Old 07-30-2013, 05:43 PM   #15
wheelhaus
wheelhaus's Avatar
Are you referring to the distance between the pedals, or when you apply the brake it's traveling too far or not enough, and not on the same plane? When you apply the brakes, ideally it should be about level with the gas pedal.
A little high or low per preference, but you shouldn't have to reach your heel very far backward, or stick it far forward to catch the gas pedal.
Old 07-30-2013, 05:51 PM   #16
d4wt
d4wt's Avatar
Drives: a couple + an frs
a lot of people tend to keep the pad of their foot instep closest to the sole centered on the brake and try to hit the throttle with their heel. while this is "correct" it can take a bit of getting use to with the pedal arrangement of this car.
this also will create a sort of "roll" in your foot which leaves you sickling at an improper angle to hit the throttle. try sliding the pad of your food down and right more so that you are relying more on the area closest to your toes for the break and heel for the throttle.
yes i'll get a lot of flame for that as you should always have a firm base when heal/toe shifting. but to get use to this i find it easier to start this way and work back to aligning your instep. once you get back to this you'll notice more movement in your leg/knee instead of relying on the twist of your ankle (sickling) to tap the throttle.
works for me at least
d4wt is offline   Reply With Quote
Old 07-30-2013, 07:38 PM   #17
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
OP, this should solve your heel toe problem:
http://www.rallysportdirect.com/Cusc...elerator-Pedal
Was a pain in the ass to install the brackets but worth it.
enouf is offline   Reply With Quote
Old 07-30-2013, 11:02 PM   #18
frslee
Just drive it
Drives: 13' FR-S
Buy a pedal that attaches on top of gas pedal. Works great for me.
frslee is offline   Reply With Quote
Old 07-30-2013, 11:50 PM   #19
Yellow_Jacket
Drives: Whiteout FRS
Yeah, I agree with this. I just hit the brake with pad of my feet and cock my feet so I can blip the throttle with the heel. Works pretty well with this car.
Yellow_Jacket is offline   Reply With Quote
Old 07-31-2013, 05:04 AM   #20
Kefuddle
Drives: Blue manual Toyota GT86
I' thinking that with stock brake parts at track speeds and thus the amount of brake pressure required (compared to street driving - however spirited), that the standard GT86 pedal offset would be just right.
Kefuddle is offline   Reply With Quote
Old 07-31-2013, 05:12 AM   #21
ft_sjo
Drives: GT86
You're not pressing the brakes hard enough if you think the accelerator pedal is too far down. H&T is for when you're HARD on the brakes and need to blip.
Old 07-31-2013, 11:45 AM   #22
torqdork
torqdork's Avatar
Drives: RV-7
With 1K of all-mountain use, the pads are bedded in allowing a bit more brake pedal travel and life is good. Also, experiment with different shoe sole thickness, stiffness and width. Then practice during DD and within a week you'll be a natural.
torqdork is offline   Reply With Quote
Old 07-31-2013, 12:44 PM   #23
jwlee7ucla
Drives: Ultramarine FRS
no, h&t is whenever you are turning and want to change gears.
I'm sure a lot of you has figured out that this problem of mine is during light braking, not threshhold braking. If I have to be threshhold braking on the street, chances are it means I drove like a **** lol.
jwlee7ucla is offline   Reply With Quote
Old 07-31-2013, 12:47 PM   #24
ft_sjo
Drives: GT86
You shouldn't be changing gear whilst turning.
Old 07-31-2013, 12:55 PM   #25
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I heel toe DD and with any amount of brake pressure. Just practice
shu5892001 is offline   Reply With Quote
Old 07-31-2013, 04:15 PM   #26
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
Cusco makes a gas pedal you can attach to make it easier to heel toe
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 07-31-2013, 04:29 PM   #27
jwlee7ucla
if you want to be nitpicky, the gear change is right before the turn. Often times when I type things its like a mental vomit of words onto paper, so I don't proof read my posts, especially on concepts that are elementary considering that many people in this thread alone have heel toe'd for years
Difficult to heel toe NoVtec Scion FR-S / Toyota 86 GT86 General Forum 110 11-12-2015 05:42 PM
Heel Toe Question trackmagic Scion FR-S / Toyota 86 GT86 General Forum 36 02-24-2014 12:29 PM
Having difficulty heel toe #87 Tracking / Autocross / HPDE / Drifting 25 01-26-2014 11:00 PM
Heel toe #87 Other Vehicles & General Automotive Discussions 21 08-25-2012 05:39 AM
Heel and Toe ichitaka05 Other Vehicles & General Automotive Discussions 13 04-02-2010 02:28 AM
