Old 08-02-2013, 05:31 PM   #29
Events@Ptuning
Events@Ptuning's Avatar
Drives: 2013 Scion FRS
Bump!
Events@Ptuning is offline   Reply With Quote
Old 08-06-2013, 05:37 AM   #30
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Question. Would the WMI kit also allow you to run at the lower boost levels EVEN SAFER on the stock block or is there no real point in having it at the 6-10 psi range??
MooKz is offline   Reply With Quote
Old 08-06-2013, 09:46 AM   #31
Ross
Drives: 85 corolla gts
You can have a higher amount of safety using water / meth kit at 6 to 10 psi. But always tune for it and have fail safes in place. I have not had to deal with many failures over the years but have seen a few.
Ross is offline   Reply With Quote
The Following 2 Users Say Thank You to Ross For This Useful Post:
MooKz (08-25-2013), ptuning (08-06-2013)
Old 08-06-2013, 12:29 PM   #32
ptuning
ptuning's Avatar
Drives: White FR-S
Due to the very high compression ratio of this engine, trying to achieve the ideal ignition timing (MBT) is often tricky. We are often forced to run timing based on knock limitation rather than full optimum timing. At 8-10 psi, we would definitely be able to run more timing and make more power with WMI in place. That's not to say that we can't run 8-10 psi without WMI, it's just that we will not be able to achieve MBT.
If you were to run WMI, you'd probably want to run at least 10-12psi though, if not a little more, just to get your money's worth.
ptuning is offline   Reply With Quote
Old 08-06-2013, 01:44 PM   #33
MooKz
MooKz's Avatar
Can you send me a PM on the WMI installed price please
Sent from my HTC One using Tapatalk 2
Old 08-06-2013, 02:52 PM   #34
Calum
That Guy
Drives: 2013 asphalt FRS MT
Have you guys tested with 91 octane yet?
Old 08-06-2013, 02:57 PM   #35
ptuning
ptuning's Avatar
Drives: White FR-S
NP, Patrick will PM you with additional info on the WMI shortly. Thanks.
Old 08-06-2013, 02:59 PM   #36
ptuning
ptuning's Avatar
Drives: White FR-S
We have not, but we'd expect numbers that are not too far off from the 93 tune, especially at 6 psi. We'll get around to this once we get our shop test car back together.
OTD pump gas Ecutek tune - 182rwhp + 145wtq ultra Engine, Exhaust, Transmission 43 11-01-2014 02:50 PM
Visconti Tune STG 1 Pump Gas Help Cal3000 Engine, Exhaust, Transmission 7 05-05-2013 08:36 PM
Visconti Stage 1 NA Tune Pump & e85 Review CBR600RR Engine, Exhaust, Transmission 22 04-26-2013 10:36 AM
FA20club.com E85 Preliminary Review JoeBoxer Engine, Exhaust, Transmission 130 12-10-2012 11:01 AM
