Old 08-08-2013, 08:33 AM   #29
Snake
Drives: ADM Toyota 86 GT
Way to bump an old thread but has anyone heard anything on what Cosworth are working on? Their website doesn't say much apart from that they are working on the FA20.
Snake is offline   Reply With Quote
The Following User Says Thank You to Snake For This Useful Post:
zephyr69 (08-08-2013)
Old 08-08-2013, 11:06 AM   #30
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Originally Posted by cossey View Post
Fly Wheel Horse Power?
lol Typically in the USA we label FWHP as SHP or Shaft Horse Power just to avoid this bit of confusion. xD I can see why others got confused must just be a difference in terms between us and the Brits like usual!
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 08-08-2013, 11:15 AM   #31
swift996
swift996's Avatar
I happened to be on their website last night clicking around and seeing if they had anything. They do some great work but probably not the type for most people on the forums.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-08-2013, 01:12 PM   #32
mid_life_crisis
Drives: FR-S 10 #103 AT
More commonly Brake horsepower in the states. Some call it Crank horsepower because it is measured at the crankshaft. I've never heard Shaft horsepower myself, but I don't claim to have heard it all.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-08-2013, 01:46 PM   #33
mid_life_crisis
Originally Posted by 7thgear View Post
throttle by wire is only a limitation if you want to keep the stock programing
people jumping over to ITBs are likely to run stand alone so whether the throttle operation is electronic or mechanical is of no concern.
you can most likely drop in a mechanical pedal and call it a day.
more work sure, but at the level of prep where ITBs come in the car is probably in pieces anyway.
Nah, you would have four throttle bodies (duh), each with its own MAF and install individual exhaust probes per cylinder. A carefully designed and adjusted manual linkage would cause all four throttle bodies to open the same amount, actuated by the throttle by wire system. There would be a secondary ECU. The secondary ECU would monitor the four intake and exhaust sensor pairs as well as the throttle position and control the injectors.
This would allow the ultimate in mix control: optimized per cylinder. It could also constantly compare the four MAF values and send up a flare if the values got too far apart for some reason (probably mechanical failure in the linkage).
Old 08-08-2013, 04:23 PM   #34
mike the snake
Too bad we don't use carbs any more. The carbs on my old Porsche (50mm PMO carbs) actually made slightly more power than the equivalent FI, but weren't nearly as efficient. Sexy as hell though no doubt!
Some nice 2 barrel down-draft Webers and a throttle cable, some extra time figuring out jetting, no way it would pass smog but it might work for a track car?
http://hargettprecision.com/index.ph...che-itb-s.html
I can't see many people buying something similar for this car at that cost. Would it be so f'ing cool? Yes. The reality is that the flat engine is rather expensive to engineer certain parts for. Porsche is the only other manufacturer still using them and their engines are on another level, including cost-wise. However, if an ITB setup were to come to market for a flat 4 Subaru engine this would be the platform I'd expect to see it in, given the limited application in a F/I setup.
EDIT: This car, from what I've seen, has throttle-by-wire. That means an ITB setup gets that much more complicated since you don't have a simple mechanical link between the pedal and throttle body. Some kind of electronic mumbo-jumbo would have to be figured out in regards to the electronic motor that actuates the throttle body, or in this case, 4 ITBs. I simply don't see that kind of research and development going into this platform.
What is this a muscle car? You got something you want to talk about? I don't need to make my car LOOK tough...
I'd rather see something like this:
The Following 3 Users Say Thank You to mike the snake For This Useful Post:
bestwheelbase (08-09-2013), Hyper4mance2k (05-26-2015), Turdinator (08-08-2013)
Old 08-08-2013, 10:20 PM   #35
Turdinator
Señor Member
Turdinator's Avatar
Is there any reason why you couldn't butcher a stock throttle for the elctronics and hook the stepper motor to a linkage controlling four throttles with a large common plenum and the stock maf just after the filter? There would have to be some maf scalling but i believe ECUTEK can handle that...
P.S. @mike the snake that is a sexy setup
1974 TA22 Celica
2013 86 GT
Old 08-09-2013, 12:06 AM   #36
Boil
Drives: CX500 Cafe Bobber
Nice & clean looking 916…!
I had a dual Weber 40 IDF setup on my VW Thing back in the day, nothing sexier than a bank or two of Webers with velocity stacks…!
Boil is offline   Reply With Quote
Old 08-09-2013, 05:33 AM   #37
cf6mech
Drives: FRS Silver LS1 swapped.
The only place I have heard SHP (shaft horsepower) is in Turbo prop aircraft engines.
cf6mech is offline   Reply With Quote
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
ft_sjo (08-09-2013), Ruckus (08-09-2013)
Old 01-24-2014, 01:12 PM   #38
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Has there been any updates on this? Nameless announced a couple months ago that they have partnered up with Cosworth. Maybe @Jason@Nameless could give an update as to when we can expect to see something?
ToyoburuBRZ is offline   Reply With Quote
Old 01-24-2014, 02:46 PM   #39
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
Interesting
Mathewgzlz is offline   Reply With Quote
Old 01-25-2014, 11:37 AM   #40
zooki
Drives: waiting on a 2021...
Umm, yea...right after they release that header.....LOL
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Lonewolf (01-25-2014)
Old 01-25-2014, 11:44 AM   #41
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
I would be interested in Cosworth internals/parts as I go turbo.
AVodka14 is offline   Reply With Quote
Old 01-26-2014, 11:59 AM   #42
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
They have released it.
Also, I sent a message to their FB page and got this as a reply this morning:
So they're still working on them, that's not much of an update but at least they said that much.
EvilBeaverFace is offline   Reply With Quote
GT86 Confirmed Pricing Jayvelliott Scion FR-S / Toyota 86 GT86 General Forum 42 01-31-2012 05:21 AM
Confirmed NZ spec will called '86' bricktop AUSTRALIA 2 01-31-2012 12:41 AM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
