Old 04-11-2013, 06:10 PM   #1
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Tires for 18x8 +45 TSW?
Got some TSW wheels in 18x8+45 square setup. I'm dropped 1.4" on Eibach & want ultra low profile tires. I 'm fine with bumps, and I don't AutoX... What are some good tires?
I was recommended:
Hankook v12 evo 245/35
Continental Extreme Contact DW 225/40
And Falken ZX912 235/40 from my friend at Firestone (super cheap)
Which is best and what is a good size for a small sidewall, but still keeps great handing?
322whp/273wtq
Readytoxplod is offline   Reply With Quote
Old 04-12-2013, 01:21 AM   #2
Blue86
Drives: Sonic Blue 86GT Manual
don't forget dunlop star spec 2 (less tyre life but more grip) and even eagle F1 asymmetric 2
Blue86 is offline   Reply With Quote
The Following User Says Thank You to Blue86 For This Useful Post:
Readytoxplod (04-12-2013)
Old 04-12-2013, 02:07 AM   #3
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
If you don't autoX just get the cheap 235/40s IMO
The Following User Says Thank You to BlaineWasHere For This Useful Post:
SkAsphalt (04-12-2013)
Old 04-12-2013, 12:23 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
There
Old 04-12-2013, 12:35 PM   #5
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Either of the first two. The Falkens are all-seasons. Friends don't let friends put all-seasons on their sports car.
MVJ1975 is offline   Reply With Quote
The Following User Says Thank You to MVJ1975 For This Useful Post:
Old 04-12-2013, 12:47 PM   #6
BlaineWasHere
Grip>Drift
Drives: FRS
Which are likely better/more grippy than the summers that came on the car.
Old 04-12-2013, 12:53 PM   #7
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Lots of tires are. That doesn't make them good tires, it just makes the Primacy HP bad ones.
Regardless, the 'Kook V12s will be a much better tire and I can't see them costing much more.
Old 04-12-2013, 02:15 PM   #8
Readytoxplod
Tire Destroyer
I can get the Falkens for $550, hankooks cost almost $900. Would the falkens be close to 245/35 in sidewall height? Thanks for the help guys, first time buying wheels..
322whp/273wtq
Old 04-12-2013, 02:20 PM   #9
Readytoxplod
Tire Destroyer
The sizes are different too. Still not sure which fits best!
322whp/273wtq
Old 04-12-2013, 02:28 PM   #10
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Hmm. If you can get the Falkens that cheap it might be worth it. Is that installed, or just for the tires? They'll be grippier than the crappy Primacy in any case. The second number is the sidewall ratio; the Falkens will be "taller" than the Hankooks, but they'll both be lower profile than the stock 215/45 tires.
You can get 245/35 Ventus V12s from Tire Rack for a bit less - about $750 plus shipping - but then you'll have to pay someone to mount/balance them for you.
Old 04-12-2013, 03:05 PM   #11
BlaineWasHere
Grip>Drift
Drives: FRS
Both 245/35 and 235/40 will both fit fine. 235/40 is a little taller and 245/35 is wider.
Old 04-12-2013, 05:06 PM   #12
Readytoxplod
Tire Destroyer
550 installed. Okay I think I'll just buy some hankooks.
322whp/273wtq
Old 04-13-2013, 12:48 AM   #13
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Just get the Hankooks. They are fine. I've been on mine since like July with 0 issues:
denkigrve is offline   Reply With Quote
The Following User Says Thank You to denkigrve For This Useful Post:
Readytoxplod (04-13-2013)
Old 04-13-2013, 02:39 PM   #14
Readytoxplod
Tire Destroyer
Hankook v12 in 245/35 18?
or should I use a 225 or 235 width?
I talked to another "tire expert" at discount tire, he said 245 will be too wide in the front and affect handling.
Those look perfect btw!
322whp/273wtq
Wheel Directory: WedsSport TC105N 18x8.0 +42 King Tut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 12-20-2015 08:58 AM
Wheel Directory: Axis X-Factor 18x8.5 +45 madcap Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-15-2014 01:26 AM
Wheel Directory: TSW Interlagos 18x8.0 +35 denkigrve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 03-19-2014 03:01 PM
FEELER: 18x8 +35 5x100 Ace Vertex - tires included ayetothejay Wheels and Tires 1 02-17-2013 07:07 PM
FS: FL set of 18x8(45) RPF1 5x100 with tires Scooby South Wheels and Tires 2 01-08-2013 10:35 AM
