Old 06-28-2013, 03:41 AM   #1
Location of the secondary amp
Hi Folks,
I'm new to this forum and my FR-S.
Yes, I've tried a search.......
I understand that the standard radio in the FR-S, has an additional amp (other than what is in the head unit). Is this what I'm looking at in the picture?
I recently had the head unit replaced (with a Kenwood DNX570HD) and asked the installer to make sure that amp in the trunk was hooked into the system.
How can I check to make sure it's hooked in?
Should the cover be warm if it's active?
TIA
Old 06-28-2013, 04:31 AM   #2
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
That's the amp. If you get sound through the door speakers, it's hooked up.
Gir is offline   Reply With Quote
The Following User Says Thank You to Gir For This Useful Post:
Tr1huynh (06-28-2013)
Old 06-28-2013, 12:55 PM   #3
Well, thank you, Gir .....
That sets my mind at ease.
Old 08-05-2013, 11:17 PM   #4
BRZnut
Drives: BRZ DGM Limited
Is there anyway to add a sub directly to the stock amp? Not looking for huge thump, just to round out the low end sound.
Old 08-05-2013, 11:22 PM   #5
thill
No. You can get a decent powered sub for under $200.
Old 08-06-2013, 01:28 PM   #6
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
You could, but the problem is the power wire to that amp is only like 12ga, meaning it's not big enough to run a real sub amp, even a class D.
If you ran another power wire then you might as well run real RCA cables from the deck and hook it all up properly.
Check out this thread for more info on the stock amp wiring:
http://www.ft86club.com/forums/showthread.php?t=42239
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 08-06-2013, 02:20 PM   #7
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
12AWG is good for 25A, in 60C-rated wire. That's enough to support at least a 150W Class AB amp.
It's not going to knock down buildings, but I suspect for most people it's more than enough.
Admiral Ballsy is offline   Reply With Quote
FS: OEM downpipe / Secondary catalytic converter cb7tuner Engine, Exhaust, Bolt-Ons 2 06-07-2016 02:17 PM
Secondary O2 sensor needed for Cruise control? DJCarbine Engine, Exhaust, Transmission 31 04-10-2015 09:49 PM
Secondary Fuse Block for Interior Circuits F1point4 Electronics | Audio | NAV | Infotainment 1 06-17-2013 01:09 AM
Secondary cat removal wootwoot Engine, Exhaust, Transmission 7 05-29-2013 12:42 PM
Secondary Cat sw20kosh Engine, Exhaust, Transmission 2 03-11-2013 03:41 PM
