +35 square set up. I'm not sure if I want to go 225 or 235, so I will likely try both: 225/40/18 F and 235/40/18 R - I can always just buy two new tires. I also will likely have a set of Eibach Sportline springs (-1.4") in the mail this week, going to coils before Winter. I also will want to bring camber as close back to spec as possible.
Any issues?
Also, I want to bring the rear wheels out close to flush - maybe 10-15mm? For that adjustment, I saw that adapters (as opposed to spacers/bolts) would be a better option? Haven't really found too much on people running with adapters. Input?
Iddoit2er is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
