Drives: Ultramarine FR-S
How to gut the interior?
I want to start my sound deadening project for the entire floor,side panels, and doors of the FRS. I searched but had no luck finding a tutorial on how to disassemble the whole interior. I'm sure quite a few modders have done this. Are there any guides out there?
#2 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
This might better be aimed at the DIY request section.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#3 |
#4 |
Original 2013 Owner
Ah yeah, I think the information you are looking for is out there but it is not in one place. For example, one user might have removed the back paneling by the rear seats in order to get to a ground wire while another user might have removed the door cards to install courtesy lights. You can try downloading the service manuals (not the user manual that comes with the car) to see if there are any tips in there. Otherwise, you're gonna have to write up a DIY for everyone since it seems you're the first!
φφκα |
#5 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
To take out panels:
1) Literally look/feel for fasteners. 2) Remove fasteners 3) Remove component To install panels: 1) Replace component 2) Replace fastener It's literally self explanatory. They're either bolted/screwed into place, or snapped in. Generally the bolts/fasteners are visible or accessible with your tools, but this isn't rocket science. |
#6 |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
I just finished my sound deadening. This was helpful.
http://www.ft86club.com/forums/showthread.php?t=35604 Sent from my iPhone using Tapatalk
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
#7 |
Thanks for the input guys! Il probably start with the doors and trunk/wheel well next week. As for the rest of the cabin, Il dedicate one weekend to get it all done.
#8 |
Is it fast? No.
From my experience. The doors, inside the rear quarter panel and then the floor was the most beneficial.
I took some pillows and stuffed them in the opening behind the rear speakers after I put dynamat all over the metal. Sent from my iPhone using Tapatalk
| DCW Carbon Fiber interior items! Center console Plaques / Interior panels | doggy | Interior Parts (Incl. Lighting) | 143 | 10-11-2013 11:17 AM |
| LED interior conversion kits (interior), USA stock & warranty | WTF | Interior Parts (Incl. Lighting) | 0 | 05-22-2013 10:17 PM |
| interior fog? | munjah | Issues | Warranty | Recalls / TSB | 7 | 12-03-2012 05:36 PM |
| FR-S Interior | ph0en1xtk | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 07-19-2012 05:03 PM |
| BRZ vs 86 interior | beirouty | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 11-30-2011 09:48 AM |
