Old 08-05-2013, 05:07 PM   #29
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
Test drives, dealership personnel ... my car had 89 miles on it when I got it ... can't imagine there was any adherence to low RPMs
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 08-05-2013, 07:10 PM   #30
lexusb3
Drives: FRS
I boosted it during the "break in period" lol
lexusb3 is offline   Reply With Quote
Old 08-05-2013, 08:28 PM   #31
Optimus Prime
Optimus Prime's Avatar
Drives: Whiteout 2013 FR-S
yup, I was kinda excited to end the break-in myself. Don't worry, nobody was within a 1/2 mile of me.
Optimus Prime is offline   Reply With Quote
Old 08-05-2013, 09:03 PM   #32
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by lickitysplit View Post
I agree, and I myself am going through the break in period per those instructions. I was merely stating that it all depends on who you ask. I ask the manual since the engineers who built the engine said that was the break in process.
That was my point. I'm agreeing with you.
Suberman is offline   Reply With Quote
Old 08-05-2013, 09:08 PM   #33
Suberman
Originally Posted by FRSBRZGT86FAN View Post
I think you should do the after break-in oil change alot of people said on here that it felt a bit more free revving afterwards and the less metal particulates in the filter and oil the better I guess.
This is incorrect as it happens. The break in requires that the rings lose metal to the oil in order that they match the cylinder bores exactly. The metal filings end up in the oil filter. It doesn't matter when you do the break in the metal still ends up in the filter. The trouble with waiting to do the break in is the rings may never grind down enough to seal properly.
This is a faily simple process and Subaru tells you exactly what to do in the owners manual. Just do that and your engine will produce the designed power and use little or no oil for 200,000 km or more. Don't follow the instructions and your engine WILL burn oil, eventually.
Old 08-06-2013, 10:39 AM   #34
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Originally Posted by Jertronic View Post
Contemplating an oil change tomorrow.
I wouldn't change the oil until at least 5,000 miles. Used oil analyses have shown that the oil is fine and there is no need to change the oil so early.
Plus the additional moly, zinc, and phosphorus from the factory fill is probably beneficial for a full break-in and will probably be more robust that any oil that you replace it with (unless you switch to a race oil).
-Dennis
bluesubie is offline   Reply With Quote
Break in Y/N ? FiRStscion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 83 07-26-2013 12:41 PM
Break-in period...what's really going on? CaptainSlow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 04-27-2013 01:43 AM
Fr-s Break in procedure. Ontariofrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 03-14-2013 07:14 PM
break-in for the automatic brz/frs chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 03-08-2013 12:52 PM
Break in ipothas Issues | Warranty | Recalls / TSB 11 10-21-2012 04:41 PM
