Old 01-12-2012, 01:03 PM   #1
ryude
Drives: Volkswagen GTI
How to get that boxer rumble?
I love the deep burbly note a boxer makes, but every video of the brz sounds like a regular 4 cylinder. Does anyone think the aftermarket will make something to give us that sound?
ryude is offline   Reply With Quote
Old 01-12-2012, 01:26 PM   #2
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Yea its called UEL (unequal length) Headers and you are good
The FR-S/BRZ are coming with EL headers which devoids the car of the "boxer rumble" but is more effictive and makes better numbers.
So its sound vs performance
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 01-12-2012, 03:07 PM   #3
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Well, it's not quite that black and white. All else being equal, a UEL header on an N/A car will be down a bit on peak power but will have a bit broader of a torque curve. For turbo engines though, it's EL ftw.
old greg is offline   Reply With Quote
Old 01-12-2012, 03:10 PM   #4
Caliban
Terrorist of Chat Rooms
Drives: 05 E46M3, 06 CT9ARS, FR-S?
just take the whole exhaust system off (cat-back section).
Caliban is offline   Reply With Quote
Old 01-12-2012, 03:13 PM   #5
old greg
Rocket Surgeon
Drives: PSM GGA OMG
No, then it will just sound like a Honda
Old 01-12-2012, 03:17 PM   #6
Dimman
Kuruma Otaku
Dimman's Avatar
Would part of the problem be a tuning one? If we're using UEL, we're getting different scavenging effects on different cylinders, right? But the ECU is getting averaged signals for MAP and UEGO. So the tune will have to be safe, which means the whole engine will be tuned to the limits of the 'weakest' cylinder, which may not be optimal for power on the others.
So question is: if we have individual cylinder fuel/spark trim and say EGT feedback, how much closer will an UEL get to EL power-wise when all the cylinders can be tuned better for their individual peak power?
Because titanium.
Old 01-12-2012, 03:38 PM   #7
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Would part of the problem be a tuning one? If we're using UEL, we're getting different scavenging effects on different cylinders, right? ... if we have individual cylinder fuel/spark trim and say EGT feedback, how much closer will an UEL get to EL power-wise when all the cylinders can be tuned better for their individual peak power?
It's not so much the fuel or timing that does it, it's more that different cylinders will reach peak VE at different engine speeds. So lets say when cylinders 1&3 are at peak VE, cylinders 2&4 might only be at 95% of peak. When an engine with EL headers reaches peak VE it is moving more air than it could with UEL headers, but to either side of that peak the UEL headers could be tuned to maintain a fairly steady overall VE where VE with an EL header would taper.
Old 01-12-2012, 05:50 PM   #8
ryude
Would it be possible to make the same horsepower, but more torque with the unequal length headers?
Old 01-12-2012, 06:08 PM   #9
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Only if the UEL header was better designed/built than the EL header. Versus stock? probably. Versus an equally good aftermarket EL header? no.
Old 01-12-2012, 06:09 PM   #10
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Did not know this tho I've never seen unequal length headers before on a NA car.
I believe this could be done but most likely it would be because you arent extracting the max out of the headers tho for me this is all "in theory"
Out of the FRS game
Old 01-12-2012, 06:30 PM   #11
KeepGuessing
Drives: e30 150 deville etc etc
UEL exhaust headers will raise torque due to some of the cylinders keeping higher backpressure than others...the top end will be lost due to the same reason...Much like chosing a long runner intake manifold vs short runner...
As for making the SAME horsepower but more torque...it would depend on what the constants are there.
Do you mean the same horsepower as "brand X manifold" or the same horsepower as you would make using a dynamically identical manifold just one made using a UEL method...
If the choice is ONE..then yes of course, you can produce more HP and more torque than a particular brands item by having one produced to suit YOUR car your climate and the rest of the modifications done to your car...
If the choice is #2..then no, because the majority of the design will carry over thus keeping the limitations/gains similar in all area's EXCEPT UEL....
The real question is, when will a company produce some variable length headers (i remember seeing a design/patent offer for this a while ago but it was completely unpractical..probably tripling the weight of a standard cast type)
KeepGuessing is offline   Reply With Quote
Old 01-12-2012, 07:15 PM   #12
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Really? This is what I have on my Impreza
Old 01-12-2012, 07:26 PM   #13
catharsis
Drives: honda civic si 08
What he said. /close thread.
Seriously the only way to get it is with UEL headers, and it might be better than the stock header, but still worse than a good aftermarket EL header.
If sound is such a concern, will you to be getting a device that makes a "Woosh" sound so people think you got an ubercool turbo?
catharsis is offline   Reply With Quote
Old 01-12-2012, 07:48 PM   #14
Dimman
Kuruma Otaku
Dimman's Avatar
I guess that's kind of the same thing. With different VEs the averaged fueling and ignition leaves some cylinders under-performing.
Because titanium.
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Porche boxer vs Subaru boxer Shevon Engine, Exhaust, Transmission 22 08-10-2011 12:43 PM
Is it the first ever FR with a boxer Cogito8888 Scion FR-S / Toyota 86 GT86 General Forum 27 04-30-2011 11:12 AM
Who would like to see a boxer diesel in the FT-86? Blokatos Engine, Exhaust, Transmission 43 06-19-2010 01:04 PM
AE86 Boxer Sleeperz Engine, Exhaust, Transmission 9 05-05-2010 01:51 AM
