Old 04-13-2013, 03:33 PM   #15
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Originally Posted by Readytoxplod View Post
Hankook v12 in 245/35 18?
or should I use a 225 or 235 width?
I talked to another "tire expert" at discount tire, he said 245 will be too wide in the front and affect handling.
Those look perfect btw!
I'm on 225 40 18s all around. The wheels are 18x8 +35. 245's would definitely be too wide. 235 or 225 will be fine.
Action shot for you as well:
denkigrve is offline   Reply With Quote
The Following 2 Users Say Thank You to denkigrve For This Useful Post:
Ganthrithor (08-05-2013), jonnyozero3 (04-13-2013)
Old 08-01-2013, 07:18 PM   #16
Eau Rouge
Eau Rouge's Avatar
Drives: 2013 BRZ, Limited, C7P, 6AT
I can get the Falkens for $550, hankooks cost almost $900. Would the falkens be close to 245/35 in sidewall height? Thanks for the help guys, first time buying wheels..
I didn't see it stated but your sidewall height is your section width multiplied by your aspect ratio. In the case of the 245/35, that's 245mm x .35 aspect ratio = 85.75mm. Converted from metric by dividing by 25.4 works out to 3.375 inches.
Now you know how to fish!
Eau Rouge is offline   Reply With Quote
Old 08-01-2013, 07:20 PM   #17
Eau Rouge
Eau Rouge's Avatar
I forgot to mention that this measurement is to the base of the tire bead. The lip of the wheel rim will cover some of that, generally by about half an inch for most wheels.
Old 08-04-2013, 11:03 AM   #18
Jetscape
Jetscape's Avatar
Drives: Toyota GT 86 Red AT
Nice set up. Are those 18" TSW Interlagos ?
Originally Posted by denkigrve View Post
Just get the Hankooks. They are fine. I've been on mine since like July with 0 issues:
Jetscape is offline   Reply With Quote
The Following User Says Thank You to Jetscape For This Useful Post:
denkigrve (08-05-2013)
Old 08-05-2013, 10:19 AM   #19
denkigrve
Random Internet dad
denkigrve's Avatar
Yep. 18x8 +35
They're about to be replaced though. Gramlights are on the way. 18x9.5 +40 57C6.
Old 08-05-2013, 12:09 PM   #20
tennisfreak
Drives: 2018 BMW M240i
The Faulkens I purchased for my truck offer sh!t for grip.
Old 08-05-2013, 12:41 PM   #21
OrangeJuleas
OrangeJuleas's Avatar
I just got my 18x8's wrapped in Falken Azenis 922's 225/40R18 and I'm pretty happy with them. I don't do a lot of racing, but drive spiritedly to/from work. I feel more connected to the ground around corners. You should check the reviews on the tires you are looking at (and make sure to check tire weights as well!)
Good luck! :happy0180:
I'm not insane, in fact I'm kinda rational, when I be asking y'all, "Where did all the passion go?"
OrangeJuleas is offline   Reply With Quote
Wheel Directory: WedsSport TC105N 18x8.0 +42 King Tut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 12-20-2015 08:58 AM
Wheel Directory: Axis X-Factor 18x8.5 +45 madcap Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-15-2014 01:26 AM
Wheel Directory: TSW Interlagos 18x8.0 +35 denkigrve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 03-19-2014 03:01 PM
FEELER: 18x8 +35 5x100 Ace Vertex - tires included ayetothejay Wheels and Tires 1 02-17-2013 07:07 PM
FS: FL set of 18x8(45) RPF1 5x100 with tires Scooby South Wheels and Tires 2 01-08-2013 10:35 AM
