Old 07-31-2013, 08:10 PM   #1
FA20Club.com
Drives: 2013 White Out FR-S
FA20CLUB ECUTEK Flex Fuel Forced Induction Certified...Vortech Innovate & Turbo
For all those who were unaware we were first to market last year with our flex fuel kit they have sold well but we decided to do a proper release with some new testing via the ever popular Vortech Blower. We had the opportunity for one of our Customers to install and retune the complete kit.
This version of our kit boast the following:
  • Mil Spec Wiring
  • Deutsch Connectors
  • Only One Single Wire Connection Needed
  • Braided Sleeving
  • Marine Grade Heat Shrink Tubing
  • Weather Tight Connectors
Now onto the benefits:
  • No More Draining Fuel Tank to Change Fuels
  • Optimized Cranking, Fuel & Ignition Tables
  • Maximized Power Delivery No Matter the Ethanol Content
  • No Worries About Winter Blends
Here you can see the test with our Vortech Based Flex Fuel Map. Tables we setup into our custom Map. The sensor reported a ethanol content of E60 car was tested with the 12psi pulley. As you can see the power went up progressively throughout the test as the ethanol was able to mix into the preexisting pump gas in the tank.
[/CENTER]
FA20Club.com is offline
The Following 9 Users Say Thank You to FA20Club.com For This Useful Post:
Brian@Vortech (08-01-2013), evo4g63 (07-31-2013), feldy (08-01-2013), ft86me (08-01-2013), Pete (07-31-2013), pheoxs (08-01-2013), PineappleFriedRice (08-01-2013), pixel67 (07-31-2013), tg_1981 (08-01-2013)
Old 07-31-2013, 08:52 PM   #2
nelsmar
Can't wait to try this out!
I see 3 lines on the graph what were the difference between the three?
My flickr - Canibeat
Local magazine scout
nelsmar is offline
Old 07-31-2013, 08:56 PM   #3
FA20Club.com
baseline run with 9psi pulley then e85 on 12 psi pulley the middle run i cant remember the ethanol level but it started at E9 and ended at E60 on the final pull.
Old 07-31-2013, 08:56 PM   #4
Pete
Pete's Avatar
Drives: 22 BRZ
Nice, I have been waiting for one of these and I just worked a ton of overtime.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline
Old 07-31-2013, 09:00 PM   #5
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I am stoked about getting this kit for my Innovate system
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline
Old 07-31-2013, 09:00 PM   #6
nelsmar
So only E60 on this? MMMM. All i wanted was hopes of tapping 320WHP out of my vortech kit eventually... looks like I will be able to get exactly what i wanted down the road!
nelsmar is offline
The Following User Says Thank You to nelsmar For This Useful Post:
Old 07-31-2013, 09:04 PM   #7
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Cool stuff. Should be installing mine this weekend.
Sent from my Nexus 7 using Tapatalk 2
pixel67 is offline
Old 07-31-2013, 09:06 PM   #8
sw20kosh
Drives: 2013 Black FR-S
Is your flex fuel tune for the innovate kit ready yet? Do you have any data to share on any of your innovate tunes?
sw20kosh is offline
The Following User Says Thank You to sw20kosh For This Useful Post:
xjohnx (07-31-2013)
Old 07-31-2013, 09:12 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
any plans to integrate EBCS along with the flex fuel kit so that SC users could run a smaller pulley all the time, bleeding off excess boost when on 93 octane but letting the boost ramp up as the ethanol content rises?
xjohnx is offline
Old 07-31-2013, 09:12 PM   #10
nelsmar
Soon
nelsmar is offline
Old 07-31-2013, 09:14 PM   #11
evo4g63
evo4g63's Avatar
What mods were done to this car besides the 12psi pulley and your flex fuel system w/tune?
-2016 Subaru WRX
evo4g63 is offline
The Following 2 Users Say Thank You to evo4g63 For This Useful Post:
Cal3000 (08-01-2013), nelsmar (07-31-2013)
Old 07-31-2013, 09:15 PM   #12
JerryMichaels7
Drives: Whiteout FRS
Would this when it sees it running e85 be the same as your e85 tune? or would it be better to run the e85 tune till we need to actually use the flex fuel feature
JerryMichaels7 is offline
Old 07-31-2013, 09:52 PM   #13
Andy@FA20Club
Drives: FA20Club.com
that would be correct. the benefit is that should you have a 50/50 mix or 70/30 mix it will relay to content to the ECU and adjust as needed.
Andy@FA20Club is offline
Old 07-31-2013, 09:55 PM   #14
Andy@FA20Club
We have you covered when you are ready -- no data to show as not many have booked for tuning on the dyno.
fa20club.com, flex fuel kit
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
Best place in Socal for Ecutek Flex Fuel Pneub Southern California 10 08-05-2013 08:49 AM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
FA20CLUB EUTEK True Flex Fuel Kit On Sale FA20Club.com Engine, Exhaust, Bolt-Ons 38 03-15-2013 12:09 AM
