Old 07-30-2013, 09:52 AM   #57
nunonuna
nunonuna's Avatar
Originally Posted by Gixxersixxerman View Post
I wire it up at the main fuse box, using the top left 15 amp fuse with a add a fuse.. Been running mine that way since November/December.. It comes on and off with the ignition.. On with ignition in the on position.
And I fully seal these lights, so there should be no fogging at all.. Out of all the retrofits I've done so far all have been fine.. And we are having a series of atoms here and so far so good
I got the fuse tap part, but I'm little confused with fuse box.
So main fuse box means One in the engine bay? Or One under the driver side dash?
I'm sorry that I didn't quite understand you.
nunonuna is offline   Reply With Quote
Old 07-30-2013, 09:06 PM   #58
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Yes the fuse box in the engine bay.. Top left is a blue 15 amp fuse that's the spot I use
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
nunonuna (07-31-2013)
Old 08-01-2013, 06:49 AM   #59
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
I decided to do it. Just went with the quad set up without halos. heres how it looks at night. Also a friend couple is in their frs to the left of me so you can see the difference in the output to stock
[ame]http://youtu.be/KT649XFoTcA[/ame]
and view from their car:
mrlewistan is offline   Reply With Quote
Old 08-08-2013, 05:12 AM   #60
paperboy42190
Drives: 2007 Acura TL Type-S
what did you do with the wiring for the drl/high beam? the drl voltage isnt enough to power on an hid ballast
paperboy42190 is offline   Reply With Quote
Old 08-08-2013, 05:15 AM   #61
paperboy42190
Originally Posted by x96nax View Post
Also, a foreground limited is placed inside the projector and is used to block off some light that is at the bottom of your beam. This usually helps visibility at night as your focus goes from seeing what's directly in front of your car to things that are seen 25+ feet away. Well that's how I recall it from reading up on it from HIDPLANET.com anyways.
exactly. most people think having such bright lights in front of the car looks so nice but in reality it makes visibility worse. having a foreground limiter helps visibility but unknowledgeable people will think your lights dont look at bright. a foreground limiter is not just something you can add though unless you're super skilled. it comes stock on TL projectors and I think a few others, but not too many.
Old 08-20-2013, 01:24 PM   #62
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
@Gixxersixxerman I've done the same mod as yours now and I love it. Unfortunately one of my halos came off... Can you tell me what adhesive you used to attach the halos? Going to redo them this weekend.
phanguy is offline   Reply With Quote
Old 08-20-2013, 10:13 PM   #63
Gixxersixxerman
I use a white tube of permatex I think the brand is, RTV adhiseve.. It's from autozone, clear, 5$ or so and really strong.. I have to cut it off they don't fall off or pull off
phanguy (08-20-2013)
Old 08-20-2013, 10:32 PM   #64
Gixxersixxerman
According to what I researched on HIDplanet, all factory projectors have some sort of foreground limiter, and morimoto projectors since the 5.0 have fore ground limiters also.. Im Still in the research phase though.. I get what it's for though
Old 08-29-2013, 10:45 PM   #65
8bit
What dashcam are you using? It's pretty neat you have the MPH linked to it
8bit is offline   Reply With Quote
Old 08-30-2013, 10:40 AM   #66
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
wow this is so nice, the difference in output versus stock is staggering.
Gixxersixxerman you should start selling these headlights as a package.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following User Says Thank You to f0rge For This Useful Post:
Gixxersixxerman (08-30-2013)
Old 08-30-2013, 12:51 PM   #67
Gixxersixxerman
I've done a couple more since this one and about 10-12 retrofits..
mrlewistan (08-31-2013)
Old 08-31-2013, 05:32 AM   #68
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
the blackview dr400 hdii or however you spell it lol but if your camera has a gps function it should be able to show mph on your vids via options menu. i kinda debated enabling it but figure i actually dont speed that much or in a crazy manor lol
Old 08-31-2013, 05:43 AM   #69
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
easy answer:
http://www.ft86club.com/forums/showthread.php?t=7435
i didnt want to bother seeing if the drl had enough voltage to trip the bixenon shutters so i just removed it.
then the highbeam wires connect directly to the wires coming out of the projectors because those lead directly to the shutters (does not get routed to the relays). for a quad set up you need highbeam splitter harnesses to make sure all 4 shutters have power
Old 09-09-2013, 01:06 AM   #70
phanguy
phanguy's Avatar
i wired all four halos to the inside 12v and put in a switch too. installed with the resistors that it came with of course. the smaller ones are super bright, but the bigger ones seem to be dimmer. i can't tell in your pictures, but is the brightness equal for both? mine is noticeable in direct sunlight or in reflections of other cars though so it isn't too bad. any ideas?
Quad exhaust tips? migle Engine, Exhaust, Transmission 86 09-23-2020 11:45 PM
J2 Quad catback exhaust? bcmakesiteasy Engine, Exhaust, Transmission 22 06-01-2015 03:43 AM
quad tips project d CANADA 6 10-03-2013 02:43 PM
TRD Style Quad exhaust Nafe AUSTRALIA 17 05-11-2013 02:13 AM
Quad Exhaust Lip? Neekowahhhh Scion FR-S / Toyota 86 GT86 General Forum 4 12-17-2012 08:49 PM
