Old 08-03-2013, 07:17 PM   #183
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Originally Posted by Pablitomarrero View Post
Ill try that, but i thibk the reason they came on was because I actually drove without an airbag :/
I took out the passenger seat and drove for quite a while and as soon as I put the seat back in the light went away for good.
Cade01 is offline   Reply With Quote
Old 08-03-2013, 07:18 PM   #184
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Hmn, alright then! Keeping them crossed. Thanks!
Pablitomarrero is offline   Reply With Quote
Old 08-03-2013, 07:51 PM   #185
Cade01
Cade01's Avatar
Good luck
Old 08-11-2013, 08:26 PM   #186
Pablitomarrero
Good luck
You were right... i never plugged in the pins...so stupid. Code went away by itself
Old 08-12-2013, 12:26 AM   #187
Cade01
Cade01's Avatar
Glad it was something simple and that there was no incidents where an airbag would have been needed.
The Following User Says Thank You to Cade01 For This Useful Post:
Pablitomarrero (08-12-2013)
Old 08-12-2013, 01:58 AM   #188
Synack
Boosted
Synack's Avatar
Drives: Sideways
I've got a netbook running 32 bit Windows 7. Should the drivers just install automagically?
Still waiting on the cable but I'm installing the 8.10.021 software right now so I'll be ready to go.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-12-2013, 05:08 AM   #189
Pablitomarrero
Yes
The Following User Says Thank You to Pablitomarrero For This Useful Post:
Synack (08-12-2013)
Old 08-14-2013, 05:40 PM   #190
Synack
Boosted
Synack's Avatar
Drives: Sideways
Well I just got the cable, ran Windows 7 32-bit, drivers installed after awhile automatically. Installed 8.10 TS. Tried to connect and it wouldn't. Not sure where to go from here.
Update:
Uninstalled/Reinstalled Techstream. Opened Techstream. Closed Techstream. Opened Techstream, set configuration to North America. Copy pasted the serial key from the text file. Closed Techstream.
Installed MVCI driver 2.0.1.
https://skydrive.live.com/?cid=75C93...49501E9A%21141
Then reopened Techstream after plugging in the cable from car to laptop.
*My laptop was plugged into the car, charging it, if that helps anyone.*
I then hit "Connect to Vehicle" and it was successful and I was able to tweak things from there.
The LED color was RED when it was working and connecting properly.
The key was reading perfectly fine in the ON position with both the engine running and not running.
Old 10-17-2014, 10:28 PM   #191
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
Hey guys "long time, first time"
So, i finally got Techstream to work with one of my old XP Windows 32bit laptop from 2002.
My question is, I used the software to reduce the delay of the "auto" head light auto off when the door is open, to 0 seconds, but this doesnt work when the head light is set to the "on" position. Is there any way to get it to auto off the "on" headlights? I like driving with my headlights during the day (especially when it rains here in South Florida, so many people would rather put their hazards on then just turning on their headlights.). Ive gotten so used to my Tacoma auto turning off the "on" headlights. BTW, i changed the light threshold to "Light2"
I am also not above placing a piece of black tape over the light sensor to fool the system into always leaving the "auto" headlights on when driving during the day. Would there be a problem with this? Where is the light sensor? There is a bubble sensor on the right side of the dash and a indentation divit sensor on the left side.
Sorry for resurrecting an old thread but its best to keep all the related information together.
2015 BRZ Limited.
Shinobu's Smile is offline   Reply With Quote
Old 10-19-2014, 05:47 AM   #192
73TORANA!
Drives: Orange GTS
I cant help you out with the tech stream question but the light sensor is the bubble on the dash, just put a piece or cardboard over it to try it just remember there is delay to stop the lights flickering on and off in marginal conditions. I don't see any problem putting tape over it as it will just simulate night.
73TORANA! is offline   Reply With Quote
Old 10-19-2014, 07:40 PM   #193
Shinobu's Smile
Yup, it worked thanks
Old 12-01-2014, 02:36 AM   #194
Liliflower
Drives: 2008 FT86 GTS
Then what fits
Originally Posted by Jeff Lange View Post
This is TechStream Lite, it cannot reprogram ECU's.
Jeff
What do you recommend for ECU programming, DST2?
Liliflower is offline   Reply With Quote
Old 04-16-2015, 05:51 PM   #195
VakaGT
VakaGT's Avatar
Drives: None
Can I adjust DRL brightness?
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 04-16-2015, 11:12 PM   #196
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
was you car using high beams for DRL? if so there's a resistor you have to remove for full brightness
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Production Toyota FT-86 Details and Design Previewed by Toyota Sports Vehicle Boss ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 541 11-18-2011 09:04 PM
Toyota FT-86 G's Sport Concept moved to Toyota Mega Web showroom at Odaiba Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 05-02-2011 01:11 AM
Toyota FT-86 G-Sport Concept car displayed with AE86 at Toyota Amlux, Tokyo Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 03-08-2010 11:09 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 11:36 AM
