Old 07-30-2013, 04:10 PM   #29
davidp
Drives: BRZ Limited
the problem with the 2jz is that it ruins what this car is designed for .. nimble and fun to drive will not be .. fast in a straight line with an anchor up front .. not only the full setup will add weight but wont help with the center of gravity... the car will weight around 350-400lbs more up front and will need lots of suspension work to counter the effect of the higher COG so forget about the good handling part once you do that .. a ls swap would at least keep a good weight distribution while having as much potential as the old iron block 2jz...
davidp is offline   Reply With Quote
Old 07-30-2013, 05:46 PM   #30
Synack
Boosted
Synack's Avatar
Drives: Sideways
Has nobody thought of the VQ35? Cheaper, can easily make great power, lighter, sounds great, etc. Maybe I'll have to volunteer for the FR-Z project in a couple years
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-30-2013, 06:00 PM   #31
Dipstik-sportech
Dipstik-sportech's Avatar
Easy to make power from a vq35? Fully built engine for anything over 400whp, doesn't sound easy to me.
Sent from my iPhone using Tapatalk 2
Old 07-30-2013, 06:08 PM   #32
Synack
Boosted
Synack's Avatar
Drives: Sideways
VQ35DE-T
Gonna roll with ~500whp. Will probably have to drop the compression a bit. Either way, much better power below 3000rpm. Not to mention, cheap, again. Saving weight and keeping a good balance meanwhile getting power down low and reliable good power up top.
Old 07-30-2013, 06:13 PM   #33
Diode Dynamics
Diode Dynamics's Avatar
Cheap is such a subjective term...lol
-Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Spd229 (11-18-2013)
Old 07-30-2013, 06:19 PM   #34
Synack
Boosted
Synack's Avatar
Drives: Sideways
-Nick C.
Truth. I would say the FA20 with a decent turbo kit already tuned and included would sell for a decent price. I wouldn't think a 2003-2005 VQ with turbo kit, pistons, rods, etc would cost much more than ~$5000-6000. Of course there's labor too. Maybe there's a shop that would want to do it and sponsor it like the OP and like D3PE did with my car.
Old 07-31-2013, 05:59 AM   #35
Scion1181
Scion1181's Avatar
Drives: 02 Sequoia 2013 Scion FR-S
Awesome, hope you post some pics.
Scion1181 is offline   Reply With Quote
Old 07-31-2013, 06:41 AM   #36
ZDan
ZDan's Avatar
Drives: '23 BRZ
Best of luck with the build, weight distribution is going to be a challenge so every opportunity to move masses as far aft as possible should be taken. The car is 54/46 stock with driver, with pretty much *all* of the added engine weight going directly onto the front tires, it's going to be pushing 60/40. Not conducive to putting down big power! Can the turbos be mounted behind the rear bumper?
Old 07-31-2013, 01:03 PM   #37
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
LSx is right around 400lbs.
FR-S weight distribution is 53/47. CRUDELY, a 300lb weight increase will total about 3-3100lbs and 1800/1300 (60/40) weight distribution. That's putting every drop of weight in the front just about.
Fox body mustangs are rolling around with 60/40 and they can be built to absolutely destroy in drag. See:
[ame="http://www.youtube.com/watch?feature=player_embedded&v=ZWfYJyBUl5o"]Mustang battles R35 GTR from a DIG on the street - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=mZ7T1r3lB5k"]AV Boys "Grey Mare" Mustang Vs Izzy Performance Porsche Twin Turbo VRT - YouTube[/ame]
Anyway, it's all about setup. If he wants to drag/drift the FR-S, this is the *vastly* superior motor and you can argue an LSx swap in the mix but ultimately, his stock block 2JZ is going to hold/produce more power faster(and more reliably) than the FA20 will for a while if ever. And a built 2J is proven.
This is all assuming he's doing this for drag/drift. I pointed out before that's all it will be good for (and it will, predictably). But at the end of the day, to say X motor swap will ruin X car is just a load of shit for someone who has either never done an engine swap or is a forum warrior.
Another thing, there's more that needs to be upgraded when the platforms peak supporting components can really only handle 400-500whp. Max. Rear ends grenading, axles snapping. If he's going through with a 2JZ swap, I'm sure he's taking into account other stuff that will need to be strengthened/modified.
slicktop is offline   Reply With Quote
Old 07-31-2013, 11:46 PM   #38
FRSupra
FRSupra's Avatar
Originally Posted by Wise View Post
Probably. But a turbo or supercharger kit would keep the low centre of gravity and light weight of the FA20.
Depends on what you want. The FA20 will never be able to reach the amount of power potential the 2JZ has. But the 2JZ will take away the lightweight playfulness and controllability of this car's rear end. It's quite a heavy engine. It's bulletproof reliability comes at the cost of it's cast iron block weighing it down.
I used to have a MKIV Supra and I remember it was an absolute handful in the wet. Crazy fun in the dry though.
Originally Posted by slicktop View Post
Nearly 400? It's nearly 600 for the 2JZ, plus about 150lbs for the 6spd.
A 2JZ in the FRS is meant for drag/drift. That's it.
Originally Posted by Hawaiian View Post
Not to mention that the weight sits a lot higher on the chassis, and really has a huge effect on the balance.
FRSupra is offline   Reply With Quote
Old 08-01-2013, 12:35 PM   #39
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
There's a thread over in BRZ with an LS swap claiming roughly 56/44 weight distribution.
http://www.ft86club.com/forums/showthread.php?t=38499
Edit: 57/43
ineedyourdiddly
Old 08-01-2013, 01:10 PM   #40
jadewbj
jadewbj's Avatar
Wouldn't the built motor from crawford with forged pistons and rods and a stout turbo kit be much cheaper than $25,000? Plus it would make plenty of power for the car to make it ridiculous while keeping the Low Center of Gravity and weight down?
The Shortblock – CP S3L-i FA TURBO Shortblock Fully Blueprinted And Assembled is at about $4,000 right now on their site.
The installation kit they sell is $600
A turbo kit from various tuners is around 6-7 grand and can make upwards of 500 horse and could easily but upgraded with a bigger turbo etc to bring the power up.
That would be a total of $11,600 before labor which would be considerably cheaper than getting the totally different motor to work right.
Just something to think about.
jadewbj is offline   Reply With Quote
Old 08-01-2013, 01:19 PM   #41
slicktop
Well, then you have the sound of a I6/V8...
The built CP BRZ overheated apparently. I wonder what a 750whp flat 4 dyno would look like...
Old 08-01-2013, 01:30 PM   #42
jadewbj
jadewbj's Avatar
I think that was just in Matt Farah's test drive. They have since fixed it, I think.
Weatherstrip Update! Mac1235 Issues | Warranty | Recalls / TSB 28 04-11-2016 01:27 PM
EVASIVE MOTORSPORTS UPDATE BUILD FOR PIKES PEAK Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 04-28-2014 05:10 PM
Mod Update.... UM FRS CANADA 12 12-25-2012 01:50 PM
BESPOKE APP UPDATE OUT NOW ML Electronics | Audio | NAV | Infotainment 13 10-12-2012 07:47 PM
GT5 2.0 Update!... MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 11 10-15-2011 02:53 PM
