Old 08-02-2013, 04:27 PM   #1
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Question Why is TPMS Transplant expensive?
Hi friends,
I was looking into what the cost was for a TPMS swap into new aftermarket wheels. I was quoted $80 for all four but I'm trying to understand why it costs so much to have a seemingly simple job completed.
This leads me to thinking, why can't I do TPMS myself? Where is the value-add that is justifying this cost?
Has anyone done their own TPMS transplant and what was required?
Thanks!
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 08-02-2013, 04:29 PM   #2
OrbitalEllipses
Drives: Attitude
They're charging you for breaking down the old wheels to get the sensors off.
chriscross_tnt (10-08-2013)
Old 08-02-2013, 05:19 PM   #3
infinite012
Drives: 13 DGM BRZ Ltd
Optional step: Deflate tires really not optional
1. Break bead
2. Fish your hand inside tire/wheel to unfasten TPMS from wheel
3. Remove TPMS
4. Break bead on other set of wheels
5. Fish your hand inside tire/wheel to fasten TPMS to wheel
6. Reinstall tire to wheel
7. Inflate.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
Cjymiller (08-02-2013)
Old 08-02-2013, 05:21 PM   #4
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
80 bucks is expensive?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 08-02-2013, 05:23 PM   #5
Cheddar
Saving them pennies...
hes making car payments now....
Cheddar is offline   Reply With Quote
The Following User Says Thank You to Cheddar For This Useful Post:
suaveflooder (08-02-2013)
Old 08-02-2013, 05:25 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Also: some aftermarket wheels are not drilled for this, so you're essentially paying them to have it mounted properly which may involve drilling the wheel barrel to add it on.
This is mostly a problem on multi-piece wheels.
See the pics for info: https://www.google.com/search?q=tpms...w=1280&bih=939
You don't need this though, if you monitor your tire pressure manually and/or on a regular basis.
-alex
Old 08-02-2013, 05:27 PM   #7
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
come down here at auto innovation in milpitas. $40 for four.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 08-02-2013, 05:43 PM   #8
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
It is since I don't know what the value add is for the service.
But to infinte012's point, I completely overlooked that they have to pull them out of my old tires.
φφκα
Old 08-02-2013, 06:44 PM   #9
topazsparrow
Drives: slow
Skip the TPMS swap entirely.
0$
the ONLY outcome is that the warning light will be on in your dash. A tune will take care of that if you go that route as well.
topazsparrow is offline   Reply With Quote
Old 08-02-2013, 07:04 PM   #10
OrangeJuleas
OrangeJuleas's Avatar
America's Tire charged me $5/wheel for their "rebuild kit", which was basically them taking them out of my old wheels and putting them in my new ones. The rebuild kit is most likely the wearable parts in the valve stem (gaskets and other such stuff).
Still, at $20 for them to be transferred, it is worth it. Discount Tire and Tire Rack also have the $5/wheel standard. Sure, you can just ignore the light, but if you're going to do something to your car, you should do it right. Also, make sure you're checking your tire pressure often anyway!
I'm not insane, in fact I'm kinda rational, when I be asking y'all, "Where did all the passion go?"
OrangeJuleas is offline   Reply With Quote
Old 08-02-2013, 07:23 PM   #11
KONVERTER
KONVERTER's Avatar
That is only 10$ each to technically mount and balance 8 tires... thats a steal take it...
KONVERTER is offline   Reply With Quote
Old 08-02-2013, 07:58 PM   #12
wparsons
wparsons's Avatar
^^ This! Most places here charge $15/wheel to mount/balance new tires, $80 total to pull the sensors out of existing wheels/tires and install them in new ones is a great price.
flickr
Old 08-02-2013, 08:01 PM   #13
OrbitalEllipses
Drives: Attitude
That was my point...
And you don't need to drill the new wheels or anything. My aftermarket wheels were fine, didn't even need a rebuild kit.
Old 08-02-2013, 08:18 PM   #14
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
$80.00 is on the high side.
We charge $10 per
Touge Factory is offline   Reply With Quote
Is the brz/frs too expensive? huma BRZ First-Gen (2012+) — General Topics 74 05-12-2015 01:28 AM
Expensive light Rims+Expensive light Tires or Suspension+Cheaper Rims+Cheaper Tires? OnionTou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 08-09-2013 07:57 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 09:25 AM
Why are expensive brakes better? hotaka Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 08-28-2012 02:26 AM
FA20 + gearbox weight Vs Transplant setups.... FT-86GOD Engine, Exhaust, Transmission 2 08-21-2012 10:42 PM
