Old 08-04-2013, 11:19 PM   #15
diss7
Drives: AE86, 2x GT86, TE27
Originally Posted by bkblitzed View Post
ah okay thanks. I might just gut the overpipe cat then.
Yes, I'm going to do the same.
diss7 is offline   Reply With Quote
Old 08-05-2013, 12:25 AM   #16
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Taking the cats out stock exhaust gave a fellow 86er great torque gains. In fact I have full 63mm performance pipe with Header and this guy got almost the same gains on a dyno run as I did.
Here is dyno chart of before and after cat removal of stock header and front pipe.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
diss7 (08-05-2013)
Old 08-05-2013, 01:11 AM   #17
KONVERTER
KONVERTER's Avatar
The cat delete pipes are cheap enough... Gutting cats is not worth the time or effort IMHO... You can sell your cats for half the price of a pipe to a scrap yard for the metals alone...
Sent from my Nexus 4 using Tapatalk 4
KONVERTER is offline   Reply With Quote
The Following User Says Thank You to KONVERTER For This Useful Post:
MurderousPandas (02-26-2017)
Old 08-05-2013, 04:00 AM   #18
cf6mech
Drives: FRS Silver LS1 swapped.
Finished gutting my header cat when it started to gut itself all on its own with my turbo set up,...so I'm totally catless now. It a little louder now, backfires more frequently as I burn E85 and you definitely can smell the emissions more.
cf6mech is offline   Reply With Quote
The Following User Says Thank You to cf6mech For This Useful Post:
WolfsFang (08-05-2013)
Old 08-05-2013, 04:01 AM   #19
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Looks like I will be doing this on my day off. What do you guys use? Just a really long screw driver?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 08-05-2013, 04:23 AM   #20
diss7
Youll be there forever with a screw driver. Drill with big bit around the outside, then the centre will fall out. Then tidy. Wear breathing protection, who knows what their made out of.
To those commenting about just putting a decat pipe in. Yes this would be easier, but in some places (like Nz) this would fail the warrant of fitness inspection that we have to obtain annually.
2. A vehicle (other than group L vehicle or a class MA or MC motorsport vehicle with a valid motorsport authority card) that was first registered in New Zealand on or after 1 May 2010 and manufactured from 1 January 1990 has a catalytic converter removed where there is evidence that one was originally fitted.
Old 08-05-2013, 04:25 AM   #21
WolfsFang
Scrape Master
WolfsFang's Avatar
I have a borla cat delete so I will be gutting the stock header.
Old 08-05-2013, 06:26 AM   #22
Calum
That Guy
Drives: 2013 asphalt FRS MT
Why not get the pipes without the cat and just swapping the original ones back in before the inspection? It's a bit of a pita but you'd get better flow then punching out the cats.
Old 08-05-2013, 09:03 AM   #23
wparsons
wparsons's Avatar
Why not just get a proper pipe with a high flow cat??? There are more gains from the larger piping than from punching out the cat in the front pipe.
The stock pipe is like 2 1/8", a 2.5" pipe with high flow cat will make more power across the rev range than the stock pipe with a gutted cat.
flickr
Old 08-05-2013, 09:58 AM   #24
ML
ML's Avatar
Drives: 13 White MT FR-S
'Cause this is free.
The Following User Says Thank You to ML For This Useful Post:
bedabi (04-20-2014)
Old 08-05-2013, 11:07 AM   #25
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
It's not free. Since one would be destroying some expensive parts.
The OEM cats are worth a bunch of money. Look up how much they cost new.
If you really want to go catless, keep the OEM stuff in a bin, get a header/test pipe. In a couple years when someone buys a ghetto mod'ed FRS for cheap, they will pay a good price for a set of OEM cats, especially in CA.
uspspro is offline   Reply With Quote
Old 08-05-2013, 11:21 AM   #26
ML
ML's Avatar
Thank god I don't live in CA
Tim_Asphalt_FRS (08-05-2013)
Old 08-05-2013, 11:25 AM   #27
uspspro
I'm just talking economics. The OEM cats a worth a few hundred. It's like throwing money away. The gains will be better with new parts.
Old 08-05-2013, 01:00 PM   #28
wparsons
wparsons's Avatar
^^ This! I bet an OEM front pipe with cat is worth about twice what a catted aftermarket front pipe is.
I know on some VW's the much smaller cat pipe is like $900 from a dealership for a cat with two flanges.
flickr
Gutting primary cat? jordanrw260 Engine, Exhaust, Transmission 6 07-30-2018 10:24 PM
Just replacing the stock cats? brillo Engine, Exhaust, Transmission 4 07-08-2015 11:12 AM
Gutting the BRZ and putting in a Electric Engine? mechaghost BRZ First-Gen (2012+) — General Topics 22 07-31-2014 07:12 PM
I giggled... Cats have it made seven Off-Topic Lounge [WARNING: NO POLITICS] 51 12-21-2012 03:46 PM
Speed cats (or other driving shoes) Symbiont Off-Topic Lounge [WARNING: NO POLITICS] 25 06-14-2012 11:10 PM
