Old 03-08-2013, 11:02 AM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
break-in for the automatic brz/frs
I've read a lot about break-in about the twins but all of them are the manual transmission. For the automatic i understand that we also need to keep it below 4000rpm and no constant speed, however, i find that if i just leave it in auto, most of my rpm is in the 1300-2000rpm range. Is that too low? Do i have to keep the rpm ABOVE a certain range during break-in? Also, should i use manual mode during the break-in period? I currently have 600km (under 400 miles).
btw i'm following the break-in in the manual so no hard break-in. I'd rather follow Subaru and Porche boxer engine break-in rpm range.
chenshuo is offline   Reply With Quote
Old 03-08-2013, 11:05 AM   #2
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
I personally kept my Auto below 4000rpm and didn't use the slap shift much. I pretty much "babied it" until I hit the 1000k mark. Personally, I think you'll be fine following the method you are. Happy driving and stay safe.
Chattanooga Scikotics MFIC
Red Robin Build
L3P47 is offline   Reply With Quote
Old 03-08-2013, 11:38 AM   #3
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Yeah that's about right. The key is to not keep it at constant speeds/rpms. You want to vary the RPMs either via manually shifting the AT or by just punching it every now and again.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 03-08-2013, 12:52 PM   #4
SilentAngel
Guest
Posts: n/a
pretty much, what the other's said. When i went through the break in period in mine i just kept it below 4k RPM and didn't ease on the pedal much just kinda let it bounce around a bit. Mostly did city driving. If i was on a long stretch of road that stayed the same i would just downshift about every 10 min to make the rev's go up for awhile and then back down. Almost at 13,000 miles now, haven't had any issues.
ECU reset after Break-In paros28 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 02-19-2013 05:41 PM
Break in ipothas Issues | Warranty | Recalls / TSB 11 10-21-2012 04:41 PM
How did you break in your engine? WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 4 06-05-2012 01:12 AM
Break-in question Baldeagle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-31-2012 02:28 PM
Break-In Period UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2012 03:26 AM
