Old 08-01-2013, 10:55 AM   #15
ML
ML's Avatar
Drives: 13 White MT FR-S
Originally Posted by jamesm View Post
Yeah I'm going to baby it to rev works and their tuner is going to look at it tomorrow. It's already scheduled for a retune after the clutch is broke in (next Tuesday) when we'll up the boost. So he'll probably just make sure it's safe and make whatever minor tweaks are necessary until then. Thank god my shop/tuner are nearby lol.
Update? I'm having the same issue with my PCV line leaking I think.
Old 08-01-2013, 10:59 AM   #16
jamesm
i was leaking badly, i fixed it initially with a check valve (linked above) which worked great, but i've since gone to just capping the intake manifold and venting the pcv line along with the crankcase breather. don't want none of that crap going back into my engine. a catch can only removes oil, not heat .
you should definitely be running a check valve between the manifold and pcv or manifold and catch can if you have one. if not, you're probably leaking boost and pressurizing the crankcase.
The Following User Says Thank You to jamesm For This Useful Post:
ML (08-01-2013)
Old 08-01-2013, 11:04 AM   #17
Ross
Drives: 85 corolla gts
Also double check your evap solenoid vacuum hose at the manifold. I have found a leak there as well as no clamp is used on it.
Ross is offline   Reply With Quote
The Following 2 Users Say Thank You to Ross For This Useful Post:
jamesm (08-01-2013), ML (08-01-2013)
Old 08-01-2013, 11:19 AM   #18
ML
ML's Avatar
do you put a filter on the vented lines ?
Old 08-01-2013, 11:36 AM   #19
xjohnx
Grip>Slip
xjohnx's Avatar
Is this a part the local napa/pep boys/autozone would carry?
Old 08-01-2013, 12:03 PM   #20
jamesm
yes i did. on the crankcase breather (the pcv is one way... only flows out, no need for a filter).
ML (08-01-2013)
Old 08-01-2013, 12:04 PM   #21
jamesm
no, you want one of these. it's very important that you get a valve with the correct opening vacuum.
Old 08-01-2013, 12:41 PM   #22
xjohnx
Grip>Slip
xjohnx's Avatar
Awesome. Just placed 2 orders (1 to my house, and one to Pure Auto in case it can get there in time for tomorrow's install.)
Thanks again.
jamesm (08-01-2013)
Old 08-01-2013, 01:15 PM   #23
jamesm
where is this line located on the intake manifold? i definitely need to check mine. thanks for the heads up!
Old 08-01-2013, 01:20 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Below the manifold towards the driver. You will see a blue connector, its hard to see, the solenoid is literally below the intake manifold. If you haven't gone to crazy PS numbers, (like 14+) most probably its ok. But you would also notice some kind of symptom of vacuum leak.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jamesm (08-01-2013)
Old 12-25-2014, 06:38 PM   #25
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Well I think James won't be able to post but his picture showing the check valve installation isn't visible. Can anyone post it or similar? Thanks.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Oil Leaking?? tonytduc Issues | Warranty | Recalls / TSB 371 11-13-2016 07:14 PM
After Oil change, something's leaking :( DSMDave25 Issues | Warranty | Recalls / TSB 24 04-03-2013 09:56 PM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 03:03 AM
