go_a_way1
Old 07-31-2013, 02:11 AM   #1149
fenton
WOW that camera mount is bad!
Daily driving with some quick blasts 00:00 to 2:40
Drag reduction only 3:00 to 3:10
2nd gear 2000rpm 3:45
3rd gear 2300rpm at 4:35 - you can see it hit and the sound gets a bit deeper
1st gear 2000rpm 6:50
2nd gear 2500rpm uphill 7:20
fenton is offline   Reply With Quote
Old 07-31-2013, 03:05 AM   #1150
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
Thanks Fenton; that was a helpful video for me, even though the audio was low quality. I appreciate the work putting the videos together!
Pug is offline   Reply With Quote
The Following User Says Thank You to Pug For This Useful Post:
fenton (07-31-2013)
Old 07-31-2013, 03:36 AM   #1151
radroach
Drives: car
try an external mic that way you can direct the sound towards the engine
Old 08-01-2013, 10:14 AM   #1152
mid_life_crisis
Drives: FR-S 10 #103 AT
I've never used it so I'm blanking on the name, but there's a piggyback tuning system that has a pretty good reputation and leaves no evidence behind that it was ever installed. Could that be used instead of flashing the ecu to avoid the cel and get the most out of the system? Another advantage is that once a tune was developed, it could be easily made available on Phantom's website. I remember reading that it can support multiple tunes, so you could set it up with the full power tune and one that is optimized for standby mode where the electrocharger is just slightly pressurizing the system. With a little work, we might come up with a single switch that would toggle both at the same time.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-01-2013, 10:24 AM   #1153
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Unichip, and we've already mentioned this and Jack from unichip has reached out to Phantom. Unichip also has excellent support for plug-in modules so it's possible that it could be used to turn the supercharger on/off rather then using an actual switch on the accelerator.
http://www.ft86club.com/forums/showt...=25211&page=42
The Following User Says Thank You to neutron256 For This Useful Post:
DAEMANO (08-01-2013)
Old 08-01-2013, 11:00 AM   #1154
mid_life_crisis
Too much stuff to remember it all.
If it monitors throttle position, then it might be possible to give those of us who want a little more control than 100% or nothing (okay, next to nothing) what we want.
This is looking better and better. I cannot wait for the '14s to come out so I can get my car. By then this system might even be ready for prime time. woohoo!
Old 08-01-2013, 12:33 PM   #1155
neutron256
neutron256's Avatar
It does monitor the TPS, as well as RPM, and MAF. From what I can tell even has the ability to create sperate maps for things like NOS or Water/Meth injection so on the surface it seems like it would be perfect for something like this.
I may be getting the Unichip tuning package just so I can start checking it out and playing with the concept a little. I'm no tuner, but if I can get the basics down hopefully I can find tuner who can help me get the details sorted.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
DAEMANO (08-01-2013), SloS14 (08-01-2013)
Old 08-01-2013, 01:07 PM   #1156
Robftss
Drives: VW
BuTang's car just off the rollers:
Peak HP up 20%
Peak TQ up 33%
Best HP Gain up 50% @ 4000 rpm
Best TQ Gain up 54% @ 4000 rpm
Toma provided a conservative 'base tune' (CEL code manipulation, 11.5-11.75 AFR's, 800-900 rpm idle to ensure alt. output) I have a BRZedit file.
Boost curve consistent and spot on to Fenton's.
Fenton's car had cam angles adjusted and leaner (12.5-13's) ~ 205hp
Bu-Tang's car has a safe 'base tune'. ~ 199hp. (he has graphs)
Results are as expected, HP/TQ curves are very smooth, Thanks Toma !
Rob
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
Old 08-01-2013, 01:20 PM   #1157
fenton
Peak HP up 20%
Peak TQ up 33%
Rob
Good work! I kinda like my 600 rpm idle, the visconti 800rpm idle didnt even seem as smooth as what @Toma Flashed to my car. What do you mean to "ensure alt. output".... never mind ensure alternator output.
Funny mine doesnt ever do anything weird at 600rpm.
Old 08-01-2013, 01:20 PM   #1158
fenton
Peak HP up 20%
Peak TQ up 33%
Rob
Oh what was Bu-Tang's fuel used for the dyno?
Old 08-01-2013, 01:33 PM   #1159
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Ran 94 octane for this tune, but it was the first tank as well.
Bu-Tang is offline   Reply With Quote
Old 08-01-2013, 01:41 PM   #1160
mid_life_crisis
I'm pretty sure you can set it up so if the Meth pressure drops, it will automatically switch over to a tune that is safe without it.
Old 08-01-2013, 01:41 PM   #1161
Bu-Tang
Here they are!
First one is a Filter/No filter dyno comparison, Toma just took the air filter out and directed the air box facing upwards with the fan blowing that direction. As you can see it really made no difference.
File Type: pdf Scanned from a Xerox multifunction device001.PDF (215.9 KB, 207 views)
The Following User Says Thank You to Bu-Tang For This Useful Post:
Old 08-01-2013, 01:44 PM   #1162
Bu-Tang
800-900 RPM is mainly cause for me I have a sub and amp in the car, running at the high RPM just ensures a solid charging rate to support all my accessories at idle.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
