Old 08-08-2013, 08:36 AM   #57
Frstorm
Drives: 2013 Firestorm
My jeep has them and I turned the feature off so I don't mind at all.
Frstorm is offline   Reply With Quote
Old 08-08-2013, 08:52 AM   #58
Mikem53
Drives: FR-S 6MT
Originally Posted by KyleGato View Post
My headlights being on reduces my fuel economy? tf
Yep.. No free ride.. The alternator will cause more drag on the engine to power the lights..
Mikem53 is offline   Reply With Quote
Old 08-08-2013, 11:29 AM   #59
MotorboatinSonOfA
MotorboatinSonOfA's Avatar
Drives: 2013 Scion FR-S - Raven MT
It's a feature that is still to this day advertised as a STANDARD FEATURE. not once did anyone say that this auto off feature being non-existent in the US version FR-S is ruining their life.
However, people do make mistakes and I'm sure someone in this thread will at some point forget to turn off their lights and when they do, the battery will discharge for 20 minutes (until it automatically shuts off). Something that shouldn't be happening because this feature should have come with the car. This isn't a discussion about how difficult it is to turn off lights. I don't know about you but I don't want my battery discharging for 20 minutes in circumstances where the lights are accidentally left on
Edit: I just got off the phone with the manager that is the highest up apparently and he said that the auto off feature does exist in the form of the automatic battery disconnect after 20 minutes. I'm going to see if it's worth filing a complaint with the BBB. the auto off feature is still listed on scion's website. Has anyone here already done this. I believe I would file it as false advertising right?
Sent from my SPH-L710 using Tapatalk 2
MotorboatinSonOfA is offline   Reply With Quote
Old 08-08-2013, 01:18 PM   #60
MotorboatinSonOfA
Getting this back on topic, I'll post here after I reach out to the BBB. if anyone has any tips please let me know. Unfortunately the monroni sticker in my car didn't list auto off headlights as a feature but the scion website still shows it as a standard feature
Old 08-09-2013, 12:15 AM   #61
MotorboatinSonOfA
Originally Posted by Jawnathin View Post
Quick question - What is your expectation of this Auto Off Feature?
1.) Are you looking for Automatic Headlights? And by that, I mean, they are 'smart' and turn on when its dark and off when its day time/car is turned off. This is a 'set it and forget it' setting as they're controlled automatically.
2.) Or are you looking for just Automatic OFF, as in, you must manually turn on the headlights when you want to use them, but in an instance where they're on and you turn off the car, they turn off with the car? This will require manual control everytime you want to turn them on though. If left in the 'On setting', it would just be On when you start up the car, regardless of day/night
I do think for option 1, there would certainly need to be a switch or option on the light switches. This way it can be switched from On/Off/Automatic modes.
For option 2, I don't think any sort of switch should necessary. The car just needs to kill power to the lamps when the ignition is set to off. Clearly there needs to be SOME logic to enable/disable when needed, but I wouldn't expect it in the form of a manual switch or lever.
Option 2 would be great but most vehicles that have automatic off headlights actually have a separate 'Auto' setting on the stock which turns on the headlights, etc.
I don't believe it's possible to change a setting on the FR-S that would simply enable the auto off feature
Old 08-09-2013, 12:17 AM   #62
Luis_GT
I feel like I'm writing in german or something...
Old 08-09-2013, 02:43 AM   #63
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
That's the oddity. On the 10 series there is an auto choice on the stock. So why they didn't use it for the stock FR-S is beyond me.
oldpueblo is offline   Reply With Quote
Old 08-09-2013, 02:47 AM   #64
Luis_GT
Easy... it's cheaper... which is the point of the FR-S, the 10 series is a special edition, thus they chose they high end model vs the base model.
They saved money on headlights, and eliminated the whole photosensitive system...
Old 08-09-2013, 03:43 PM   #65
There's really nothing to file a complaint about here. The car HAS the advertised feature, it's just not the feature you (and I) thought it was. It's not even really a misrepresentation unless you asked for clarification and they told you something different than what it is.
I've moved on, I suggest everyone else do the same.
Old 08-11-2013, 07:32 PM   #66
MotorboatinSonOfA
It has a battery protection feature that I believe shuts off any power going to the car. Although that in effect turns off the lights, you can't say that calling that feature "auto-off headlights" isn't misleading. However, I really don't think I have as strong of a case I thought because the auto-off headlight feature isn't even listed on my Monroney sticker.
Saying that the FR-S has the auto-off headlight feature would be like saying that your house has automatic lights that shut off after 20 minutes, but instead of only the lights turning off, all power to your house is shut off after 20 minutes.
I get what your saying though, because of technicalities, I feel it would be very difficult for even someone with the feature listed on their Monroney sticker to get the actual feature installed
Old 09-02-2013, 02:47 PM   #67
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Thumbs up TechStream confirmed
I have the EU Stalk on a Scion FRS, the front fogs work great, I will be running the wiring for the Auto portion of the stalk to take advantage of the Auto Headlight Off after 30 secs. The TechStream showed the FRS already had the 30 sec Auto Lamp Feature enabled. I can attest it won't work without the Auto Stalk and Auto Dash Light Sensor and all supplemental wiring hardware . I used TechStream to shutoff the Passenger Seat Belt Warning Buzzer, so my daughter can leave her school backup, purse, iphone etc on the seat without setting off the alarm. It also works great for Ecutek Data logging withoout the laptop setting off the alarm.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-02-2013, 07:19 PM   #68
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Originally Posted by ae86stunt View Post
Really, Who the $&^% cares?
Its a Road going drift car.....
To me it was frustrating because after having the feature in the 16k tC and getting used to it for 8 years, I was surprised to not see it in my 25k FR-S.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 09-02-2013, 10:14 PM   #69
Rumbaar
Victim's aren't we all
Rumbaar's Avatar
Drives: Toyota GTS 86 - Pegasus White
Strange the Australian GTS model has this as standard. Set the lights to AUTO, they turn on when it's dark and turn off once I open the door after turning off the car.
Rumbaar is offline   Reply With Quote
Old 09-03-2013, 09:13 PM   #70
cfusionpm
Understandable. My 06 accord has leather heated seats, Satnav/xm, a stock 400 watt stereo.. sunroof, auto head lights. Ect...
I gave it up to the wife for the FRS. The only features I considered were.
RWD, 6 Speed manuel, 50/50 weight distribution.
And that's what this car is. Not to mention the feeling of being in a race car just siting still...
Oh no, I get that. And after seeing the 2nd gen tC lose little things like all-auto windows (up/dn, driver/passenger), I'm not exactly surprised. Seems like it's a simple no brainer to include though, and it was one less thing to have to think about.
True or False monkie Off-Topic Lounge [WARNING: NO POLITICS] 231 02-05-2013 06:55 PM
Auto-Off Headlamps nktech Scion FR-S / Toyota 86 GT86 General Forum 12 12-10-2012 09:51 AM
Toyota Advertising Complaints nzer Off-Topic Lounge [WARNING: NO POLITICS] 21 08-31-2012 08:35 PM
False Advertising Mike Sino BRZ First-Gen (2012+) — General Topics 8 07-15-2012 03:59 PM
