Old 08-01-2013, 05:24 PM   #43
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Originally Posted by diss7 View Post
The trd diff oil is 75w140..
Is TRD advising using the 75W140 in the FRS diff? or is TRD diff oil just 75W140.
No Limit Motorsport is offline   Reply With Quote
Old 08-01-2013, 06:10 PM   #44
No Limit Motorsport
Originally Posted by Marchy View Post
I'm curious about the guy who said that using motuls 300 should be replaced every 3k miles, was this just engine oil or the transmission and rear diff? I'm currently using the motuls 300 75w90 in both my transmission and rear diff and its been more than 3k miles. Everything seems great but i'm curious as to where his comment was coming from.
Motul 300V engine oil should be replaced every 3k
Motul Gear 300 transmission/diff lube change at the intervals recommended by your car manufacturer.
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
Marchy (08-01-2013)
Old 08-01-2013, 06:53 PM   #45
CSG Mike
CSG Mike's Avatar
While we'd love to sell you more oil, I can't recommend you change it every 3k in good faith.
Here's an oil analysis from my s2k, using 300V.
And, for reference, a virgin sample
Old 08-01-2013, 09:04 PM   #46
diss7
Drives: AE86, 2x GT86, TE27
TRD here are advising to use the TRD/Motul 75W140 in the stock torsen LSDs in our NZ cars. If you swap this out for a mechanical, then they advise to then use the TRD Japan oil.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
No Limit Motorsport (08-02-2013)
Old 08-02-2013, 09:25 AM   #47
No Limit Motorsport
Wow. Very interesting. I wonder what the difference is between what TRD/Motul is selling versus the normal Motul Gear Competition 75W140.
http://www.motul.com/us/en-US/products/108
Old 08-02-2013, 09:48 AM   #48
bluesubie
Drives: 2004 Subaru Forester 2.5XT
300V can easily go 7,500 miles. There's a 6k FRS run on it in this thread.
Maybe the TRD oil isn't any good so you have to go with a 75W-140.
Seriously though, the Gear 300 75W-90 is an outstanding ester based oil and it's doubtful that there would be very many (if any) conditions in a BRZ/FR-S that this oil can't handle. Motul claims 0% shear loss and that the oil stays in grade after 20 hours in the KRL shear test.
http://www.astm.org/Standards/D6022.htm
It's also highly recommended for Subaru diffs by a tribologist at bitog that blends gear oils. The Subaru USA rally team does use the Gearff 75W-140, but I seriously doubt that there are very many BRZ/FR-S applications that would need such an oil (maybe serious track only cars). Of course, I would be interested to see a uoa where the Gear 300 wasn't sufficient.
-Dennis
bluesubie is offline   Reply With Quote
The Following 2 Users Say Thank You to bluesubie For This Useful Post:
CSG Mike (08-02-2013), No Limit Motorsport (08-02-2013)
Old 08-02-2013, 10:35 AM   #49
No Limit Motorsport
I wonder where APR got this information. I am curious if it of their own opinion, or was this stated to them by Motul. Either way I suppose oil analysis is the true tell all.
"300V is not designed for extended oil change intervals, therefore it should be changed after track/race events, at 3000 miles on ultra high performance street vehicles or at 5000 miles on lower performance engines. APR Recommends 300V Power 5w40 for most high performance racing applications and 300V Le Mans 20w60 for 24 hour endurance racing with Audi R8 V10's. APR does not recommend use of low viscosity 300V oils for extended periods of time as the lower viscosity oils were not intended for street or long track use. For help choosing the correct 300V oil, please contact APR."
http://www.goapr.com/products/motul_oil_300v.html
Next oil change I am going to send a sample to Blackstone, we run the 300V 5W30 in our turbocharged car. I am hoping for the same results others have apparently been getting in regards to length of oil change intervals.
Old 08-02-2013, 11:17 AM   #50
CSG Mike
CSG Mike's Avatar
They probably believed a lot of internet myths
Props to you guys for testing your oil! Looking forward to your results so that we can compare
bluesubie (08-02-2013), No Limit Motorsport (08-02-2013)
Old 08-02-2013, 12:25 PM   #51
bluesubie
Yep.
A few years ago on bobistheoilguy, there was a modified twin turbo S4 that ran 300V for 7-8k mile intervals with very good results. Their detergent/dispersant package of good levels of calcium and magnesium has always been good for a typical street oil change interval with some track use thrown in as well.
-Dennis
The Following User Says Thank You to bluesubie For This Useful Post:
Old 08-02-2013, 01:09 PM   #52
OrbitalEllipses
Drives: Attitude
Originally Posted by bluesubie View Post
Yep.
-Dennis
At what viscosity...the question really is if the 0W-20 water will last that many miles.
Old 08-02-2013, 01:27 PM   #53
CSG Mike
CSG Mike's Avatar
Why does the weight matter? If at the end of the OCI, the oil viscosity hasn't changed or gotten thinner (as is typical of 300V), then the oil is doing what it's meant to be doing...
I understand that a lot of lesser oils thin out with temperature and use. 300V is a top shelf oil.
Old 08-02-2013, 01:36 PM   #54
OrbitalEllipses
Drives: Attitude
@CSG Mike, I'd agree as long as the viscosity stays the same it's fine. I just don't think I've seen a 7000 mile 300V 0W-20 on this forum.
Old 08-02-2013, 02:05 PM   #55
CSG Mike
CSG Mike's Avatar
I haven't either... who will be the first?
I unfortunately can't check BITOG since I'm IP banned there... someone claimed my UOAs were theirs and I was never given a chance to even defend myself... lol
Old 08-02-2013, 02:07 PM   #56
OrbitalEllipses
Drives: Attitude
I still have the OEM oil in a bottle that I haven't sent to Blackstone... infinite shelf life right? derp. Coming up on 5000 miles on the Eco-Lite 8100 soon-ish too.
Motul Oil's & K&N oil filter deals! No Limit Motorsport Mechanical Maintenance and Tools 1 09-18-2012 02:20 PM
Delete driver01 CANADA 5 08-30-2012 04:58 PM
Fluids change after break-in yomny Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 08-05-2012 01:18 PM
Service Parts! Motul Oil / Oil Filters vividracing Mechanical Maintenance and Tools 8 06-20-2012 12:46 AM
