Old 08-02-2013, 11:17 PM   #57
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Uninstall the turbo kit as much as necessary to effectively go back to a stock intake and no FI. That means replacing the stock intake tract and venting the turbo to atmosphere. Then flash back to stock. If the issues are gone, you know the problem is probably with the kit. If the issues aren't gone, you know the problem is with the car, but you will have to remove everything anyway to solve it. If the problems are with the kit, yell at Avo. If they're with the car, yell at Subaru.
The Following User Says Thank You to EAGLE5 For This Useful Post:
HotLeopardMama (08-05-2013)
Old 08-03-2013, 06:27 PM   #58
Lammie
Lammie's Avatar
Drives: Subaru BRZ
Originally Posted by AVOturboworld View Post
Which tune map are you running on?
P0219 is a engine overspeed code, comes up when over-revved. B14A1 really means nothing. Others are related to cam issue.
I'm using one of John's tunes.
Lammie is offline   Reply With Quote
Old 08-03-2013, 10:22 PM   #59
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
... and what is your redline set at?
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 08-06-2013, 12:46 AM   #60
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Sorry to hear that dude. Did you end up getting your car fixed or did you part out your set up?
TRD_07 is offline   Reply With Quote
Old 08-06-2013, 06:42 AM   #61
Lammie
Lammie's Avatar
Drives: Subaru BRZ
Red line should be same as stock, 7400.
I'm still deciding on what to do. Gonna call the dealer today and see if anything comes from that.
Old 09-10-2013, 05:37 PM   #62
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Whatever happened with this? Curious how it all turned out.
gdrider77 is offline   Reply With Quote
Old 09-10-2013, 05:39 PM   #63
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Old 09-10-2013, 05:51 PM   #64
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Did the guys with these codes all have the same tuner?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 10-27-2013, 02:15 AM   #65
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
My car isn't sold. Dave, don't say something if you don't know man.
The DTC/Idle stall issues continued until the car wasn't drivable. The kit is now off the car and I'm trying to iron out the DTC issues still. Just had some more OCV valves replaced but I think the ECU still needs replacing. Still on the original ECU.
vubaru is offline   Reply With Quote
Old 10-27-2013, 02:49 AM   #66
Bigmaxy
Drives: Pegasus GTS86
@Lammie I'd be interested in hearing how things are going now. Did you find the problem?
@vubaru So I take it Scion are still playing with you despite knowing the car had a turbo fitted. That's good news.
Bigmaxy is offline   Reply With Quote
Old 10-27-2013, 12:28 PM   #67
Sportsguy83
Drives: Limited BRZ
Holly Forum disappearance Batman!!
Also, I said the car was sold because well... below is your last post on the site before yesterday, posted 06-28-2013, 05:55 PM:
Bad news. It's the end of a long road. I'm sorry to say that the dealer is refusing to warranty the car in its current state. The ECU keeps clearing the P0014 and P0017 DTC's but the dealer finally was able to read them and verified the problem.
The dealer reports that the OCV that failed has a pulley that is not operating correctly and needs replacemenet, but it is under the valve cover and access is blocked by turbo hardware (I believe is is blocked by lines but I'm not 100% sure on the location yet.) So the dealer says I need to have the turbo kit uninstalled for them to warranty the car.
As I don't have the funds to uninstall and reinstall turbo kits ad infinitum, I'm going to have WORKS uninstall the kit, part it out, part out the car, and trade it in.
It's been fun! If anyone wants a slightly used AVO turbo kit, full engine back exhaust in good condition, VOLK TE37SL's in mag blue/staggered fitment, etc., send me a PM!
Looks like I will be trading the car in once it is back in stock form and warrantied, probably for a STi.
Mark
The Following User Says Thank You to Sportsguy83 For This Useful Post:
pmccut (10-27-2013)
Old 10-28-2013, 08:15 AM   #68
Lammie
Lammie's Avatar
Drives: Subaru BRZ
She started missfiring and stalling when coming to stops. (P000B, P000D, P0017, P0019, and a P03xxx (only showed up once))
We tried moving the CVs around as per the TSB but it didn't help. I also tried changing the tune hoping that it might be that, but that didn't change anything either. Thanks Paul for supplying me with an up to date tune.
I asked 2 dealers here about the TSB and what they would do to try and fix the issue. Their response was that there was no TSB in Canada and that they would look into it step by step as any other car. I eventually just asked them to replace the ECU and hoped that it would fix the issue. After the ECU was swapped and my keys re-programmed, she stalled coming off the lot. Although there was no cam shaft slow response time (P000B/D), so I hope that the new settings from subaru fixed that issue, the cam shaft out of position code (P00017, P0019) was still there.
I have a stint in Argentina starting next year, so I decided to park her until I came back. Winter is coming...
My next plan of attack was to ask the dealer to look at the TSB related to shimming the cam sensor and see if she needed that, and if that didn't work proceed to changing the CVs and cam assembly.
Old 10-28-2013, 02:48 PM   #69
Bach415
Bach415's Avatar
Drives: Whiteout FRS
It's not scion, its Subaru.
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
Sportsguy83 (10-28-2013)
Old 10-28-2013, 06:23 PM   #70
vubaru
Now with Boost!
vubaru's Avatar
Subaru was willing to replace more OCV's which weren't replaced before. Livermore Subaru did one side; Diablo Subaru did the other. Whether they are willing to replace the ECU if I still have problems going forward is another story. I wouldn't take that bet.
At this point, car is stock with the Milltek exhaust and AVO panel filter, stock tune. I am not throwing any DTC's or CEL's, but let's see how things go for a week or two.
Possible trade? Nameless axle-back for Perrin Resonated Cat-back GTB/ZR-1 Engine, Exhaust, Bolt-Ons 0 03-26-2013 01:51 PM
Visconti Calum User/Vendor/Sponsor Reviews, Feedback, Comments 7 03-11-2013 06:02 PM
Visconti stg 1 Hawaiian Great Lakes 18 08-23-2012 02:11 PM
Bespoke Operation Video? Username Electronics | Audio | NAV | Infotainment 4 06-09-2012 01:56 PM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
